lenovo yoga 2 pro (20266) bios looking for
  • tlh
    • Sep 2017
    • 5
    • Turkey
    i need bios
  • tlh
    • Sep 2017
    • 5
    • Turkey
    Re: Lenovo Yoga 2 Pro (20266) Bios looking for
    i need bios
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Re: lenovo yoga 2 pro (20266) bios looking for
      if you dont post complete info like mb code etc, no one is going to bother. Post your old dump and describe your problem first. There are very capable members here who can help you.
      • lucaszmn
        by lucaszmn
        Problem:
        Initial Findings:
        • I concluded that the
        08-12-2025, 03:01 PM
      • AYsys
        Lenovo Yoga X1 Gen4 - Faulty Bios or what is going on?
        by AYsys
        Hello dear forum members,
        I own two Lenovo Yoga X1 Gen 4 laptops. One of them had a touchscreen problem, and I tried to fix it by externally flashing the BIOS. Unfortunately, I didn’t save the original BIOS and accidentally flashed it with a faulty one. After that, the device stopped working completely.
        I then had the idea to make a BIOS backup from the other Yoga X1 Gen 4 (same hardware) and flash it onto the non-working device.
        Nothing was flashed here — the BIOS was only backed up.
        I created the backup using a CH341A Black programmer and NeoProgrammer....
        Yesterday, 11:05 AM
      • Wahaz
        by Wahaz
        10-30-2023, 08:42 PM
      • HotSaladMan
        Lenovo ThinkBook 14S Yoga ITL Bad Flash + Need Bios
        by HotSaladMan
        *##*#*#*#*#*#Cringe Warning Used Clips for Tl866ii Plus Backups#*#*#*#*#*#
        Model : Lenovo ThinkBook 14S Yoga ITL
        S/N : MP28JT19
        MFG Date : 2022/02/09
        Factory ID PRC4
        MO : MPNXB26080FX
        MTM : 20WE001US
        MODULE FCC ID : PD9AX201NG
        IC : 1000M-AX201NG
        BOARD INFO
        FLV34 LA-KO51P
        REV : 1B 2020-08-24
        Bit of Info
        Using Tl866ii Plus, it would scan the chip but wouldn't not detect the
        chip id, so i would always uncheck the id check, so it would bypass the error
        i did in fact make...
        11-07-2024, 07:46 AM
      • beogeek
        Lenovo Yoga Slim 7 14APU8 Bios Request
        by beogeek
        I've currently got a Lenovo Yoga Slim 7 14APU8 that is not posting. Its fan spins, the keyboard lights up, and the caps lock doesn't work. It was taken to some shop for cleaning, and then they updated or tried to update the bios. After that, there was no display and no post. I've removed the bios ic from the board and made a bios dump. I need some assistance going forward, as I suspect this is probably just a bad bios issue. I've tried searching for a dump, but no luck; if anyone can throw me a bone, it would be much appreciated!
        Attached is the bios dump in the state I received it...
        10-24-2024, 12:54 PM
