HP BIOS unlock tool
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    #201
    Re: HP BIOS unlock tool
    I take them from junk motherboards. Have had bad experience when I ordered 10 new ones from ebay. Only 1 of them worked.
    • CornholioGSM
      • Feb 2014
      • 265
      • CZECH
      #202
      ...it works 820 G2 unlocked with ch341 / asprogrammer ...was needed to add file extension .bin
      • quidep
        • Apr 2020
        • 19
        Could you please tell what you did exactly?
        • RethoricalCheese
          • Mar 2013
          • 1519
          • Estonia
          #204
          guidep, your issue is with reading/writing. It has actually nothing to do with my unlocker.
          His issue was that he had the file name lockedbios.rom and had to rename it to lockedbios.bin for it to work.
          But to think of it... That *.bin restriction was unnecessary. It was added just because I always have used .bin extension and not .rom or anything other.
          • slaine
            • Feb 2020
            • 21
            • germany
            #205
            Hi, got another 840G3 where the HPUnlocker is not working. Guess the location is again stored in two different places. @RethoricalCheese - do you mind posting the clean vss-section as file, so i could put them in via HxD? Image original and unlocked is attached
            @RethoricalCheese - got it working i used the userCred section from the previous one you patched for me. If you look at both files, there is a section with alot of numbers in UserCred, you unlocker did not remove those. As i removed this section via HxD it worked. Maybe this is something you want to look into for future HPUnlocker updates
            Block B1908C-B190C8 // 00B19170 // 00B19200
            • RethoricalCheese
              • Mar 2013
              • 1519
              • Estonia
              #206
              Yes, I am aware of the problem. It is just that mostly that section is not like yours is. I have unlocked maybe a thousand HP-s and never had one like you have.
              Since I am working on another unlocker (which takes only a second or two to read, unlock and write), I will redo the unlocking part when I get to that point.
              • 50jaker
                • Apr 2020
                • 19
                • Spain
                #207
                Hi @RethoricalCheese, I have a question, I have an HP Probook 6470b but it has two users in the bios locked by password, I only know the password of one them, but unfortunately the Bios Administrator I have no idea... I bought it in that state 5 years ago, I would like to know if in this state your tool can unlock the bios administrator but having an extra user in the bios.
                • RethoricalCheese
                  • Mar 2013
                  • 1519
                  • Estonia
                  #208
                  It shouldn't be a problem. Just unlock using this tool and then when you get to bios you can reset security settings aswell to be sure everything is removed.
                  • gpu
                    • Jan 2015
                    • 12
                    • Ukraine
                    #209
                    Hello My laptop HP zbook 14u G6. Using 866II Plus. Read dump, use utility have file ...._unloked after prorramming password no clear... Help me pleace
                    • RethoricalCheese
                      • Mar 2013
                      • 1519
                      • Estonia
                      #210
                      Probably just too new and something has changed. I don't have such a new laptop to try anything on.
                      • peste
                        • Dec 2016
                        • 13653
                        • ROMANIA
                        #211
                        try
                        • gpu
                          • Jan 2015
                          • 12
                          • Ukraine
                          #212
                          Originally posted by peste
                          try
                          Bios Administrator Password present! Password in main bios or ec?
                          • RethoricalCheese
                            • Mar 2013
                            • 1519
                            • Estonia
                            #213
                            Such a new PC. Don`t know about it yet.
                            Won't HP help you out using proof of purchase?
                            • gpu
                              • Jan 2015
                              • 12
                              • Ukraine
                              #214
                              No, but bye laptop with ebay, used...
                                • 21968
                                32 months remaining on the warranty.Didn`t the seller transfer it .
                                • gpu
                                  • Jan 2015
                                  • 12
                                  • Ukraine
                                  #216
                                  Im living in Ukraine laptop from Denmark. Im using laptop everyday. .. everyone help me?
                                  • Claudiomfa
                                    • Nov 2015
                                    • 455
                                    • Portugal
                                    #217
                                    Try this repaired file and tell us if work
                                    • gpu
                                      • Jan 2015
                                      • 12
                                      • Ukraine
                                      #218
                                      Working but password present! after programming bios shows Restoring bios. One queshions - password in main bios or in firmware EC?
                                      • Claudiomfa
                                        • Nov 2015
                                        • 455
                                        • Portugal
                                        #219
                                        You can make a EC backup from your laptop?
                                        • gpu
                                          • Jan 2015
                                          • 12
                                          • Ukraine
                                          #220
                                          EC bios
                                          • salim5566
                                            loking for bio tool that hve all feature like ps5 bios and laptop bios unlock and repair 1 tool can do all please good tool?
                                            by salim5566
                                            Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
                                            06-26-2025, 03:25 PM
                                          • to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                            by to5it0
                                            Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                            I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                            This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                            I have opened the laptop and identified the main BIOS chip...
                                            10-24-2025, 01:35 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • Citymin
                                            NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
                                            by Citymin
                                            My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
                                            The charging red LED lights up, but the charging screen doesn't show any indication.
                                            When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
                                            (I've tried removing the battery and resetting the device, but the issue persists.)
                                            NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
                                            PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
