about TL866II PLUS ERROR
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    am trying to install TL866II PLUS in my computer, but am getting config file writing error, how do i fix it on window 8
    • 31260
    Re: about TL866II PLUS ERROR
    you probably need to be admin for the install
    what version are you using? the current latest is 10.11
    http://forums.xgecu.com/viewthread.p...1&extra=#pid23
    • CapLeaker
      Leaking Member
      • 8342
      Yep, you need to have admin privileges on Windows to install the software.
      Thanks for the Link, I should be updating mine as well. I guess might as well get the RT809h updated too.
      • hispeck
        • Aug 2015
        • 258
        • nigeria
        Yes am having the latest 10.1 , at first I didn't install through admin, but I later tried to install through admin same, do I need to uninstall the first one?
          • 31260
          not sure.
          • hispeck
            • Aug 2015
            • 258
            • nigeria
            I just reinstalled now in another system that has window 7 through Admin, but is saying ( config file writing error!
            Installation directory does not have write permission.
            Please modify the installation directory attribute to allow to be written.)
            • hispeck
              • Aug 2015
              • 258
              • nigeria
              I opened through admin and I didn't get the error again, on the xgecu forum a new update 10.13 released today for T56 and TL 866ll plus
              • hispeck
                • Aug 2015
                • 258
                • nigeria
                Can TL 866 ll plus and RT809F use the same TSOP 48 adopter socket? Because I see in the update that TL 866 ll plus does NAND flash
                  • 31260
                  probably not, but you can try
                  • CapLeaker
                    Leaking Member
                    • 8342
                    some sockets are interchangeable others are not.
                    • CapLeaker
                      Leaking Member
                      • 8342
                      forgot to mention, that once the new program is installed, you have to flash the tl866 too.
                      • hispeck
                        • Aug 2015
                        • 258
                        • nigeria
                        how to flash bios with this tl866ll plus any guide
                        • CapLeaker
                          Leaking Member
                          • 8342
                          it is inside a new updated software. once the software runs, you have to flash the TL866
                          • hispeck
                            • Aug 2015
                            • 258
                            • nigeria
                            I tried to flash 25QJVSIQ after flashing the problem remain the same. The main board TP. RD8530. PB 816 . Is a china tv. Can someone please show me screen shoot of the TL 866ll plus I want to know if after installing the software there is settings to make before use. Because I flashed the ic and I saw the yellow light blinking while is flashing,
                            • hispeck
                              • Aug 2015
                              • 258
                              • nigeria
                              The tv is stuck on red light,
                              • hispeck
                                • Aug 2015
                                • 258
                                • nigeria
                                I checked the vcore 1.2 and 5v all present
                                • CapLeaker
                                  Leaking Member
                                  • 8342
                                  is your computer 32 or 64 bit?
                                  try uninstalling the old software, download a fresh copy then install the software on C:\Program Files (x86)\TL866
                                  • hispeck
                                    • Aug 2015
                                    • 258
                                    • nigeria
                                    system type 32 bit operating system, x64 based processor
                                    this is it
                                    • CapLeaker
                                      Leaking Member
                                      • 8342
                                      try it on a 64bit windows installation.
                                        • 31260
                                        the software works fine on 64bit Linux with wine btw.
                                        • japlytic
                                          DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
                                          by japlytic
                                          In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
                                          Tried (only with keyboard/mouse connected):
                                          • BIOS + database update
                                          • Using latest Windows 11 image built with official image creation tool
                                          • Previous setup version for Windows 11 installer
                                          • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
                                          • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
                                          • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
                                          06-19-2025, 04:59 PM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • sushilachuthan
                                          APC UPS error P13
                                          by sushilachuthan
                                          one of our new (only 4 year old) 1KVA APC UPS stop working and through error P13 contact customer support.
                                          the equipment is out of warranty , upon investigation, we found the inverter board has the fault on the output hybrid relay circuit.
                                          The inverter output relay is parallel by SCR/Triac to enhance the relay performance or other means.
                                          We replaced the SCR with new device,, but the device is not power on as expected.
                                          Further research on the issue found that, the error P13 (event ID 107) is latched on the UPS nvram/MCU and need to clear/reset using a service procedure....
                                          09-26-2025, 09:00 AM
                                        • giagiuf
                                          Lenovo W530 1802 Error when I install a new wifi card Intel AX210
                                          by giagiuf
                                          I will try to install an Intel AX210 chip in to my Lenovo W530 but i receive the 1802 Error, what can i unlocked BIOS and Whitelist removed?
                                          Please let me know as soon as possible.
                                          Best Regards,
                                          Giagiuf
                                          09-20-2024, 10:24 AM
                                        • Superbee_dad
                                          Sharp 80” long short flash backlight error - Help
                                          by Superbee_dad
                                          Hello Sharp TV experts
                                          Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                                          > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                                          > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                                          01-24-2025, 11:51 PM
