XFX 850w blown bridge rectifier.
  • leotron
    • Apr 2019
    • 29
    • Offworld
    Hi, a friend of mine gave me this broken power supply, aparently it's the rectifier bridge that was damaged months ago. He took it to a technician and they didn't have the repair tools necesary but they remove the original bridge rectifier since it was damaged(burned). I have some of this rectifiers laying around, but they are not the same. The original its a pair of GBJ1506
    And I have KBL06 , KBL406 , RVB406, D5SBA20, D3SBA60, GBU608. Most of them have similar values to the original, but I'm not planning to use the PSU at full load (ie: SLI, an I7 processor, etc).
    TomsHardware https://www.tomshardware.com/reviews...su,4581-3.html
    Thanks in advance for your time!
  • leotron
    • Apr 2019
    • 29
    • Offworld
    Re: XFX 850w blown bridge rectifier.
    I'm sorry I didn't wrote my question, it is posible to replace the original bridge with the replacements that I have? I'm planning to put a large heatsink in top of them.
    Thanks for reading.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8696
      you're probably perfectly fine with the two KBL06 , KBL406 , RVB406, D3SBA60, or GBU608 in parallel - but you should use two identical units and should make sure both are well touching each other for thermal equilibrium. No heatsink is needed if the originals didn't have one though I don't think any of these really could benefit from one due to thermal resistance.
      If the two originals were attached together then perhaps some circuit mods are needed to accommodate...or just run at low load, say no more than 300W.
      I'd still try to find out why the bridge blew. These things usually do not blow.
      • R_J
        • 9535
        The GBJ1506 is a 15 amp 600volt bridge, The KBL06, for example, is only rated at 4 amps 200v
        • Quaddro
          Tukang Kentu
          • Nov 2010
          • 141
          • Indonesia
          Good only for testing, but not for continuous usage..
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8696
            I don't think it's possible to run 15A into even a GBJ1506 if it didn't have a heatsink, hence the suggestion that the lower units may be fine if there wasn't a heatsink to begin with (none of those little dinky pieces of metal, the heatsink needs to be somewhat elaborate, probably need at at least around 50cm^2 surface area).
            I thought I saw the KBL06 able to handle 600V@4A, agreed this is not sufficient for the full wattage of the supply, but should be okay for low wattage usage as well as inrush.
            FIND OUT WHY THE BRIDGE BLEW, IT'S NOT SUPPOSED TO BREAK THIS WAY!!!
            • leotron
              • Apr 2019
              • 29
              • Offworld
              Thanks to all of you for the answers, the PSU may be in short circuit. This ia stock image from TomsHardware that shows the heatsink.
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8696
                Okay that's not a good sign if it needed a heatsink stock, you will need to locate new 15A units if you want to run at 850W again, else you're stuck to do 250-300W until you do so.
                  master hoarder
                  • May 2008
                  • 12170
                  • Bulgaria
                  +100 ^ This!
                  If you have a blown bridge rectifier, chances are there is something else wrong with the PSU. It could be something as simple as blown MOVS (due to repeated power surges) or because of a blown APFC section (which is not so uncommon.) I'm betting on the latter, unfortunately.
                  That said, >>for testing<< the PSU, you can use any of the bridge rectifiers that are rated for at least 500V reverse voltage.
                  I personally suggest removing both GBJ1506 bridge rectifiers and testing both of them. If one is good, you can use just that rectifier and not have anything else with it in parallel. This actually won't really limit the output power of the PSU that much, if at all.
                  Not at all.
                  The only reason the manufacturer put a heatsink on those two 15A bridge rectifiers is for thermal coupling (and rather poor at that, but still better than nothing.)
                  The reason for the two 15A bridge rectifiers is to increase the efficiency: less current going through a diode means less power dissipated. Since diodes have non-linear power dissipation vs. current, you want to keep the current as low as possible across the bridge rectifier for lowest power dissipation (and thus, increased efficiency.)
