TCL 75R615 has sound, no backlight
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: TCL 75R615 has sound, no backlight
    Need the part numbers to know the gate, source and drain. Many videos on how to test.
    • R_J
      • Jun 2012
      • 9634
      Originally posted by thetonywarren
      Ok, does anyone have a good source for how I should be testing these particular mosfets? Ive viewed a few videos on youtube, but just looking for suggestions.....
      Thanks!
      If they don't check shorted, they are very likely ok. For a proper test you need to remove them and that could just cause more problems.
      • thetonywarren
        • Feb 2013
        • 169
        Ok, so I removed the heatsink that attaches to the two mosfets, I understand this is probably overkill but I wanted to be as throrough as possible. Please see the attached picture with both of the mosfets, I believe thy are MDF18N50, also see the attached link with the data sheet for reference....
        https://datasheetspdf.com/pdf/830304...hip/MDF18N50/1
        I will attempt to test both of these components per this video......
        https://youtu.be/gloikp9t2dA
        • thetonywarren
          • Feb 2013
          • 169
          I am still struggling in testing out these two mosfets, Im unable to re-create the testing results using 3 different multimeters I have with diode mode......Im not sure if Im doing something wrong or if there's something specific about these components that would prevent me from using a standard inexpensive multimeter in diode mode to test......any help is much appreciated......
          Thanks in advance!!!
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            I have one of these testers as i do find testing certain parts at times hard
            https://www.ebay.co.uk/itm/143173138...YAAOSwPF9ci9rw
            • dskall
              • Oct 2016
              • 2905
              • usa
              #26
              I maybe wrong here but I think your problem is that your gate to source is 10v to turn on mosfet. Your meter may not be able to do that.
              • thetonywarren
                • Feb 2013
                • 169
                I kind of thought about that, even though I was not sure.....is it because my meter is powered with a 9v battery it doesnt have enough voltage to trigger the mosfet to turn on/off? I know that description is pretty crude/simple, just trying to understand the concepts.....If that's the case Im guessing i'd need a more powerful DMM or a bench type meter that plugs into the wall? Regardless, Im purchasing one of those cheap LCR tester meters on amazon to try and sort things out.....
                • thetonywarren
                  • Feb 2013
                  • 169
                  I replaced the cap as well as resoldering the heatsink and mosfets. I was too impatient to wait for the LCR meter to arrive. TV seems to power up normally!!! Great news. Thanks to all for the help and advice.
                  • dskall
                    • Oct 2016
                    • 2905
                    • usa
                    #29
                    Thanks for feedback.
                    • CoryF
                      • Jul 2023
                      • 3
                      thetonywarren do you happen to have any high resolution photos of the back of the power supply board? My TV recently stopped working and I was able to find some components that were blown related to the 24V main supply. I was able to replace QW401 and R404, but there is a small resistor on the back side (R402) that is part of the gate drive circuit that has a hole blown right through the part marking. Hoping I can find the resistor size in a high resolution image.
                      Any help you can provide would be appreciated, thanks in advance!
                      • thetonywarren
                        • Feb 2013
                        • 169
                        The only pictures I have are the ones from post #3. Other than that, the TV has been working since the repair, use it every day pretty much.
                        • Ierwin
                          by Ierwin
                          05-13-2025, 03:31 PM
                        • triplefour
                          by triplefour
                          09-13-2023, 10:43 PM
                        • triplefour
                          TCL 75S421 has sound but no backlight not even a flash
                          by triplefour
                          TCL 75S421
                          PSU BOARD: 40-L402H8-PWD1CG
                          it shows not even a flash of backlight when powering up.
                          but the tv appeas to turn on and i can hear the sound of the menus moving and clicking. i can power down the tv with the button.
                          testing the backlights with my tester all 4 strings lit up and showed similar voltage drops. around 110 or so.
                          unplug mb and leave only psu plugged into backlights (PSU + BL SELF TEST MODE?) does not light the backlights.
                          i do see 24v but 0v on PSON and BLON (i didnt write this down tho so cant be sure)
                          with mb connected, PSON...
                          11-17-2023, 09:54 PM
                        • apnar
                          TCL 75R615 - no picture but working backlight & sound
                          by apnar
                          Hello all! New to TV repair and trying to bring a TCL 75R615 back from the dead. I've tried to do my basic research/reading but am at a loss so thought I'd see if anyone had some suggestions.
                          The TV powers up and I can see the backlight on. I can hear sounds by navigating the remote.
                          I tried disconnecting each side of the LVDS cables one at a time, powering off for a while between, and it didn't change anything. So my first guess was the TCON board so I order a replacement and swap that in. Didn't change anything.
                          Next I thought I'd try swapping the...
                          07-22-2022, 12:49 PM
                        • televizora
                          HP 8470p - distorted sound and noise when playing audio
                          by televizora
                          Hello.
                          I have an issue with HP 8470p - rather strange one.
                          I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
                          Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
                          Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
                          12-31-2021, 10:25 AM
