best cheap/free scores 1.1
This is a sticky topic.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    #181
    Re: best cheap/free scores 1.1
    got 2 8d batteries free because while they are new they were tested bad by an idiot.
    they are dry charged.of course they will be dead till acid is added!
    • Toasty
      • Jul 2007
      • 4171
      #182
      SMOG!! Aren't they around $700 a piece??!!
      Polys coming soon
      Of course, now the weather breaks nice and now all I want to do is be outside working in the gardens. Just got done picking up a tarp full of crap from this last storm.
      veritas odium parit
      • weirdlookinguy
        • Sep 2007
        • 1638
        #183
        WRT54G v2.2... nice piece you've got there. Have you put DD-WRT on that yet? Also, what are those reflectors you put on the antennae? Might have to check that out for my WRT54G
        • Colt45ws
          • Jan 2009
          • 174
          Yeah, I put DDWRT on it as soon as I got it home.
          This is the antenna reflectors:
          http://www.freeantennas.com/projects...te2/index.html
          Those are standard size I had on it. Says 9dBm which is about what I got, maybe a little more. It was being used as a client there, so the fact that it made it pretty directional worked out fine.
          http://colt45.ws/misc/routermod.jpg
          OC'd it and cranked up the output power to 100mw.
            • 30979
            HP scanner was in the street last week!
            too bad the psu wasnt, but i got a 24v switcher, so i just need to pick up a 2.1mm power plug to see if it's good.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #186
              smog?
              new these things cost around $300.
              Polys coming soon
              • mockingbird
                • Dec 2008
                • 5484
                #187
                What are those weird proto yagis you have attached to the dipoles?
                • Colt45ws
                  • Jan 2009
                  • 174
                  The what?
                  • mockingbird
                    • Dec 2008
                    • 5484
                    #189
                    Those metal sheets you have attached to the antennas...
                    • Colt45ws
                      • Jan 2009
                      • 174
                      Printed it out and covered it with aluminum foil.
                      • NxB
                        • Feb 2009
                        • 1595
                        #191
                        nifty
                        • Toasty
                          • Jul 2007
                          • 4171
                          #192
                          Originally posted by kc8adu
                          smog?
                          SMOG = Sweet mother of god! - from 1998 Chris Farley, Saturday Night Live
                          ahhhh! 8D's in AGM or Gel are $700. gotcha!
                          veritas odium parit
                          • c_hegge
                            • Sep 2009
                            • 5219
                            For $30 I scored myself 3 motherboards. Only thing wrong with them is bad caps. I can get $50 each if I sell them in a refurbished PC at work, so it should be easy money. There is an Intel D865PERL, a D865GBF and a Lenovo thinkcentre motherboard. All seem OK so far after repairs. I even gave the D865PERL a poly-mod on the VRM and I'm stress testing it in Prime95 as I type this. The others got rubycons.
                            • ratdude747
                              Black Sheep
                              • Nov 2008
                              • 17136
                              lucky...
                              sigpic
                              (Insert witty quote here)
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Supermicro X7DAL-E for $24+ship.
                                Used these usually go for $200 and up.
                                http://www.supermicro.com/products/m...0X/X7DAL-E.cfm
                                Ad said it had a chip in PCB near CPU #2 implying CPU-2 might not work.
                                Asked for close-up photos and the chip was in the edge of PCB were it didn't affect any traces.
                                ~ Board runs fine with single or dual CPUs.
                                Dual skt 771 takes dual or quad core Xeons & 24GB RAM.
                                ATX Form Factor so fits standard cases.
                                Mann-Made Global Warming.
                                - Dr Seuss
                                • everell
                                  • Jan 2009
                                  • 1514
                                  Just got two freebie power supplies, Bestec ATX-250 12E. Both dead with 5vsb problems, but for me, an easy fix.
                                  I will use one with Abit KT7A which I have recapped. But can't check out my recap job because it doesn't have a cpu....yet. Anyone got a AMD socket 462 cpu running somewhere between 700 and 1000 Mhz?
                                  Got the first Bestec fixed by doing the DM311 mod. The original switching transistor was open, and I didn't want to damage anything further by trying to fix that 2 transistor circuit and creating a fireworks show!
                                  Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                                  • toastygoodness
                                    • Jul 2005
                                    • 813
                                    best ever.... gigabyte am2 ds3 amd 770 board + black edition athlon x2...
                                    got it because a friend wanted a new cpu and board. woot!
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      it may be a while until i can get it (at my old house), but i have a 1000mhz athlon t-bird that could be yours for the cost of shipping... i also have a 1300mhz duron t-bird in front of me... again, cost of shipping.
                                      sigpic
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        Got a hipro W700WC3 700W for $15. Pics to come soon. Thing is huge.
                                        • everell
                                          • Jan 2009
                                          • 1514
                                          The Abit board will take a cpu from 500 mhz to 1200 mhz, so the 1300 simply won't do me any good. When you can get hands on the 1000 mhz cpu, I am interested. Just pm me when you have it and I will send you some post money.
                                          • H34TO
                                            ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
                                            by H34TO
                                            Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
                                            06-17-2025, 07:17 AM
                                          • evilkitty
                                            When your mom is complaining about her new cheap lights
                                            by evilkitty
                                            My Mom bought some cheap motion sensor lights on wish... then complains about about batteries and this thing chews though them, well it uses 4 AAA batteries and a pack of rechargeable ones is about 13 USD
                                            well since it uses 4 AAA and rechargeable are 1.2v and non-recharge at 1.5 this thing must work with 4.8-6v, I'll shove a USB cable on it, infant i will use a broken phone charge cable... dam this thing uses 430 mA and they made it battery powered...
                                            lets ignore the fact that i thought the board fit both ways... and the wire color is reversed going to the board...
                                            07-23-2024, 01:27 PM
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • Dan81
                                            The Cheap Duo - Two SiS machines
                                            by Dan81
                                            Just as the title states. Two cheap SiS machines, surprisingly stable.
                                            What I will tackle in the near future (the build will be slightly postponed due to slight stomach issues - am still recovering and my physical power (sorry if it sounds weird,English isn't quite my primary language) isn't the best at the moment. Especially with the diet I have to take at the moment.) are two SiS based machines.
                                            The first one is a IPC rebranded Mitac 7521T. Why did I feel the need to tackle this machine? Well, just look at the specs:
                                            CPU - P3 1100MHz Coppermine...
                                            04-16-2022, 12:28 PM
                                          • akwky
                                            by akwky
                                            Hi!
                                            04-14-2025, 01:56 PM
