Samsung un58j5190 power supply failed
  • cspiddler
    • Aug 2011
    • 15
    I need a component # on my power supply board. Backlights failed and shorted the transistor that regulated the power to them. Model number is: UN58J5190AFXZA. Board number is: BN44-00787A. Part is located on back side near the backlights power plug. Location ic Q9102C. Transistor is heat damaged and I can't read the number. Can anyone help?
  • cspiddler
    • Aug 2011
    • 15
    Re: Samsung un58j5190 power supply failed
    I've had trouble posting my pics let me see if 3rd try is a charm.
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      I’ve had trouble posting my pics let me see if 3rd try is a charm.
      it will be a FET. Can you read the part number on the driver IC, located beneath the burned component?
      Searching its datasheet would give an idea, because manufacturers often use the recommended solution from the datasheet. But there are a few other things to take into consideration: why has it failed so badly? You have to find it out, maybe the backlight LEDs have made contact with the metal chassis? Also, when this FET goes bad, the driver IC and a few other surrounding components also go bad.
      Edit: Found it. AOD3N40. But you still need to find the reason it has failed so badly.
      Cheers, Janos
      • R_J
        • 9608
        Check Shopjimmy and see their note: https://www.shopjimmy.com/samsung-un...repair-kit.htm
        "This model has an above-average rate of LED strip failure"
        • cspiddler
          • Aug 2011
          • 15
          Thank you very much. I think I have some 3N40s on some other junk boards I’ve collected. The IC looks like an SEM 5027A. Don’t know if I have one of those but $3 maybe. Tkhe nearby resistor and diode on the top side of the board seem ok. Looking at the board I thought it would be junk but I checked the traces from the FET and all had “0” ohm continuity and none were shorted to other traces so I thought I might replace a few components and see if the board will fire back up. I’ve been to ShopJimmy and they say if the backlights fail likely it will crash the board, so backlights are next. Just a hobby to keep my old retired brain going. So if I can fix for little or nothing I can find someone that needs. Thanks again.
          • cspiddler
            • Aug 2011
            • 15
            Just an add-on if someone reads this post. Got a backlight taster and the backlights were bad which is what burned out the power board. May help you diagnose if you see this damage. Hard to make a case for repair when I have no use for it and the value is close to the repair cost. I mostly donate them anyway and like donations that bring several times the investment. Anyway this forum is a great resource and I appreciate the help. Thanks again.
            • brucetv
              • May 2015
              • 281
              • united states
              Here's a close up shot, had a power supply in stock. Hope it help. Looks like its made by Alpha & Omega
              Da Bears!
              • cmg3631
                • Nov 2017
                • 22
                Hey "cspiddler", I just wanted to thank you for this post! A buddy of mine gave me this TV and when I opened it up the exact same problem was very evident on the power board. This post saved me a lot of time, thank you.
                • R_J
                  • 9608
                  Originally posted by jeffreyulrich
                  Wouldn't it be better for you to change a bn44-00787a? It's cheap. It's only 26 dollars
                  https://w***************************...***********tml
                  Are you only here to sell your parts?
                  Last edited by SMDFlea; 03-31-2020, 08:27 AM. Reason: Spam link removed from reply to a spammer
                    Originally posted by r_j
                    are you only here to sell your parts?
                    +10
                    • cmg3631
                      • Nov 2017
                      • 22
                      Well! It's a moot point now. I cracked the screen while relocating it. I need to get me a pair of those suction cup screen holders.
                        • 12306
                        • U.S.
                        https://www.harborfreight.com/search?q=suction%20cup
                        • neilc6
                          • Nov 2015
                          • 1550
                          Have two power supply boards with blackened areas above Q9102C for UN58H5202. The marking is 5N40 (NCH, 5A, 400V) and not 3N40 (3A). If Q9101C is shorted, part is 50R380CE (NCH, 500V, 14A, 0.38ohm). Will need to order the parts from Digikey.
                          • William1967
                            • Nov 2017
                            • 217
                            • Netherlands
                            Please note, if the power supply has been repaired or replaced, the error has not yet been resolved, often seen with these models that flashover at the LED strips is the cause.
                              by sam_sam_sam
                              03-31-2024, 02:12 PM
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • cheeky2
                              Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                              by cheeky2
                              This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                              I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                              Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                              06-15-2025, 05:12 AM
                            • JimBanville
                              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                              by JimBanville
                              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                              09-13-2023, 07:21 AM
