List of pin compatible Laptop ICs
This is a sticky topic.
  • String2016
    • Nov 2015
    • 2238
    • philippines
    #241
    Re: List of pin compatible Laptop ICs
    can i replace RT8205B with RT8205C?
    • peste
      • Dec 2016
      • 13436
      • ROMANIA
      #242
      with the changes from pin 18 and 19 I think it works..
      TPS51125= RT8205B
      • eng.umair.a
        • Jun 2016
        • 79
        • Pakistan
        #243
        Tested 100% working SYX196BQNC=SY8206BQNC
        • zedameo
          • Jan 2019
          • 14
          • algeria
          #244
          thank you it worked with dell 3521
          • spleenharvester
            • Mar 2010
            • 921
            I have what I believe is an NCP511SN25T1G, which is a 2.5V output LDO in a SOT-23-5 package - is this interchangeable with either an ADP151AUJZ-2.5-R7 or a TLV70025DDCT by any chance?
            Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
            • spleenharvester
              • Mar 2010
              • 921
              Just a follow up, I fitted the ADP151 today and it seems to be working absolutely fine.
              • dmartins
                David M
                • Apr 2014
                • 197
                • Lisbon
                #247
                4957agm Any compatible mosfet?
                • sameera
                  • Aug 2012
                  • 10
                  • sri lanka
                  #248
                  Does any one know compatible for BQ738H ?
                  I have BQ738. are they same?
                  • mastsrl
                    • Apr 2019
                    • 38
                    • Argentina
                    #249
                    Originally posted by kadi144
                    can i use a TPS51216 or BQ 727 as replacement of TPS 51716 in DELL INSPIR0N 15-3000
                    i don't think so, whilst they're pin-compatible, the mode pin takes completely different resistors (i'm having this exact same issue), since 51716 can control up to DDR4 and has much higher switching freq. (500 to 670Khz) whilst 216 goes to 400Khz
                    • lezsimply
                      The Wanderer
                      • 657
                      • Philippines
                      #250
                      Good day does anybody know what ic represents 5x=5j s8n labeled on top? tried searching net, empty handed. Dont have schematic for this hp slimline. Thanks.
                      • lezsimply
                        The Wanderer
                        • 657
                        • Philippines
                        #251
                        Ok I got it now sorry for lazy researching its a RT6575D. Thanks
                        • lezsimply
                          The Wanderer
                          • 657
                          • Philippines
                          #252
                          Guys any other compatible with this ic?
                          • LightMad
                            • Jun 2019
                            • 56
                            • cameroon
                            #253
                            Originally posted by highpulse
                            51123 can be replaced by 51125
                            No
                            • Badcaps.netforum
                              • Aug 2017
                              • 8
                              • Peru
                              #254
                              max17020=isl6236
                              • Zibbo
                                • Mar 2017
                                • 203
                                • Zimbabwe
                                #255
                                I have a Lenovo Flex 2 (14D) with a burnt NPCE285GA0DX EC chip and I have a spare NPCE285PA0DX. Are these chips compatible?
                                • Discrete47
                                  • Feb 2019
                                  • 22
                                  • Pakistan
                                  #256
                                  CD3301BRHHR_QFN36 dell Latitude E7440 charger ic replacement ????
                                  • orientalsniper
                                    • Apr 2013
                                    • 461
                                    What is compatible with APW88688 / APW 88688 ?
                                    • ravi_1617
                                      YY Solutions
                                      • Jan 2012
                                      • 348
                                      • India
                                      #258
                                      Any compatible for AMD 216-0752001,
                                      • Zibbo
                                        • Mar 2017
                                        • 203
                                        • Zimbabwe
                                        #259
                                        Is MEC1300-NU compatible with MEC-1310-NU? I can't find the datasheet or the pinout of either.
                                        • myth77
                                          • Feb 2017
                                          • 380
                                          • Croatia
                                          #260
                                          can someone confirm is G5244T11U and SY6288C20AAC interchangable?
                                          • Deby
                                            List of compatible laptop motherboards
                                            by Deby
                                            This is a list of compatible laptop motherboard information that I have been collecting for some time.
                                            And it's still ongoing.
                                            Every time I come across information that a board is compatible with another, I write it down.
                                            Anyone who wants to, can continue to expand the list.
                                            Packed in the rar, is an excel table that has additional information.
                                            Motherboards.rar...
                                            05-31-2024, 04:34 AM
                                            Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                            09-06-2024, 09:30 PM
                                            Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-06-2024, 08:47 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                            Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                            This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                            09-07-2024, 06:11 AM
