samsung ht z310 - FAN_CHK error
  • Sadistic Taste
    • Mar 2014
    • 72
    Hi
    Hoping someone can help me troubleshoot this, I'm still trying to learn. I found the schematics online, but i need some guidance
    The system turns on a works, but after about 20-30 seconds I start getting FAN_CHK on the display, then it powers off. Obviously overheating.
    Opened it up, and the fan isn't working. It doesn't seem to be getting power.
    I have measured 12v up to QF3, then nothing. Can't find any shorted components, or any obvious blown caps.
    If anyone is willing to take a look at the schematic, and help me out, I would really appreciate it. Thanks
    Re: samsung ht z310 - FAN_CHK error
    What page is that QF3 at?
    Pictures of the board and the model number of the fan?
    • Sadistic Taste
      • Mar 2014
      • 72
      Hi Budm, thanks for your replay.
      My mistake, it's FQ3. I'm not home atm, I will upload a pic tomorrow.
      Just a an update tho, I wasn't getting any voltage on the fan connector at first, but after about 20 seconds I was getting 3.3 on one pin, and 6.7 or so on the other pin.
      The fan still would not spin, so I connected it to a 12v source and it spins fine. I connected it back up to the z310, and once the voltage kicked in, I manually turned the fan with my finger, and it starts spinning. However, once I power it off and back on, it stops working again.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        If you can start it with your finger then either the voltage is slightly low and unable to kick start it or most probably the fan bearings are worn and the fan needs to be replaced.
        What DC voltage rating is on the fan. It also supplies feedback pulses when running to the mainboard.
        • R_J
          • 9607
          You should have +12v on the emiter of FQ3, once the unit is turned on the micro should tell FQ3 to turn on and supply +12 (aprox) on the collector, the current should flow through FR3, throught the FAN and through FR1 to D.ground. when the volume is turned up, audio is fed through fr8,9 fc5,6 and rectified by fd1,2 that turns on fq2 that turns on fq1 that connects fr12 accross fr3, this increases the voltage to the fan speeding it up. If the fan starts when you spin it do you still get the error? also if you spin the fan and it starts does the speed increase when you turn up the volume?
          I suspect the fan is just bad enough to not start and run with the lower start voltage.
          going by your voltages and assuming 12 volts at FQ3, it looks like there is about 100ma runnig through fr3, the fan and fr1
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            I have never seen a circuit to drive a fan like this. Why so complicated?
            • Sadistic Taste
              • Mar 2014
              • 72
              First of all, thank you everyone for your help.
              I have attached some pics. Also, the fan model is Xfan: RDM5015S
              I was thinking it could just be the fan..
              Originally posted by R_J
              If the fan starts when you spin it do you still get the error? also if you spin the fan and it starts does the speed increase when you turn up the volume? I suspect the fan is just bad enough to not start and run with the lower start voltage.
              Thanks for explaining the circuit. Once I get the fan spinning, the error is gone, until the next time I turn it off/on, or stop the fan with my finger.
              The fan isn't increasing when I adjust the volume, voltage is reading 4.12 on my meter with the fan running. I only have one speaker here.
                So what DCV do you get between the two wires of the FAN?
                • Sadistic Taste
                  • Mar 2014
                  • 72
                  I get 7v on the red, 3v on the black and 4v across the two pins.
                    So the fan is only getting 4VDC, min is 6V per spec for the Fan requirement.
                    Are you getting 12V on the Emitter of FQ1, and a little less on the Collector of FQ1.
                    Notes: FQ1 may not be turned on unless the circuit detects the Audio signal on the F-L speaker.
                    • Sadistic Taste
                      • Mar 2014
                      • 72
                      12v on the emitter, and 8v, on the collector. It's now decided to work normally. Tho I've had it on running for a while..
                      I'll leave it unplugged and try again shortly.
                      • Sadistic Taste
                        • Mar 2014
                        • 72
                        Ok, I've powered it on/off a few times now to test, and it has only gave the error once so far. I didn't get a chance to check the voltage, as it powered off.
                        I seem to be getting the 6VDC on the fan connector now, but I still feel that something is wrong, since I did get the error again once.
                        When I have the the error, the fan seems to be only getting 4VDC.. Strange
                        • R_J
                          • 9607
                          When the unit is turned on you should get +12 on FQ3 emitter and aprox +12 on the collector, if not that transistor could be bad or its not being turned on enough by FQ4
                          Check the voltage on FG4 Base and collector (emitter is ground), the check the voltage at FQ3, base.
