ESR meter upgrades
This is a sticky topic.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #201
    Re: ESR meter upgrades
    Yes
    For the extra money i wish i ordered this now
    http://www.ebay.co.uk/itm/2221248490...%3AMEBIDX%3AIT
    if i get a refund for my kit i will purchase one of these then i can send the values too you etc.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      #202
      Cheers!
      Do note that the original seller you bought from (At least the one you linked to originally)
      Also sells it assembled.
      So he really should be able to get you either a schematic or at least a picture of it assembled
      http://www.ebay.com/itm/2016-EZM328-...-/331800111900
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #203
        Cheers!
        ive emailed the seller a few time all he says in the return messages is "so you cant weld this" i think he means solder it and he has no schematic ive asked twice and to confirm one of yesterdays post i made
        sorry about the confusion (was one of those days yesterday nothing went rite) i misscounted the ebay picture and now just re checked the kit all again yes there are 24 spots on my pcb and 24 resistors fitted on the ebay picture yes just counted ny resistors again 23 plus 1 zero ohm (which isnt shown in any ebay pictures) but without any schematic im still stuck anyway.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          #204
          Ok, incase you did not notice the picture in his eBay AD is not of the item he sells.
          They are watermarked "kiss_buy".
          That seller does have the same meter for sale, search for "ESR 2016" in his eBay store...
          • GoNz0
            • Sep 2012
            • 28
            • United Kingdom
            #205
            I hope the banggood kit has instructions!
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #206
              Thanks i have just noticed that too.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                #207
                which kit did you go for have you got a link.
                • GoNz0
                  • Sep 2012
                  • 28
                  • United Kingdom
                  #208
                  http://www.banggood.com/DIY-M12864-G...-p-997023.html
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    • uk
                    #209
                    if you look really closely at the pcb you can see it has the parts printed on it so your fine with that kits thats a good price too i keep forgetting about that site.
                    • GoNz0
                      • Sep 2012
                      • 28
                      • United Kingdom
                      #210
                      Good point!
                      Thanks.
                        • 31284
                        post pics of both sides of the pcb that are good enough to see all the tracks clearly.
                        i'll work it out for you.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #212
                          stj if you mean mine i will post some asap as light here at the minute is too bad too take any good ones, so bear with me thanks.
                            • 31284
                            i almost finished the pcb stuffing list,
                            verify something for me.
                            x2 110 ohm
                            x1 5.6k
                            are you sure about those - specially the 110ohm - is it actually 1k?
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              #214
                              x1 5.6k measures 0.56 on 20k scale
                              x2 110 ohm measure 1k my mistake sorry
                              x1 2.2k is 2.2k (im not sure if i wrote this as 2.2ohm)
                                • 31284
                                wouldnt .56 be 560ohms?
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #216
                                  Resistor colour GREEN BLUE BLACK BLACK BROWN cheers for your help stj just checked using hobby -hour calculator 560 ohms
                                    • 31284
                                    thought so.
                                    in that case - go build it!
                                    r1 - 680r sensing circuit
                                    r2 - 470k sensing circuit
                                    r3 - 680r sensing circuit
                                    r4 - 470k sensing circuit
                                    r5 - 680r sensing circuit
                                    r6 - 470k sensing circuit
                                    r7 - 10k reset pullup
                                    r8 - 33k power control
                                    r9 - 3k3 power control
                                    r10 - 27k
                                    r11 - 100k (says r1 but is next to r10)
                                    r12 - 10k voltage divider for battery sense
                                    r13 - 3k3 voltage divider for battery sense
                                    r14 - 560r display related - led current limit
                                    r15 - 27k
                                    r16 - 0r jumper for AVCC
                                    r17 - 2k2 from tl431 to vcc
                                    r18 - 1k rotary encoder current limit
                                    r19 - 1k rotary encoder current limit
                                    r20 - 10k rotary encoder pullup
                                    r21 - 10k rotary encoder pullup
                                    r22 - 470r frequency input dropper
                                    r23 - 10k frequency input voltage divider
                                    r24 - 10k frequency input voltage divider
                                    rv1 - 10k preset frequency input voltage divider
                                    u3 = tl431
                                    q1 - 4673 (bc557c)
                                    q2 - c945 (bc547)
                                    q3 - c945 (bc547)
                                    c1 - 22pf for crystal
                                    c2 - 22pf for crystal
                                    c3 - 100nf
                                    c4 - 10nf
                                    c5 - 10uf 16v
                                    c6 - 10uf 16v
                                    c7 - 100nf
                                    c8 - 100nf
                                    c9 - 100n frequency input DC blocker
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #218
                                      thought so.
                                      r10 - 27k
                                      r15 - 27k
                                      u3 = tl431
                                      q1 - 4673 (bc557c)
                                      q2 - c945 (bc547)
                                      q3 - c945 (bc547)
                                      c3 - 100nf
                                      c4 - 10nf
                                      c5 - 10uf 16v
                                      c6 - 10uf 16v
                                      c7 - 100nf
                                      c8 - 100nf
                                      Big thanks for your help stj i wont be able too get back too this project untill early next week as going down the coast to visit dad (fathers day) suprise etc if weathers nice may spend a few extra days but will update this thread when built.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #219
                                        sorry i forgot too post this yesterday
                                        c5 and c6 are 100uf 25 volts in the kit
                                        then i have x4 104j
                                        x1 103j
                                        cheers again stj for your help
                                          • 31284
                                          16v was a minimum figure,
                                          104 = 100nf
                                          103 = 10nf
                                          • chth96
                                            Is it possible to test small ceramic disc capacitor with analogue meter?
                                            by chth96
                                            I read EBOOK of Testing Electronic Component and found that
                                            "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                            Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                            It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                            Is it really possible to test small ceramic disc capacitor with analogue...
                                            03-09-2024, 10:03 PM
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            Changing the scale of an analog meter
                                            by jorpec
                                            Hi
                                            I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                            I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                            by sam_sam_sam
                                            About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                            Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
