HP 15-bs038ur CSL50/CSL52 LA-E811P schematic needed
Re: HP 15-bs038ur CSL50/CSL52 LA-E811P schematic needed
Hello
https://drive.google.com/drive/folde...neRYQcZebsN96V
Use this for reference almost similar !!
Common to two three models !!
La-d707p | la-e801p | la-e811pLast edited by Aditya11ttt; 07-03-2020, 01:08 PM.Comment
LA-D707P has some differences, of LA-E801P use different ICs & mainly the 3V/5V is different, does not match with the LA-E801P physical circuit.. If someone can share the LA-E801P schematics, it would be very kind of them. ThanksComment
Currently not availableComment
hello
https://drive.google.com/drive/folde...neryqczebsn96v
use this for reference almost similar !!
La-d707p | la-e801p | la-e811pComment
LA-D702P its same.Attached FilesComment
HP Pavilion 15-BS 250 G6 Laptop Schematic
CSL50 CSL52 LA-E801P...-
Channel: Schematics and Boardviews
by ThetechdudeHi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
Thanks.-
by topwayHi guys, Gigabyte B650 GAMING X AX is NG, need schematic repair,
if anyone can share a schematic.
Thanks.-
Schematic needed (and boardview if available).
Thanks.-
Channel: Schematic Requests ONLY!
by knk2729dag3bembcd0 rev d Board view and Schematic needed for Non Graphic Conversion (DIS to UMA) as the Graphic chip is bad
- Loading...