                          FQ3 is acting like an on/off switch for the circuit, if its not supplying +12 volts that circuit (and the audio driven speed control) will not work properly
                          It's possible FC3 (47uf/16V) could be bad (open)
                          • Sadistic Taste
                            • Mar 2014
                            • 72
                            Yes, I do get +12 at FQ3. It's FQ1 where I get +12 on the emitter, and +8 on the collector.
                            Strange thing is, its been working fine for the last few hours, powering on/off etc. Only thing I did, was replace R91, on the power supply board, as it was looking a bit burnt.
                            • toncsiking
                              • May 2019
                              • Magyarország
                              Ok, old thread but could be helpful for newbies and for others too
                              I had the same problem (after 30 seconds the display shows fan-check, and ampilifier switches out in 30 seconds.)
                              For me I found a real solution:
                              there's a capacitor FC-2 (47microfarad, 16 V) at the output connector of the fan - it was short-circuited, zero ohm. Replaced, perfect...
                              Worth to check it!
                              Now, I can see after repairing, what happening:
                              at start the fan is out, but in 30 secs it starts to work, even if there's no real need for it - as the system gets shortcut respond/fan error stops the amplifier, switches out.
                              Hehe ))
                                I think this fan circuit has to be one of the most complicated I have seen, a temperature sensor control circuit would have been so much easier but instead it is based off volume level. As a result it needs additional fault detection circuitry and many analogue components. Very odd!
                                • Curtissimo
                                  HP EliteBook 850 G8 - Error code / Caps Lock permanently on and blinks twice every 6 seconds
                                  by Curtissimo
                                  Hi everyone.
                                  I have a HP Elitebook 850 G8.
                                  Serial: 5CG2324XM0
                                  ProdID 6L8D5EC#ABA
                                  It has a Winbond W25Q256JVEN Chip.
                                  I need to remove BIOS Password.
                                  I made a dump with an CHA341A programmer and NeoProgrammer 2.2.0.10.
                                  Attached my dump.
                                  I also used the HP Unlocker tool to create an unlocked file (I followed the guidelines)
                                  I also downloaded latest HP BIOS Update (SP158137) which includes 3 .bin files. I found the Number T76 in my original dump, so I used: T76_01210000.bin
                                  What I did:...
                                  08-26-2025, 04:42 AM
                                • eigma
                                  Samsung UN40H5003 boot loop every ~8 seconds
                                  by eigma
                                  Hi, I rescued a Samsung UN40H5003AF (H = 2014 FHD) from the curb. Symptoms are: standby (red) light comes on, stays on for 8 seconds, flickers off, then comes back on, and the cycle continues.
                                  Service manual: https://www.electronica-pt.com/esque...is-u8la-71272/
                                  SMPS board: checked voltages, all seem normal (A13V = 12.8V, UD = 3.3V, PWM_BLU = 0.77V, PS_OnOff = 5.5V). Remove 10p cable to main board -> backlight comes on. I think this means SMPS board and backlight are good.
                                  Main board: BN94-07592P / BN97-08922R...
                                  11-20-2024, 10:31 PM
                                • peterwang
                                  Samsung NP750QGK-KG3US BIOS program error seeking help
                                  by peterwang
                                  PCB:BA41-03025A BA92-25486B
                                  I opened the Modular Flash Image Tool-v16.50.00.1120 software and encountered the following error message. I am seeking help.
                                  08-14-2025, 08:15 PM
                                • Sus256
                                  HISENSE 65E7KQ PRO - no boot
                                  by Sus256
                                  Hi all!
                                  HISENSE 65E7KQ PRO
                                  RSAG7.820.13512 - chassis
                                  MT9618BAATAB - cpu
                                  RSAG7.820.12059 - power
                                  HD650Y3U77 - panel
                                  KLM8G1GETF - emmc
                                  The TV does not turn on, the standby indicator is on. All voltages are present.
                                  Emms is dead. Not readable, not detected.
                                  Replaced emmc.
                                  But with another dump there is no launch
                                  Terminal log
                                  UART
                                  AC_ON
                                  RPMB key is not yet programmed
                                  HASH1_VERSION=0x00000000 64bit
                                  E-B
                                  FDE enabled
                                  layout pattern onebin by SAR7,0...
                                  06-01-2025, 02:11 AM
                                • sushilachuthan
                                  APC UPS error P13
                                  by sushilachuthan
                                  one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                                  the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                                  The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                                  We replaced the SCR with new device,, but the device is not power on as expected.
                                  Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                                  09-26-2025, 09:00 AM
