Hisense UB50CE591
  • greglogan
    • Jul 2020
    • 18
    • United Kingdom
    Hisense UB50CE591
    Hi guys
    I've been scouring the site looking for info on the above set. Here is my problem. The set powers up and you can see the Hisense logo followed by Smart. It's dim, but it's there. After that, the screen goes dark. I've checked the voltages on both LED connectors. One seems to hover around 120V until the power supply shuts down. The other is around 400V and then shuts down too.
    Are your suspicions LEDs or a power supply/driver issue?
    Appreciate any help you guys can give
    thanks
    greg.
  • neilc6
    • Nov 2015
    • 1550
    Re: Hisense UB50CE591
    You are describing the symptoms of bad backlights. You are 10x more likely to have bad backlights then a bad power supply though bad backlights can damage power supplies.
    • Diah
      • Feb 2013
      • 6647
      Originally posted by greglogan
      Hi guys
      thanks
      greg.
      you have shorted ONE LED BL
        Hi guys
        thanks
        greg.
        Show us good clear pictures of the whole backside of the TV showing all the boards, and good clear straight shots picture of the power supply board.
        Did you test the LED connector Voltage with ref to chassis GND?
        400V reading means the LED power supply is not seeing the load, you have open circuit in the LED string.
        • greglogan
          • Jul 2020
          • 18
          • United Kingdom
          Voltage tested across the PS outputs both times at XP901. It's strange because when I swap the connectors around, you can't see the logo on startup, so that's why I was thinking maybe Power Supply.
          Pic of the PSB attached. Really appreciate your help.
          • greglogan
            • Jul 2020
            • 18
            • United Kingdom
            Do you think one shorted and one open on different strings as the voltage is different?
            • Diah
              • Feb 2013
              • 6647
              NO, bl work as one circuit to shut down if one of them have issue
              • greglogan
                • Jul 2020
                • 18
                • United Kingdom
                I got this schematic from this site - it's not exactly the same, but it's pretty close. I thought the PS operated both LED strings separately, that's why i was getting different voltages.
                • Diah
                  • Feb 2013
                  • 6647
                  you have SOS shutdown.. both sockets of BL share same IC to control the currents of them.
                  • greglogan
                    • Jul 2020
                    • 18
                    • United Kingdom
                    Thank you so much. I'll get some LEDs ordered in the morning
                    • Diah
                      • Feb 2013
                      • 6647
                      they are 3030 6V
                        The LED drive Voltage is rated at 200V @400mA as printed right on the board, when no load the Voltage will jump high and trips the shutdown circuit.
                        So did you check the good LED in the Diode mode and tell us what you get in both directions?
                        • greglogan
                          • Jul 2020
                          • 18
                          • United Kingdom
                          Thanks @Diah
                          they are 3030 6V
                          • greglogan
                            • Jul 2020
                            • 18
                            • United Kingdom
                            Hi
                            I hadn't spotted the voltage quoted, so thanks for that. I'm gonna tear down the rest of this evening and I will report after that.
                            • jimbofz
                              • Apr 2013
                              • 539
                              im doing battle with one of these ,
                              see my post from a few days ago same model no led supply volts
                              ive ordered backlight drive/controller ic lx27901
                              as it measures 160 ohm to deck on pin 16 its on the print side of the board,
                              i think when the leds fail they can damage this ic ,
                              so it might be worth you checking yours these ics are only a few quid each
                              • greglogan
                                • Jul 2020
                                • 18
                                • United Kingdom
                                Jim
                                can you measure that resistance in circuit or did you de-solder?
                                • jimbofz
                                  • Apr 2013
                                  • 539
                                  Jim
                                  in situ is fine.
                                  as theres only a cap on this pin which could be responsible .in my case
                                  for me to confirm i de soldered just to be sure before i ordered ic
                                  this pin when tv working normally should have 5v on it and mine had .9v
                                  the 5v is generated inside the chip
                                  if you source any suitable leds please let me know where from , so i can also get some
                                  thanks
                                  • Diah
                                    • Feb 2013
                                    • 6647
                                    after take the defect LED need to take it in one piece so you can remark the chassis soldering pad of it. there are many 3030 but the pad are different.
                                    • jimbofz
                                      • Apr 2013
                                      • 539
                                      Jim
                                      hi did you measure pin 16 to deck?
                                      • nickgronk
                                        Hisense 55H6570F boots, loads then shuts down -
                                        by nickgronk
                                        I have a Hisense 55H6570F that gets the the boot loading screen for android and then shuts down. Oddly I hear a crackle on the mainboard as shown in the picture - nothing looks blown. The tv will boot every time, but when it reaches the loading statge of the anroid logo you can hear crackling on the board and it shuts down. What am I looking for (other than buying a new set) ? Inside the square is where I hear the crackling
                                        08-05-2024, 11:02 AM
                                      • chevellebbc@yahoo.com
                                        Static?? If I hover over the main board it shuts down
                                        by chevellebbc@yahoo.com
                                        Hoping for some newbie help. I had a tv in the basement for years that needed diagnosis. Finally got to looking at it. First was a backlight issue. Power supply checked out and replaced the led set. Then when the main board plugged it the backlights shut off. So pulled the main board tested as many components as possible and didn't find the culprit. So sourced an eBay one for cheap hoping it was something correctable. But now with the timing board unplugged the tv will start with backlights and stay on. However if I touch the ribbon it'll attempt to shut down. Now if I even hover my hand above...
                                        03-18-2023, 09:37 AM
                                      • tomketcz
                                        schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                                        by tomketcz
                                        Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                                        10-01-2025, 03:13 AM
                                      • Coolgoodman
                                        Faulty Hisense 85Q6NAU TV
                                        by Coolgoodman
                                        85” Hisense TV
                                        Greetings,
                                        Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                        Dear TV technicians of forum, I hope this message finds you well.
                                        I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                        I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                        07-24-2025, 03:02 AM
                                      • ShahZaib Ghumman
                                        Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                        by ShahZaib Ghumman
                                        Hey folks,
                                        I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                        A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                        So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                        03-25-2025, 10:59 PM
