Sony kd 43w8307c stuck in screen test mode.
  • vikivng
    • Feb 2019
    • 228
    Hi guys,
    I got this tv without the original remote.
    I have the tried to hold power button on set for 30s to no avail.
    Vol down with power also.
    Have tried to update the software.Usb blinks for a few seconds then stops.
    Tv stays off until power is pressed.
    No change.
    Any help possible.?
    • 12323
    • U.S.
    Re: Sony kd 43w8307c stuck in screen test mode.
    Is the indicator light on the front a solid green til you turn it off??
      • 12323
      • U.S.
      Can you recheck model number to verify it is kd 43w8307c?
      • vikivng
        • Feb 2019
        • 228
        Hi,thnx for your replies.
        The indicator light is white on power on.
        Maybe thats the way it normally is,? not sure.
        Anyway, this morning I was trying a few combinations and now I can hear some kind of intro music playing.
        The tv responds to most keys volume etc but still cycling through the colors.
        I have seen a solution where the poster cleaned the lvds cables.
        Most people seem to have success exiting this mode without removing back cover so I am trying to exhaust all possibilities first.
        Im sorry its kd 43x8307c ..My apologies.
        • vikivng
          • Feb 2019
          • 228
          To answer your question,,yes the indicator light is solid (white) until it is turned off.
          I can hear menu option sounds when using the remote.
          But the colors keep cycling.
            • 12323
            • U.S.
            On the update using usb, you need to follow the procedure exactly as they instruct, maybe try a different usb stick if not successful with the first one, firmware and instructions are there, scroll down, read carefully, sometimes it doesn't take on the first try: https://www.sony.co.uk/electronics/s...loads/00016209
              • 12323
              • U.S.
              Try remove the power cord from the wall, then press and hold the power button on the TV itself (not the remote) for 20 seconds. Then plug the set back in and power it up.
                • 12323
                • U.S.
                Sometimes when tv does this and nobody was messing around with the service menu, it may be mainboard issue.
                  • 12323
                  • U.S.
                  Maybe a variation, like hold power button on tv while plugging in see if a display comes up then release power button, sometimes little variations of a procedure will work. If it does bring up a service menu, be VERY careful what you do in there, easy to brick a tv if change wrong settings, good idea to write down or take a picture of settings so they can be changed back if needed.
                    • 12323
                    • U.S.
                    It may be stuck in purity check mode, I got stuck in that mode once years ago and had a hellova time getting out, my own fault because I hit purity check in service menu, also had the solid color patterns like that on an older sony kdl which needed a firmware update to correct it.
                    • vikivng
                      • Feb 2019
                      • 228
                      ok,
                      could it also be the cables are dirty.? lvds? Is it odd that I can hear all the input sounds etc.?
                        • 12323
                        • U.S.
                        Yes, could try hitting those with some contact cleaner, maybe clean the tcon or ribbon cables going to the panel if no stand alone tcon, with isopropyl alcohol and a q-tip, never force off the connections they will come easily when released properly, just a warning for those that may not know, have seen some here ruin them by forcing them off by not releasing them correctly.
                        • vikivng
                          • Feb 2019
                          • 228
                          Ok,
                          regarding the update attempt,,the usb light flashes intermittently but the color cycle and music continues as normal.
                          Its as though the tv is working as normal in the background.
                            • 12323
                            • U.S.
                            Not sure about this one but my older kdl that just needed firmware update didn't have sound or anything just stuck in color patterns, you might have a bad capacitor or something on the mainboard??
                            • Dobsuk
                              • May 2020
                              • 127
                              • England
                              Can you upload some photo of the working screen?
                              • vikivng
                                • Feb 2019
                                • 228
                                here are some photos.
                                • vikivng
                                  • Feb 2019
                                  • 228
                                  Oops, I made the pics too small..
                                  • vikivng
                                    • Feb 2019
                                    • 228
                                    Hi again.
                                    third time lucky.
                                    The tv cycles through these colors full screen
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      the most likely source of the problem is "invalid conditions" on the cable between the main board and the tcon. Some sets have a "test mode" whereby you can jumper certain pins at the tcon connector to cause this type of mode / display (I believe some form of ground). Anyways, this sony had the same problem and the fix was to check the cable.
                                      https://www.badcaps.net/forum/showth...k+test+pattern
                                      I suspect you will likely find a similar result.
                                      • vikivng
                                        • Feb 2019
                                        • 228
                                        THNX alot budwich,
                                        I will do this and update for anyone also suffering this issue.
                                        thnx
                                        • Stunt
                                          Hp Laptop Stuck on Hp protected by hp sure start screen
                                          by Stunt
                                          Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                          I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                          I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                          Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                          screen that's it and stuck there. I left it until the following day and i still...
                                          09-02-2025, 01:51 PM
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • YellowJacket
                                          SHARP LC-32CHF5111K - stuck at color test mode
                                          by YellowJacket
                                          Hi friends,
                                          TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
                                          So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find...
                                          02-04-2023, 03:11 AM
                                        • BMCappelletti
                                          Lenovo Thinkpad E14 Gen3 stuck on "To interrupt normal startup, press Enter" screen
                                          by BMCappelletti
                                          Hi everyone.
                                          Lenovo Thinkpad E14 Gen 3, stuck on the "To interrupt normal startup, press Enter" screen.
                                          Found a lot of people with this issue, but with no definitive answer. Some people managed to get away accessing BIOS, going to Startup and turning off "Option Key Display". For me that only removed the interrupt normal start up message, leaving only the Lenovo logo.
                                          Most people say hitting Enter does not work. It's true, if you wait a few seconds. But if you hit Enter right away you get the options to enter BIOS (which works), run diagnostics (goes to a...
                                          02-18-2025, 12:22 PM
                                        • gigigi
                                          Panasonic tx-55cx802b stuck on panel test mode
                                          by gigigi
                                          Panasonic tx-55cx802b stuck on panel test mode.
                                          It was working normally but few days ago some of the LED reflectors fall off.
                                          I've opened it up carefully, re-glued, while it was open switched it on to test LEDs.
                                          Then carefully assembled back.
                                          After plugging in to power remote does not work.
                                          Using power button on the TV it turns on but gets itself into a panel testing mode: white, gradient, red, gradient, blue, gradient, green and so on switching between colours.
                                          Anyone knows how to get out of this panel testing mode?
                                          I've tried so...
                                          06-20-2021, 07:06 AM
