Dell inspiron 3521 la-9104p dead
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Model-Dell Inspiron 3521
    M/B-La-9104p rev 1.0(A00)
    Problem-Dead
    The ene kbc was shorted, so i replaced it with a new one and programmed it as well with Rt809F. unit still has no 3.3v
    I have tried the following:
    01. Replaced another new kbc and programmed-still same
    02. Replaced Pu200 with TPS 51125-still same
    03.Replaced Pu100(ISL88731)-still same.
    04. There is no short on 3v and 5v coils(PL200 & PL201)
    05.Tried flashing both Eprom's-still same.
    I have noticed one thing which has left me puzzled--If i connect pin16 of Kbd Connector(which is connected to pin 42 of KBC) to Ground-all voltaged appears on the board-3.3v at battery terminals and power switch. Mb wont turn on simply coz connecting pin 42 of kbc to Gnd means KBC is in programming mode.
    So whats wrong???
    Please advise friends as i have run out of ideas.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Dell inspiron 3521 la-9104p dead
    No ideas?? or i'm not clear in my explanation of case?
    • razu
      • Jan 2015
      • 218
      • Bangladesh
      Its so difficult to find out .............laptop repair is tough work, sometimes its bother me
      • age80
        • Jun 2013
        • 55
        • Greece
        https://www.youtube.com/watch?v=rifMj6ne920
        Check this video you might find it useful and get some more clues...
        • jasko_jacker
          • Oct 2014
          • 1140
          • italy
          This is schematic and bios
          have you a short on 3.3v <-- EC ?
          ____________________
          MOD EDIT: Bios moved to bios requests sub forum
          • jasko_jacker
            • Oct 2014
            • 1140
            • italy
            I remember a similar issue on a thinkpad solved with a pch reflow but in this case you should , In this case you should try to separate 3.3V 5V block from its loads
            • raajkumar
              • Mar 2015
              • 354
              • Srilanka
              Check at PL600 & PL601 for short circuit. And also PU600.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Originally posted by jasko_jacker
                This is schematic and bios dump,
                No short on 3.3v ec
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Both the coils are not shorted to Gnd. Checked with a working board. Pu600 is fine
                  • raajkumar
                    • Mar 2015
                    • 354
                    • Srilanka
                    i had the same issue on a motherboard. but i don't remember which resistor is damaged. so check resistors around pu200.
                    • smali
                      • Sep 2014
                      • 288
                      • Pakistan
                      check RE4 and RE1
                      • anandkv123
                        • Jul 2018
                        • 27
                        • indiia
                        thanks
                        • jijunmedia
                          JIJUnMedia
                          • Jun 2016
                          • 18
                          • india
                          dears i have a problem dell 15-3521la-9104p)
                          it showing the massage battery not identifed system unable to charge
                          i change battery ,charger
                          chargig ic
                          3,5 ic
                          all starting /charging mosfets
                          near charging ic components
                          pch bios 32/io,bios16 bios programmed
                          io chip kb012qf changed and programmed
                          but no chance please help me friends
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Can u run the laptop only on charged battery?? Check for shorted caps on battery output lines. What about PS_ID??
                            • whitevolf
                              • Feb 2014
                              • 124
                              • TÜRKİYE
                              thanks
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                chargig ic
                                3,5 ic
                                This sort of "hit and trial" approach makes things worse and sometimes render the mb unrepairable. Identify the fault first, understand the circuit or seek help in the forum instead of killing mb's.
                                • djharold
                                  • Aug 2015
                                  • 247
                                  • COLOMBIA
                                  thanks
                                  • hussaka
                                    • Jan 2015
                                    • 154
                                    • italy
                                    Thank you
                                    • ycok
                                      • May 2017
                                      • 37
                                      • Türkiye
                                      Thank you
                                      • scarts4
                                        • Feb 2020
                                        • 4
                                        • Greece
                                        Thanks a lot guys.
                                          DELL Inspiron 3671 Inspiron 3000 i3-9100 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3671 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3671 boardview and Inspiron 3671 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:36 PM
                                          DELL Inspiron 5680 Inspiron 5000 i5-8400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 5680 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 5680 boardview and Inspiron 5680 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:30 PM
                                          DELL Inspiron 3668 Inspiron 3000 i5-7400 Specification for Upgrade or Repair
                                          This specification for the DELL Inspiron 3668 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Inspiron 3668 boardview and Inspiron 3668 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL...
                                          09-12-2024, 03:28 PM
                                          DELL Inspiron 5680 Inspiron 5000 i3-8100 Specification for Upgrade or Repair
