HD 2000 vs Ati HD 6450 for Flash player!
Re: HD 2000 vs Ati HD 6450 for Flash player!
Thanks; so i assume that i'm good with Hd2000 ,since i only stream up to 1080p top ?Comment
check this video;
https://www.youtube.com/watch?v=E6LQCcER5Q0Comment
Also the Hd 6450 card shown on the test is only 512 mem mine is 1g mem,does this has any difference?http://www.videocardbenchmark.net/gp...Radeon+HD+6450
and
http://www.videocardbenchmark.net/gp...D+Family&id=37
The Intel HD graphics is much more powerful than a 6450, and is about the same as a GF 620.
http://www.amazon.com/Asus-Radeon-Si...o+cars+hd+6450Comment
No. The amount of memory on the graphics card has no impact on performance (at least not once you get above about 128MB). It's all down to the GPU.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
the video u posted is that of a gaming benchmark. gaming performance has got nothing to do with video decoding performance. they use different parts of the gpu during gaming and video decoding.
i remember reading somewhere saying that u need 128mb of video ram for viewing sd videos, 256mb for fhd videos and 512mb for uhd 4k videos. other than that the video ram doesnt make a practical difference.Comment
Thanks folks for this info: i did try to use the IGT hd2000 with the other lenovo thinkcenter same motherboard H61 M series with DVI and VGA outputs to HD TV and Hd monitor, all good but only one problem, with DVI to HDMI i have over-scan and i can't use the computer on the LCD vizio display due to over-scan,and don't see no over-scan controls so i can fit the screen on the TV, with VGA it's ok but video is not as good,this is on Ubuntu 14.04 OPS, so went back to discrete Ati HD 6450 card,where i have the Ati Catalytic controls for over scan,
now ordered a Display-port to Hdmi cable, since the other same Lenovo Thinkcenter M series chip set H65 with OPS Win 10 has Display-port and Vga outputs,
hope it won't happen the something the over-scan issue! otherwise i have to be obligated to use the Discrete Ati HD 6450 instead. i will keep you posted.Last edited by ivtec; 09-18-2015, 10:20 AM.Comment
there is no overscan on digital. i'm sure vizio is to blame for as they're a crappy brand. check the TV zoom levelsThanks folks for this info: i did try to use the IGT hd2000 with the other lenovo thinkcenter same motherboard H61 M series with DVI and VGA outputs to HD TV and Hd monitor, all good but only one problem, with DVI to HDMI i have over-scan and i can't use the computer on the LCD vizio display due to over-scan,and don't see no over-scan controls so i can fit the screen on the TV, with VGA it's ok but video is not as good,this is on Ubuntu 14.04 OPS, so went back to discrete Ati HD 6450 card,where i have the Ati Catalytic controls for over scan,
hope it won't happen the something the over-scan issue! otherwise i have to be obligated to use the Discrete Ati HD 6450 instead. i will keep you posted.Cap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
Depends on application. It won't make or break a card, but in intense applications it can help.sigpic
(Insert witty quote here)Comment
yeah, gaming, it can, if it's real 3d gaming with large textures and frame sizes, shaders, maps, etc.
but honestly, for win7, if the cmos lets me have a choice I change it to 32M, and it makes no difference for the areo score
hardware buffering of HD videos, it can make a difference. Anything 4k even my i5 lags on, and it never let me choose my apu memory. But the problem is CPU power, as I've looked at my core percentages and it's 100% across all cores decoding youtube 4k, or 1080p@60fps (it fluxates framerates, but its not as bad as the lag I get from 4k)
and this is an ivy bridge i5 3230 /w a 7.1 cpu scoreCap Datasheet Depot: http://www.paullinebarger.net/DS/
Uranium you're right; the problem is my Vizio but for now i have to live with it,
and the Ati HD6450 is doing a good job on the Ati Catalytic control,that's why i decided to keep it instead of changing to the IGT hd2000 and canceled the Display-pot to HDMI cable because i learned it would do the same thing as the DVI, the over-scan on Vizio tv,besides i also learned that the buffering and other issues on Fubotv streaming site were their fault, but now they have changed and structured their streaming site and lately i have no issues,so now i'm happy with the Ati HD 6450.Comment
by ekozeko333Hi all,
I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
🔥 The Problem Started After Suspected ESD/PD Fault
I experienced a power issue or ESD event through a USB-C charger
After that, the NX20P5090 power switch was visibly burned and was replaced
Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
🧠 What I’ve Done So Far
Flashed...-
Channel: BIOS Requests ONLY!
by corrizeHello, I'm stuck in troubleshooting…
The flash system works like that : when the (mechanic) flash button is pressed, the flash mecanically pop up, and a circuit buck boost elevate 7v (batt) to 200-300v (?) for charging the big capacitor. And when the photo shoot button is pressed, the capacitor is discharged in the xeon light.
In the D800, there is a first « power board » close to the battery. 2 wires (batt 7v) goes to another little « flash board ». I measured 7v, so ok.
When I press the flash button, it's detected by the system, flash icon appear on LDC display.... -
Hello everyone !
I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
Feel free to share your experience if you ran into other issues.
DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
CD tray would not come out of the player
I could hear a motor spinning inside the player but the CD tray would not come out.
Turned out that the issue was the CD tray belt that aged poorly and began to...-
11-05-2025, 03:11 AM -
This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, RTX, Wifi, Switzerland/Lux, Platinum, W11P schematic. Our users have donated over...09-07-2024, 04:10 AM
This specification for the Microsoft Surface Laptop Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H boardview and Microsoft Surface Laptop Studio, 14.4", 2000 GB, i7, 32 GB, Wifi, Switzerland/Lux, Platinum, W11H schematic. Our users have donated over 1 million documents...09-07-2024, 04:10 AM
- Loading...
