DELL U2410 monitor psb capacitors
  • lestra
    • Oct 2013
    • 5
    • Serbia
    Hi everybody. My Dell U2410 monitor won't turn on (sometimes it want) so I decided to replace caps on PSB. There are some 470uf 35v 125c caps but problem is, I have only 105c caps. is it dangerous to use these instead?
    Also I can't read transistors labels. If someone knows their names please share. Thanks
  • R_J
    • 9535
    Re: DELL U2410 monitor psb capacitors
    Post pictures, 105c caps are fine, slightly better as far as temperature goes, also don't forget to check the small value caps, (like 1, 4.7 10 uf etc.) usually at 50 volts, they go bad and look fine. either check them with a cap/esr meter or replace them.
    • lestra
      • Oct 2013
      • 5
      • Serbia
      R_J thanks for response. Here is pic
      • lestra
        • Oct 2013
        • 5
        • Serbia
        Flipped image
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Can you tell us what brand and series is written on the original caps? It appears some of them are perhaps Su'scon (a brand with pretty mediocre reliability). The orange one doesn't inspire any confidence either (looks like an inferior brand too).
          Also, looks like this PSU has two power sections: main and standby (always-on). Also, it has Active PFC. Good way to troubleshoot these is to see if you have a voltage on the always-on power supply as well as measure voltage across the big electrolytic cap. (High Voltage! Be careful with that one! Many of the components around it may have high voltage on them too, so keep your fingers away from touching anything else.)
          Probably better to start by measuring voltage on all of the pins of the two low-voltage connectors (that is, the one in the upper-left and lower-right corners of the board shown in this picture: https://www.badcaps.net/forum/attach...6&d=1537522928 ). Then post what results you get here like this:
          Connector CN___
          pin 1: yyy Volts
          pin 2: zzz Volts
          ... and so on
          Connector CN__
          pin 1: iii Volts
          pin 2: jjj Volts
          ... and so on
          Some underside pictures of the bottom (solder side) of the board as well as a few pics showing the connector pins (and any labels they may have) would also be very helpful to determine what is what.
          • lestra
            • Oct 2013
            • 5
            • Serbia
            Momaka thanks for response and sorry for delay. All caps are Su'scon except orange on the right side, that one is GXE.
            I wanted to test monitor without plastic case and I plug power and turn it on while holding it. It start to falling on desk and I by accident touch transformer in the middle of the board. I seen strong yellow light and nothing else...then I drop monitor and start shaking, WOW? I think voltage is about 400v there.
            • Borse2008
              Seeking Advice: Repairing Dell U3425WE Monitor with Faulty USB-C/Thunderbolt Ports
              by Borse2008
              Looking for some advice or opinions on what to do with a monitor issue I’ve run into. Apologies in advance is this crossovers a few forum categories.
              I have a Dell U3425WE, which I've recently replaced with another model. That said, the original unit is still fully functional in terms of the display — it works perfectly over HDMI and DisplayPort. However, the USB-C and Thunderbolt 4 ports have stopped functioning correctly. The Issue:
              • The 90W Thunderbolt 4 port (circled in the photo) no longer charges or powers any device, including laptops or MacBooks.
              • There’s
              07-15-2025, 04:55 AM
            • Bowline
              by Bowline
              06-11-2025, 10:13 AM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
              by momaka
              03-15-2023, 10:17 PM
            • Jesus Coder
              Issues Reviving Old Dell 2408WFPb Monitor
              by Jesus Coder
              I have been having some difficulties reviving an old Dell 2408WFPb PC monitor that I received for free. When I first acquired it, the backlights of the display were on but alas no image was showing. After extensive research on the topic, I went ahead and purchased a new t-con board for the monitor. After installing the board, I was then presented with a new screen that was half black and half green (more so black). I have been unable to figure out what to do next as I have limited knowledge of display electronics. Might anyone on this forum have an idea of what may...
              06-25-2023, 02:33 PM
