Bios --ga-h61m-s1-rev.2.1
  • okbalord
    • Jun 2017
    • 205
    • Algeria
    Dump bios gigabyte /ga-h61m-s1-rev.2.1 tested -good
    OKBALORD
  • ch.a.v1985@mail.ru
    • Dec 2019
    • Россия
    Re: Bios --ga-h61m-s1-rev.2.1
    THANKS, THANKS, THANKS GREAT
    • hollowman
      • Jun 2014
      • 4
      • bahrain
      thankyou
      • atsaws
        • Nov 2017
        • Brazil
        Thank you my friend
        • jose osorio
          • Jun 2020
          • Colombia
          Thank.
          • hitec
            • Apr 2017
            • 4
            • algreria
            Thank you
            • zyze
              • Jul 2020
              • 4
              • lietuva
              Thank you
              • nassimhamdi
                • Feb 2016
                • 155
                • algeria
                thanks
                • Albertoq
                  • Jul 2019
                  • 11
                  • Perú
                  thank you
                  • chemseddine
                    • Jul 2017
                    • 34
                    • algeria
                    thansssssssssssssssss
                    بارك الله فيك
                    • surmalu
                      • Mar 2020
                      • 7
                      • Armenia
                      Big Thanks from Armenia.
                      • okbalord
                        • Jun 2017
                        • 205
                        • Algeria
                        np... ur welcome
                        OKBALORD
                        • Zickko10
                          • Sep 2021
                          • 85
                          • Nigeria
                          Thank you
                          • BPJA77
                            • Feb 2022
                            • Perú
                            thank you
                            • raedinformatique
                              • Feb 2018
                              • 25
                              • algeria
                              Thank you OKBA
                              بارك الله فيك
                              • herisbr
                                • Sep 2020
                                • colombia
                                thank you
                                • kadi144
                                  • Aug 2015
                                  • 690
                                  • algerie
                                  • miloud
                                    • Nov 2021
                                    • 15
                                    • algérie
                                    thankyou
                                    • Ahari
                                      by Ahari
                                      I...
                                      08-13-2025, 06:12 AM
                                    • mkdj
                                      by mkdj
                                      Dear all,
                                      10-19-2025, 04:41 AM
                                    • Habble7
                                      by Habble7
                                      Suspected Cause:
                                      Troubleshooting Attempts:
                                      05-22-2025, 07:28 AM
                                    • haitham sharabati
                                      [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                      by haitham sharabati
                                      Hello engineers 😀,
                                      I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                      🔧 Device Info:
                                      - Model: HP 15-da2007ne
                                      - Product Number: 8XF55EA#ABV
                                      - Serial Number: CND0338P0D
                                      - CPU: Intel Celeron N4000
                                      - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                      💀 Problem:😅
                                      - Device shows “Administrator Password”...
                                      08-07-2025, 04:54 AM
                                    • Citymin
                                      by Citymin
                                      S/N : 5RNK9FFT70...
                                      08-05-2025, 05:12 AM
