the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • Pentium4
    CapXon Be Gone
    • Sep 2011
    • 3741
    Re: the gutless, bloated, and fried power supply hall of shame
    Pulled this PSU out of an old Pentium 4 Dell Dimension with 36,000 running hours on it. Was pretty dusty. Cleaned it and discovered some dead Teapos. The primaries are both bulged and one on the secondary is bulging a fair amount. I thought that plastic caps on the top of the primaries were just curved up but when I push on them, there is pressure so they don't move down at all. Not really worth repairing? It's pretty weak. Only 12A on the 12V...
    Doesn't look like the secondary could get much airflow, especially with how dusty it was before I cleaned it out.
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      #182
      Looks like a HiPro - those are always worth repairing. With good caps, it will probably last forever. Just make sure the fan didn't get or isn't becoming seized.
      The dust in the primary side actually indicates that there was a lot of airflow in there. The primary caps most likely died because of the heat generated after the dust accumulation. 360 000 power-on hours is quite a lot. I would actually be surprised if the fan is not running dry by now.
      But yes, definitely fix it.
      • Shocker
        Banned
        • Dec 2011
        • 635
        #183
        Yes it is. That's 41 years.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4950
          • New Zealand
          #184
          Quite right, but the original figure was 36,000 - only 4.1 years
          -David VanHorn
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            #185
            Oops.
            This is proof that lack of sleep isn't good for you. In my case, I've been up until 4am almost every night for the last few months, so today (actually yesterday), I decided to fix that by staying up all night. So let's see how that goes. 21 hours uptime so far. Or is it 210 hours .
            • Pentium4
              CapXon Be Gone
              • Sep 2011
              • 3741
              Hahaha, 210 hours that'd be a long time. I'll think about replacing the caps, it'd do fine in a HTPC or something. I haven't tested to see if the fans spins. And you're right, this thing does look just like the inside of my Hipro from a Gateway I bought in 2007, except the newer one Has Elite caps on the primary
              • mockingbird
                • Dec 2008
                • 5484
                #187
                I have a Deer PSU here labeled as "550W MAX"...
                I have a few of these in computers that are getting their motherboards re-capped (ASRock AM2 boards that oddly have 20 pin ATX connectors)... Is it economically feasible to repair these PSUs and does that just entail changing the caps?
                • mockingbird
                  • Dec 2008
                  • 5484
                  #188
                  Here are some better pics:
                  This one is 244KB, so I am attaching it rather than posting it in-line.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    • Romania
                    #189
                    That PSU is a pile of rubbish. I don't even give it 200W in spec, and that would be with good caps. Just look at the tiny transformer (EI-28, not even 33), tiny inductors, and missing pi filter coils.
                    A working TV? How boring!
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Actually, it looks like a low end CWT.
                      • mockingbird
                        • Dec 2008
                        • 5484
                        #191
                        200W is more than enough... I think even 150W would be fine... These are being used on AM2 Semprons with a 59W TDP.
                        So if I change the caps, would these be reliable (taking into account the fact that they're missing basic input protection)? It's just not practical to spend $30 on 300W Fortron Sparkle PSUs for these systems which don't even need a 24-pin connector.
                        I checked the Underwriters Laboratory Database... They say it's a Deer.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          It needs both caps and PI coils to make it usable... Personally I would look for some used newton/delta units. These PSUs that you have, frankly, suck.
                          sigpic
                          (Insert witty quote here)
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Compare the OKIA on the HWI El cheapo PSU roundup (http://hardwareinsights.com/wp/2011/...-round-up-2/9/). That PSU you have won't do anything at all with the ripple in spec. It is absoloutely practical to spend $30 on a decent PSU on ANY system.
                            • Pentium4
                              CapXon Be Gone
                              • Sep 2011
                              • 3741
                              And for the record, what are the brands of those caps? That looks like my old Okia that I had. I did the world a favor and dunked it into the trash can with force.
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #195
                                Wow, almost exactly the same... Mine has two more coils, on both sides of the heatsink and one pi-filter coil, for what I think is the 3.3 line.
                                Mix of Koshin, Teapo, and Fuhjyyu.
