IBM PC compatible: Who still uses this term?
  • japlytic
    • Oct 2005
    • 2086
    An Analog Devices AD9833 datasheet from 2012 still makes use of the term "IBM PC compatible" which is no longer relevant considering that IBM sold its PC division to Lenovo in 2005.
    Who else is still using this term as of today?
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Re: IBM PC compatible: Who still uses this term?
    No very often unless your browsing on VOGONS and talking about the vintage machines and to what degree of compatibility the software required. I know depending on the manufacturer of the machine some computers failed to run many PC compatible software.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16958
      I haven't used the term since I sold the service center. That was circa year 2000.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8703
        it's not a big deal anymore because M$ strongarms any potential machine that could run windows. If it could run windows they force that computer maker to sell a copy of windows with it and ensure that it runs properly...
        Since it runs windows, there's no longer a "pc compatible" clause for computers. It's now "runs windows"...
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          No, but there's effectively such a clause; you don't tend to see OEMs adopting beige boxes in their PC-based product offerings (e.g., look at the cash registers at your local markets).
          • NotEnough
            Dell G15 5515 RGB Keyboard Not Detected (Compatible Keyboard, Possible BIOS/EC Issue?)
            by NotEnough
            I'm working on a Dell G15 5515 (Ryzen 7 5800H, RTX 3050 Ti) and recently installed a compatible 4-zone RGB keyboard and controller (for Dell G15 5510/5511/5515 models). While the keyboard functions for typing, the RGB lighting is not detected by Alienware Command Center (AWCC), which displays “No AlienFX devices found.”
            What I've Tried So Far:
            • Reseated the cables.
            • Reinstalled AWCC and AlienFX services.
            • Attempted BIOS downgrade but no improvement.
            • Inspected ribbon cables for damage.
            • Explored the possibility of BIOS or
            10-19-2024, 01:34 AM
          • Deby
            List of compatible laptop motherboards
            by Deby
            This is a list of compatible laptop motherboard information that I have been collecting for some time.
            And it's still ongoing.
            Every time I come across information that a board is compatible with another, I write it down.
            Anyone who wants to, can continue to expand the list.
            Packed in the rar, is an excel table that has additional information.
            Motherboards.rar...
            05-31-2024, 04:34 AM
          • m4a2t0t
            BD35231 compatible replacement
            by m4a2t0t
            Anyone know of a compatible replacement that has an adjustable output? The BD35230 has a fixed output of 1.0V and would be acceptable but I cannot find it anywhere. There is also the BD3523 which has an adjustable output but its also nowhere to be found. I could probably source them from alibaba but I dont have that much time and I dont want to make a huge order.
            Or perhaps you know how the BD35231 can be modified to output 0.95-1.0V? The board does have empty pads for an adjustable IC but Ive only been able to make the output go up.
            Thanks for any help...
            08-28-2025, 08:32 PM
          • taurtnt
            Help identifying AMCH073 regulator or finding a compatible replacement
            by taurtnt
            I’m trying to identify a step-down regulator marked AMCH073. It’s used on the PEX power rail of a graphics card. I can’t find any datasheet or info online.
            Here’s what I’ve observed:
            • It has a QFN-16 footprint, similar to NB670.
            • Pins 1, 2, 15, 16 are connected together and go to the inductor, so likely SW (switch node).
            • Pin 9 is connected to GND, which doesn’t match NB670 (where pin 9 is SW).
            • Pin 8 also seems to be tied to the same GND plane.
            • The chip only says AMCH073, no manufacturer logo or other markings....
            08-24-2025, 03:06 PM
          • zwect
            RTX 4060 Gigabyte Aero / FBVDDQ not switching on despite compatible IC swapping
            by zwect
            I got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...
            07-21-2025, 05:53 PM
