Panasonic CF-54 Bios Password
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    #261
    Re: Panasonic CF-54 Bios Password
    Originally posted by lenovo270
    I reviewed it.
    It wasn't loading properly.
    What about this?
    Looks good.
    Below is your unlocked dump, try it and let me know:
    Become a Badcaps supporter
    Thanks to all supporters.​
    • lenovo270
      • Mar 2023
      • 11
      • japan
      #262
      Originally posted by Vesko356
      Looks good.
      it is perfect
      donated
      • Vesko356
        VIP Moderator
        • Aug 2018
        • 4386
        • Bulgaria 🇧🇬
        #263
        it is perfect
        donated
        Great!
        I appreciate you joining in and donating the forum in this difficult situation!
        • lenovo270
          • Mar 2023
          • 11
          • japan
          #264
          Great!
          please help me if I'm in trouble again
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            #265
            Sure, I'll be happy to help again if needed.
            Cheers
            • Sudam ouellet
              • Apr 2023
              • 4
              • canada
              #266
              Hi
              I am trying to remove the supervisor password on this bios, but normally the password should be at 2 places, but I find like 6 places where the password seems to be.
              Beginning by 5B 13 B6 9F11 69 6C
              Thanks for any help
              • peste
                • Dec 2016
                • 13661
                • ROMANIA
                #267
                Originally posted by Sudam ouellet
                Hi
                Thanks for any help
                try..
                • Sudam ouellet
                  • Apr 2023
                  • 4
                  • canada
                  #268
                  It did not work but after removing all the instance of the password it did work, but there is a section for Optional kit configuration still locked any advice on this
                    • 21986
                    https://www.badcaps.net/forum/showth...on#post1049861 .Not sure how to remove it,perhaps flashing another bios that doesn`t have the hardcoded password in it.
                    • Sudam ouellet
                      • Apr 2023
                      • 4
                      • canada
                      #270
                      Ok
                      The password is "toughkit" not much setting in the menu
                      So the bios is unlocked now thanks.
                      I was trying to upgrade the Wi-Fi card but the bios, I guess seems to block the new card. any info on that you are aware of?
                      • Sudam ouellet
                        • Apr 2023
                        • 4
                        • canada
                        #271
                        Ok
                        I have found a workaround if someone want to upgrade their Wi-Fi card I followed this guide to mask off 2 pins (54 and 56) on the new card, so the computer can't send the off signal to the card the Wi-Fi card. The Wi-Fi light is off, but the card work.
                        I installed an Intel ax210 WiFi6e
                        https://thecomputerperson.wordpress....-pin-20-trick/
                        • imran421
                          • Apr 2020
                          • 83
                          PLEASE help me in unlocking the bios paswsword.
                          bin file attached
                          • Vesko356
                            VIP Moderator
                            • Aug 2018
                            • 4386
                            • Bulgaria 🇧🇬
                            #273
                            bin file attached
                            Here you are:
                            • imran421
                              • Apr 2020
                              • 83
                              no go. powers on and shut down right away
                              • Vesko356
                                VIP Moderator
                                • Aug 2018
                                • 4386
                                • Bulgaria 🇧🇬
                                #275
                                Give me a break - no way, check the soldering or orientation of the chip to the motherboard, or if you using ch341a with the clip verify the content of the chip.
                                • imran421
                                  • Apr 2020
                                  • 83
                                  My apologies. Bin file was not correct. Can You please fix this one. Thousand apologies to waste your time.
                                  • Vesko356
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    #277
                                    "...shut down right away" huh?
                                    • imran421
                                      • Apr 2020
                                      • 83
                                      it worked this time and donated as well.
                                      • Vesko356
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        #279
                                        Well done!
                                        Thank you for your support, appreciate it.
                                        • gandalffoogray
                                          • May 2023
                                          • 4
                                          does any one have the bios file for the CF-54FX.
                                          • outsider
                                            Panasonic FZ-G1 MK5 - BIOS password returning
                                            by outsider
                                            Hello
                                            I removed the BIOS password thanks to the help of one of the friends of this forum.
                                            https://www.badcaps.net/forum/troubl...61#post3637661
                                            The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...
                                            06-17-2025, 12:51 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • traxformania
                                            TONGFANG "GM7TG7P" Bios Password Problem?
                                            by traxformania
                                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                            I'm trying to reset my bios without success.
                                            I tried :
                                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                            11-15-2023, 07:32 AM
                                          • longmt1990
                                            Panasonic Cf-w5 bios password remove
                                            by longmt1990
                                            Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
                                            I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
                                            Please help me remove bios password.
                                            Thank you so much
                                            07-06-2025, 10:50 PM
                                          • Nopslide
                                            HP Omen 15-dh0052nf power-on & bios password
                                            by Nopslide
                                            Hello everyone, I come here to tell you my problem regarding the power-on password. It is not a bios reset demand, and i can't have any access to windows. This is the bios and power-on password that is blocking all other things.
                                            My Omen 15-dh0052nf purchased second-hand was configured with the bios password upon purchase (very simple password :P ).
                                            Having decided to sell it in order to get something more powerful, I reset all BIOS settings and set a blank administrator password. But the power-on password cannot be changed to a blank one so I let the actual password set....
                                            04-01-2024, 04:27 PM