                                • Scenic
                                  o.O
                                  • Sep 2007
                                  • 2642
                                  What series is that weird orange Teapo?
                                  The ones I'm familiar with are dark green, brown or black, with some old/obsolete series (SX and SD for example) being baby blue.. but orange?! I've never seen them use that color before
                                    master hoarder
                                    • May 2008
                                    • 12170
                                    • Bulgaria
                                    #197
                                    That's because it is.
                                    Yes, but it's not. I have 2 of these PSUs - one is a CyberLink CWT-320ATX with UL number E133653 (which leads to REAL POWER ENTERPRISE CO LTD) and the other unit is a TurboLink LC-A420ATX which has UL number E164554 (leading to L&C - aka Deer). But I can tell you for sure that this is not a Deer/L&C. They are both low-end CWT as c_hegge noted.
                                    One easy way to spot and distinguish these PSUs from others is by the QC sticker. Note how it has ink stamps indicating that it passed the various stages of QC rather than just a simple "QC Pass" sticker that most cheap PSUs use. If anything, CWT does probably have good QC. What brings these PSUs down is their lack of guts. With good parts, they can be decent.
                                    Umm, no, not exactly - at least not this power supply. You'll have to look at the 12v rectifier before deciding this. On my Turbolink, the 12v rectifier is rated for 10A, so it actually might work... of course it won't, because the caps for the 12v rail consist of only a single 16V 680uF Fuhjyyu TMR - that's barely enough to filter ripple for a hard drive. Running even a 40W TDP CPU off of that will result in serious stress to the motherboard's capacitors.
                                    And if you think this doesn't get worse - it does. The Cyberlink I have only has 2x 3A FR diodes for the 12V "rectifier" (read: diodes-on-a-bracket).
                                    Despite all of that, I will admit that these PSUs are engineered fairly well. The 2-transistors 5VSB aside, they actually do have SCP, OVP, and UVP. Moreover, their voltage regulation is quite good. I pulled the Cyberlink from a PC with a ECS P4VXASD2+ motherboard and a 64W TDP Pentium 4 CPU. Judging by the dust, it was powering that system for probably at least a year or 2. The only reason it survived, however, is because that motherboard powers the CPU from the 5V rail rather than the 12V rail and the 5V rail had a 15A rectifier (so a total of 75W max). The darkened PCB under the 5V rectifier confirmed this.
                                    Since the voltage regulation on these PSU is quite good, I'm currently using my TurboLink as an electronics test PSU. I'm actually planning on recapping it with "better" caps (read: not-yet-failed junk caps).
                                    That would be a Fuhjyyu TNR.
                                    *EDIT*
                                    Oh wait, never mind. I now see it has a Teapo vent and says Teapo on it.
                                    I have the same exact orange cap in my Turbolink in the same exact location and it's a Fuhjyyu TNR.
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      #198
                                      Momaka, thanks for your intuitive input... I am strongly leaning towards re-capping these units, but now that you have brought the issue of the anemic 12V line, I'm reconsidering.
                                      Am I right in assuming I'm looking at the three TO-220 packages on the secondary side? Here are the markings:
                                      1) STPR1020CT
                                      2) STPS1545CT
                                      3) STPS1545CT
                                      Looking at the datasheet for the STPS1545, it's a 15A part... The datasheet for the STPR1020CT says "2 x 5A", is this my 12V rectifier!?.
                                      Tracing back the 12V circuit, yes, I see that I've got that same Fuhjyyu TM 16V 680uF cap which obviously is filtering it alone because the coil is missing for the pi filter...
                                      Ok, ok, you're starting to convince me... Let me ask you this... Let's say I switched the 16V 680uF cap with some nice, highly rated 10mm cap with a higher capacitance (Or should I stick to the same capacitance), would this help me any?
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        #199
                                        Yes.
                                        Do yourself a favor and junk them already. I have at least one unit from almost all low-end ATX platforms lying around, and the one you have is the worst. I wouldn't trust that even with a Sempron. Especially if the motherboard happens to have Chemicon KZG or OSTs...
                                        • mockingbird
                                          • Dec 2008
                                          • 5484
                                          #200
                                          You're right... I'm going to buy some Sparkles for these machines or maybe use the ones I have that need re-capping...
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
