Need Flash Dump for TP-Link TL-WA7210N
  • MaXwELL
    • Oct 2009
    • 14
    • Turkey
    Hello Guys
    Two devices cannot be used due to flash failure.7210N dump required.Share if you have backup?
  • mmn3md
    • Jun 2013
    • Moldova
    Re: Need Flash Dump for TP-Link TL-WA7210N
    https://www.chipsetpro.com/download/CH341A-402mb.zip
    CHECK INSIDE
    • khalid XD
      • Mar 2020
      • 4
      • Marrakech
      • theblackpitbull
        • Dec 2020
        • Venezuela
        Many thanks
        • spmetroil
          Request: SPI Flash BIOS Dump (Winbond 25Q128) for Dahua NVR4216-4KS2
          by spmetroil
          I am trying to repair a Dahua NVR4216-4KS2 that is not booting.
          The main BIOS/firmware is stored in an SPI flash EEPROM (Winbond 25Q128, labeled as U130 on the PCB).
          I have a CH341A programmer and I already attempted the following steps:
          1. Identified the correct chip (W25Q128, 3.3V SPI flash).
          2. Tried to read the contents with CH341A Programmer software. The dump seems corrupted and I often get the error: “Chip with the contents are in disagreement.”
          3. Compared several chip type selections (24Cxx and 25Qxx families) to confirm it is indeed a 25 series SPI
          08-19-2025, 09:23 AM
        • kooroshi60
          Traktor Kontrol S4 MK1 Flash dump
          by kooroshi60
          Hi guys
          I need the Flash Dump (.bin) file of the Traktor Kontrol S4 MK1. SPI chip number is 25DF041A from Atmel (4Mbit)
          So please let me know if you have the .BIN Dump of this model and its price and the payment method.
          I appreciate your help.
          10-01-2024, 10:17 AM
        • bamdad61
          Canon DR-1210C flash dump request
          by bamdad61
          Dear folks, recently got a canon dr-1210c and it worked perfectly just for one day. Right now it shows all possible errors on the screen and do nothing. I tear down the device and found a 32 pin plcc flash chip. I thought reprogramming firmware might be helpful. The firmware update file from canon support include a dll file which doesn't help. So if anyone has the dump it would such a great favor to share.
          04-15-2025, 02:43 PM
        • Shadowtuy
          Bricked bios from a bad flash/update in a case of NO BACKUP repair question
          by Shadowtuy
          So I'm new here and have successfully unlocked a bios using "RCUnlocker" but after that I'm curious on recovery of a bricked bios from a bad flash/update in a case of NO BACKUP.
          The part I'm stuck on is my HP backup are a 32,768KB and 16,384KB image compared to a fresh bios from HP at 23,690KB. How would I use the fresh image to repair a flash chip? The guide I'm following just takes the image and flashes it over but clearly there is more to it.
          Just looking to expand my knowledge of this since the password removal worked great. Sorry if I missed this being...
          09-05-2023, 11:24 AM
        • highland
          Looking for Flash dump from Zyxel devices
          by highland
          I'm looking for flash dumps for my following bricked Zyxel devices;
          XMG3927-B50* (also accepted alternatives VMG3927-B50* and VMG8825-B50*)
          and also,
          VMG3925-B10*
          Thanks in advance for all your support.
          09-04-2021, 04:27 AM