                  But that doesn't mean that a single 15A bridge rectifier is not enough. Even if the PSU is used in a country with 120V AC line and the PSU has 80% efficiency when loaded... for a 850W PSU loaded with 800W of load (just making these numbers to make it easier to calculate), the PSU will be drawing roughly 1000W from the wall. @ 120V AC, that means it will be pulling roughly 10 Amps (let's say the line drops quite a bit under load with those 1000W, just for "worst case" scenario.) Many of these bridge rectifiers will still handle that 10A of current just fine. They will run absolutely hot, though... - Hence, the installment of two 15A parts in parallel. But in reality, even a single 15A bridge rectifier will likely be able to manage the full load on that PSU. And if living in a country with 230/240V AC, the current drawn will be half. So if you do live in a country with 230/240V AC, I wouldn't even worry about using just a single 15A bridge rectifier and leaving the PSU with just that.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8696
                    Eh... no, math does not check out. You're not going to even remotely halve system power loss by doubling the diodes. You will save some power but it's a drop in the bucket.
                    However you will spread out the heat generation. This strategy is frequently used and is the main reason why a lot of components are doubled up when possible. But this means that one will need to recreate the original situation when running in the original situation...
                    ... unless the heatsink was insufficient to begin with, and hence the bridge failed...
                    Last edited by eccerr0r; 02-20-2020, 01:14 AM. Reason: removing ambiguity ... english is a miserable language and hence people love arguing in english
                      master hoarder
                      • May 2008
                      • 12170
                      • Bulgaria
                      That, I agree with. But with these super-efficient PSUs, every "drop" counts a little.
                      That heatsink would probably be insufficient only if the PSU was at 100% load on 120V AC line that was dropping a bit low (110-115V maybe) and the PSU was ran like that for long periods of time so the B.R. had time to overheat and go bad.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8696
                        Staring at the datasheet, I think the waste power by running a single rectifier at higher current versus two would be less than 1W at around 900W system dissipation. Making sure the two rectifiers were balanced to realize this power saving potential is another problem...
                        Drooping from 120V to 110V at full load will increase rectifier dissipation by about 1W... I sure hope that heatsink can handle a 1W power increase.
                        • Steph.hen
                          Bridge rectifier identification part number KPB305G
                          by Steph.hen
                          Hi all, a newby question about a bridge rectifier I'm trying to identify.
                          I'm in the midst of reparing a battery charger in work which went pop, The bridge rectifier has shorted and took out a couple of other components. The rectifier in question has a part number KPB305G, and it looks like it's obsolete. Does any one know what I could replace it with?...
                          08-29-2024, 09:52 AM
                        • mpn78
                          Fujitsu Q556, What capacitor for bridge rectifier?
                          by mpn78
                          Hello
                          My Fujitsu Esprimo Q556 motherboards blew up. At least fuse, bridge rectifier and capacitor got damaged. I have changed fuse and bridge rectifier (DF1508S), but I don't know what capacitor it is (picture). I know that capacitors size is 47nF, but I don't know other specs for it. Can you help me to choose right capacitor for my motherboard?
                          There is 240V AC on input side of bridge rectifier and 340V DC as output on capasitors side.
                          Thanks....
                          04-05-2022, 12:31 PM
                        • EasyGoing1
                          Reading input and output of bridge rectifier on the same scope?
                          by EasyGoing1
                          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                          06-26-2022, 12:52 AM
                        • nicktasios
                          Macintosh Quadra 840AV PSU
                          by nicktasios
                          I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                          12-22-2024, 05:07 AM
                        • Ross Kohler
                          Diagnosing South Bridge (FH82H370) on Asus H370-Pro Gaming Motherboard
                          by Ross Kohler
                          I'm learning about motherboard repair and I believe I've traced the issue down for the South Bridge on the particular motherboard I'm working on. My path of concluding that:
                          - There's no sign of any attempt to power on when pushing the power button.
                          - No PSON signal is reaching the 24-pin ATX connector.
                          - The Super IO chip is receiving the PS_SWITCH signal from the power button and is relaying this signal back to the South Bridge.
                          - The Super IO is not receiving the S_SLPS#_R signal back from the South Bridge
                          - If I pull the Super IO S_SLPS#_R pin...
                          04-16-2024, 09:36 AM
