HP DMI Tool NBDmiFit
  • hassanulhaq
    • Dec 2018
    • 8
    • Pakistan
    #101
    Re: HP DMI Tool NBDmiFit
    Originally posted by imranromi
    Yes post here bios dump i will fix your error..
    i have attached the bios backup taken by Bios Backup tool kit. Please help me fix it.
    • imranromi
      • Jan 2015
      • 1288
      • Pakistan
      #102
      How to program bios if i send you?
      • hassanulhaq
        • Dec 2018
        • 8
        • Pakistan
        #103
        i hope you will provide bit guide too for bios flashing.
        • imranromi
          • Jan 2015
          • 1288
          • Pakistan
          #104
          You need bios programmer read bios chip and post here.Other no have option you use toolkit is not proper your bios bkup..
          • hassanulhaq
            • Dec 2018
            • 8
            • Pakistan
            #105
            just name tell me name of programme so i can provide you proper backup.
              • 20611
              When you get your bios dump, start a new thread in the bios requests section and post your bios there , please don`t post in this thread.
              https://www.badcaps.net/forum/forumdisplay.php?f=40
              • zedameo
                • Jan 2019
                • 14
                • algeria
                #107
                thank you and god bless you
                • Slow
                  • Feb 2020
                  • Botswana
                  #108
                  Can someone please recommend a version that supports HP Model 15-bs151ni.
                  • dreamteam
                    • Mar 2020
                    • united states
                    #109
                    Which NbDmiFit do I use for Hp Elitebook 8540w?
                    • tlfrance
                      • Jan 2020
                      • 18
                      • france
                      #110
                      On my elitebook 8460p, the sku / serial / CT .... numbers has get out of the bios. Don't know the reason . I've tryed many nbdmifit tool version from 1st page (HPSETxxx) of this thread without any luck. When i run the correct dmitool, i enter correct values from the laptop, then display the changes ans the end , but no changes seen from screen remains.
                      Anyone have already seen this issue?
                      I've done a bios dump with my programmer , but i'm not confident how to update this binary .
                      Thanks for help
                      • acshud
                        • Sep 2017
                        • 106
                        • romania
                        #111
                        hy,i have hp probook x360 11 g3 ee and i was forced to rewrite the bios.now i don't have information about my laptop(sku,serial......) and when i turn on the laptop i have the message mpm.some advice?
                        • babypapa
                          • Apr 2020
                          • IL
                          #112
                          thank's great post
                          • delos23
                            • Apr 2020
                            Hello, So I'm currently working on an HP 15-ac121dx, It gets the error "System Board (00A) - System Board CT Number."
                            Now, when I click F1 to get the system information it says Ct Number: HP.
                            I have the correct CT number, but I'm trying to get the tools to be bootable from a flash drive so i can correct the information. I get it to work and when it comes up it ask me to correct the time, I do and it says Vendor code not supported or something along those lines. Is anyone willing to help me to see what I'm doing wrong?
                            Thank you!
                            • Alien71
                              • Apr 2020
                              • 3
                              • France
                              #114
                              Hi Techman1025,
                              Are you able to generate a specific smc.bin file for unlocking a bios password protected for an HP Probook 6460B please ? (Sorry for my bad english).
                              Thank you for your answer.
                                • 20611
                                Originally posted by Alien71
                                Hi Techman1025,
                                Post your bios in the "Bios Requests" sub-forum and one of the members will remove the pass for you.
                                • lapfix
                                  • Mar 2020
                                  • 2701
                                  • my workshop
                                  #116
                                  pleasr , how to copy/paste the DMI info from bios to other under windows , not with boot usb.
                                  or the only way is NBDmiFit tool !!
                                  • martin lippert
                                    • Apr 2020
                                    Originally posted by Murtaza527
                                    bro i have 840 g3 for unlock but i tried put smc.bin file into usb fat32 but cant boot with usb or not showing sms command handled successfully
                                    I have found out that you will need a specific SMC.bin file, which is composed be HP and requires serial numer as well as UUID.
                                    If you just use the standard FSMC.bin file an rename it, you will end up with error message SMC comand failure.
                                    Does anybody know, how to get this calculation done?
                                    Or get in touch by email with HP?
                                    KRs, Martin
                                    • sojibbhi
                                      • May 2020
                                      • Bangladesh
                                      #118
                                      Why i cant download the file...please help me
                                      • Miquell210
                                        • Jun 2020
                                        • 6
                                        • United Kingdom
                                        #119
                                        Hello all.
                                        This is my first post as new user so hello all.
                                        Got similar problen with my laptop HP-15-r101na.
                                        After replacing motherboard receiving three error which I expected to easly fix.
                                        Well - not really.
                                        Can find proper tool to do so.
                                        1. System Board (00A) - Product Name
                                        2. System Board (00A) - Product Serial Number
                                        3. System Board (00A) - Product Number
                                        The only one think able to do was to update BIOS to version F.45
                                        Then I`ve tried to use different version of NbDmiFit with error platform not supported
                                        According to HP Serial Number Repository (Product Configuration Tracker) laptop was manufactured in 2014 so I`ve used tools supporting in theory this model - but platform not supported appear in DOS, Windows, WindowsPE
                                        Can you recommend proper tool or any idea what I am doing wrong, please.
                                          • 20611
                                          Originally posted by Miquell210
                                          Hello all.
                                          Well - not really.
                                          Use HP bios config utility BCU ,and/or wndmifit from windows or nbdmifit from UEFI flash drive . Use version 2.10 or above.
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • tsavpyn
                                            Requests to Intel Flash Programming Tool for Linux Ubuntu x86_64
                                            by tsavpyn
                                            Dear all,
                                            I forgot my BIOS password of my Surface Pro 3, I searched for solutions for a long time and knew that by using FPT to dump my bios to bin file and using decryptor, I can get my BIOS password.
                                            Now I have a problem that I am unable to dump my BIOS into bin file.
                                            My Surface Pro 3 currently runs on Ubuntu 22.04, with Secure Boot enabled and Boot From SSD Only.
                                            I searched for FPT but there is no Linux version and none of them work.
                                            I hereby request a copy of Intel Flash Programming Tool for Linux x64.
                                            I would really appreciate it if anyone...
                                            05-28-2024, 11:18 PM
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool
                                            by shamsudeen
                                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                                            anyone having it, please share
                                            Thank you
                                            07-08-2025, 06:42 AM
                                          • tony359
                                            Best tool to place electrolytic SMD caps on a board
                                            by tony359
                                            HI all,
                                            I am working on some boards where all 100+ SMD caps have to be replaced (yes, they actually went bad!). I found a workflow to remove them comfortably (two irons, pre-heater and extra hot air for larger ones on ground planes).
                                            When it comes to soldering them back, I add solder to one pad and then I use a plastic tweezer to keep them in the right place while I solder that leg.
                                            The tweezer works - but I was wondering if there is a more "dedicated" tool or whether someone has a better idea. If it was for a bunch of caps then who cares. But because...
                                            01-28-2024, 06:23 AM
