Pls tell me Generally what this is, and if you KNOW a substitute, what is that. Thanks, see pic, as I can read is C007?
Help Identifying component, what is this?
Tags: None
Re: Help Identifying component, what is this?
Can you provide more information? IE: is one leg connected to ground? (regulator) or is voltage fed into one pin and out another (mosfet) Is there a board designator U, IC, Q, D etc. it seems to have a white arrow which might designate pin1
Two pins (2,3) appear to be connected to heavy traces and pin1 seems to be a thin trace indicating it could be for a gate or base connection. Does that thin trace running under the part connect to pin1? or are pins 1&2 connected together?Last edited by R_J; 10-04-2019, 02:47 PM. -
What kind of board is this? laptop?
EDIT: I just saw the thin trace going to the bottom pin. Most likely some FET or Transistor.Last edited by KvnTM; 10-04-2019, 02:46 PM.Comment
The blown part is directly under the LDVS1 video connectors, on the bottom of this Dell 2330 AIO Motherboard. None of the three pins go to ground. The thin trace went to pin 3 in my pic. Pins 1 and 2 are eventually connected through other elements and tracing. The tweezers point where the C 007 was. I have failed to find that part number on any component in the Russian 1200 page manual. Ideas? Let's take a guess......I got nothing to lose that's not already goneComment
My guess would be that it is a switch (mosfet) maybe to switch the panel/t-con voltage on and off if it is connected to the lvds cable. There is likely a supply voltage on either pin 1 or 2 and the control pin would be pin 3Last edited by R_J; 10-04-2019, 03:54 PM.Comment
Yes, connected to lvds. RJ, can you suggest a common part number in that kind of package?Last edited by captainKKK; 10-04-2019, 03:52 PM.Comment
Please measure the resistance on all pads of the device to GND.
Just replacing it won't help. it will blow again.Comment
.Last edited by captainKKK; 10-07-2019, 07:53 PM.Comment
by KhojaHello friends, I have a Lenovo Ideapad Flex 5 14IAU7 laptop that doesn’t turn on. When I opened it, I found a burnt resistor on the motherboard. Since I couldn’t find a schematic for this model, I need help identifying the parameters of this resistor.
- Model: Lenovo Ideapad Flex 5 14IAU7
- SN: PW0AZK3W
- Motherboard: LC57-IAU MB 213062-1M 448.0RH09.001M
Any assistance would be greatly appreciated!...1 PhotoYesterday, 09:56 AM -
Hello! I am looking for help with identifying this tcon chip on KOORUI 24E4 monitor.
Driver board number: pn238ct01-3-xc-2
Other IC on the driver board: NT71265MFG-001
Good morning, I would appreciate help identifying resistors responsible probably for volume down / volume up buttons that I accidently knocked off while replacing fan connector. I enclose picture with location. Thank you for help in advance.1 Photo07-19-2025, 01:49 AM
by omaarI need help identifying this IC and, if possible, the value of the capacitors next to it. It is part of the HDMI circuit of an EVGA RTX 2060 GPU. It suffered a short circuit, leaving the graphics card without video and the TV without image....2 Photos06-06-2025, 07:48 PM
Subject: Help Identifying IC on 820-02020 (MacBook Pro A2338 M1, 2020) — C02045500 / EKQ8LL1A
I'm working on a MacBook Pro A2338 M1 (2020) with logic board 820-02020.
The machine has a power issue — not powering on, and I'm trying to trace the fault.
While inspecting the board, I found a cluster of components
This area looks damaged or burned — there are about 4–5 components that seem affected
I've attached a close-up photo of the chip and its surrounding area (see... - Loading...
