the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • japlytic
    • Oct 2005
    • 2086
    Re: the gutless, bloated, and fried power supply hall of shame
    This morning when I was at my computer, I heard a hissing sound and thought it was my monitor (which appears to be on its last legs), but I found out that it was a plugpack, DVD model DSA-0131F-05 and upon opening, a bulging 22uF 400V Jamicon TK (105C) unit was found.
    The particular unit is of the self-oscillating type, secondary capacitors are 680uF 10V Jamicon WG (before and after output inductor), and as in the picture, the fuse is crossing the secondary side, even though it has heatshrink on it.
    Has anyone else seen a bulging 400/450V Jamicon unit, especially if it is on the primary side?
    • Behemot
      • 4845
      • CZ
      #362
      If it is cooking itself in its own juices, than it is no surprise it has gone bad…how long was it working?
      • japlytic
        • Oct 2005
        • 2086
        Honestly, I have no idea.
        I meant DVE, not DVD.
        • ben7
          Capaholic
          • Jan 2011
          • 4059
          Ah yes, I have a few DVE brand adapters. I think all of them are transformer based, not SMPS.
          Did the hissing come from the capacitor exploding?
          You should blow up the capacitor :P
          -Ben
          Muh-soggy-knee
          • Pentium4
            CapXon Be Gone
            • Sep 2011
            • 3741
            Here's a delicious Deer for you guys to admire In these, when the sleeve bearing fan dies, they ALWAYS keep running until the switching transistors blow. I've seen 6 of them die and it's the switchers every time, as well as all the YC caps bulging
            • Wester547
              • Nov 2011
              • 1268
              • USA.
              #366
              Damn... that's a 28 size transformer there. Talk about pathetic....
              On the other hand, many PSUs don't have over temperature protection, in all fairness, so they too continue to run when a fan seizes. But if the switchers die from a seized fan if you're not even running the PSU at even half its capacity then they must be pathetic as well.
              • Behemot
                • 4845
                • CZ
                #367
                Is the label 350 W at least?
                I just hope thats B0S, not BOS on the transformer, if Brotherhood of Steel made such a crap, that would ruin all my belief in them
                • Pentium4
                  CapXon Be Gone
                  • Sep 2011
                  • 3741
                  Yeah it happens to these things a lot The label claims 250W. 192W on the 12V. Looks like B0S
                  • Behemot
                    • 4845
                    • CZ
                    #369
                    Thats not bad, it even looks it can do 200 W continuous, 250 W maybe. Expected more generous label
                    • goodpsusearch
                      • Oct 2009
                      • 2850
                      • Greece
                      #370
                      They are getting better.
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        They definitely are getting better. They need to at least put a ball bearing fan in there though. And fix the fan controller. The fan spins at the same speed at <50W as it does when it's pulling over 150W and it starts to get pretty hot.
                        • Behemot
                          • 4845
                          • CZ
                          #372
                          Well it's not so surprising after all, you can get 550W OCZ ZS with 80+ bronze certifications for some 55 USD…
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            That's pretty good. Here is the exact PSU on Newegg, overpriced if you ask me. http://www.newegg.com/Product/Produc...Power-Supplies
                            • Behemot
                              • 4845
                              • CZ
                              #374
                              Ah, it's SFX than? These are generally pricier…
                              • PeteS in CA
                                • Aug 2005
                                • 3579
                                • USA, Unsure of Planet
                                #375
                                Looks like B0S
                                Maybe POS, Piece Of ...
                                I would guesstimate it at 150W-200W. Wasn't 185W common in that case size? It actually has an input filter on the AC side. OTOH, the O/P caps are all extra well done!
                                PeteS in CA
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Hahaha I actually have one being used for a linux box (requires around 100W continuous, around 160W under load) I recapped it and put a ball bearing fan in there. Just to see if the little bugger can last with a little upgrade
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #377
                                    It's actually pretty tough to get something usable in SFX factor, at least here. Everything is expensive and the best thing you can usually buy is something from FSP Group, full of crappy caps anyway.
                                    • ttn328
                                      • Jan 2011
                                      • 12
                                      • Vietnam
                                      #378
                                      VENR (fake ?) 450S-ATX
                                      No EMI filter. Primary caps : Fhy 330uF - 200V x2 85C
                                      Two transistors 5VSB: C945, D13003
                                      Main switcher: D13007 x2. Very small main tranformer.
                                      Secondary:
                                      Rectifiers: S16C40C x2, F12C20C. No pi filters.
                                      DC filter caps: 1000uF - 16V x3 , 470uF - 16V, 1000uF - 16V (5VSB), all BH 105C.
                                      PWM controller : HS8108.
                                      • Pentium4
                                        CapXon Be Gone
                                        • Sep 2011
                                        • 3741
                                        That thing is silkscreened to have PFC? That looks like a new age Leadman/Linkworld
                                        • ttn328
                                          • Jan 2011
                                          • 12
                                          • Vietnam
                                          #380
                                          This PSU has no PFC, just jumbered. I don't know who is real manufacturer. This is their logo.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
