LED Array Schematic Check?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8711
    Re: LED Array Schematic Check?
    Nothing wrong with fluorescent tubes, I don't mind them at all. A lot easier to service than LED, then again the hope is that LEDs never fail. But look at all those TVs...
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Right? And even this lamp that I bought lasted all of 8 months before the LEDs in it started flickering out and I had to replace them ... after the third time replacing them and it started in with its flickering crap again, I had enough of it and decided to make this board which ... I expect ... will last a lot longer since the design seems more stable to me than what it shipped with ... and so far I only run the lamp at 50% on the dial until I need to use the magnifying glass then I crank it up to 100% but the lamp stays on all the time ... just at 50% in between actual use of the lamp.
      I never have found a fluorescent magnifying lamp that could produce the lumens that I can get with LEDs.
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        I have a generic question that maybe one of you can answer ...
        Consider the original question I had where I talked about using a potentiometer as the brightness adjuster for this circuit ... based on the calcs I was seeing, when I was going to use straight DC voltage for this circuit, I would have had to use a pretty fat POT as the brightness adjuster since it appeared that quite a lot of current would be running through that pot....
        Given that PWM is technically more efficient than using straight voltage ... what would the results be of implementing an RC filter at the output of a PWM source? Then adding a pot at that point for brightness adjustment? Would it bring it back to the original problem where the current would be such that the pot would have to be more robust or would the fact that the source voltage is simply filtered PWM mean that the calcs should be different given that the source is different than a straight DC source?
        This question is purely academic by the way ... I'm just curious.
        sigpic
          • Jul 2011
          • 6070
          Depending on how the PWM signal is generated it might make a difference but I am not sure exactly because when I had to do this for an industrial application the PWM was generated by a micro controller and with type of signal this is very noisy environment and putting a small value capacitor on the output cleaned it up enough that the device worked correctly this is what I am going by but when I look at the volt meter with out the capacitor on the output you could see the voltage fluctuation with your eyes but after putting the capacitor on the output it smooth out the voltage fluctuation and was less notable
          • EasyGoing1
            Shock Therapist
            • Sep 2016
            • 977
            Which reminds me ... I need to look at the output of this PWM dimmer with the cap on it with the scope ... curious to see what it looks like.
            Here are some screenshots of the scope when I had the PWM dimmer connected to 19 volts then the output was connected directly to the scope (not under load at all).
            If I'm not mistaken, the phantom traces in that third image, which are clearly distinguishable from the real signal ... is a result of the scope being unable to lock onto the signal thoroughly because the signal is so crappy in the first place.
            sigpic
            • Gadjet
              Need Schematic for RCF EVOX J8 two way array
              by Gadjet
              need Schematic for RCF EVOX J8 two way array
              10-01-2023, 12:15 PM
            • TinkerTron
              Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
              by TinkerTron
              Hey everyone,
              I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
              Instead, here's what's been bugging me so far:
              The schematic...
              03-06-2025, 02:03 PM
            • atunguyd
              Acer x163w Monitor PSU schematic
              by atunguyd
              Ii wonder if anyone can help me. I have a Acer x163w monitor which is not powering up. The PSU main capacitor's one leg had completly come off - I replaced it but the PSU is still not outputting DC. I found the monitor in questions service manual here on manuals lib but the schematic in there is a completely different - the schematic shows no mosfet to drive the transformer while the one I have does use a mosfet - also the schematic shows only one optocoupler but mine has two.
              The PSU board is labelled FM-20A02-AAA made by APD as per the image below. I am trying to find a schematic for this...
              03-05-2025, 02:08 PM
            • Thetechdude
              MSI Ventus RTX 4080 16G Broadview schematic needed
              by Thetechdude
              Hi guys, I'm working on a MSI Ventus RTX 4080 16G. The GPU has 12v, 5v, however what I assume is the 1.8v rail has 1.1v and what I assume to be PEX is 0v. As you may have guessed already there is no Vmem and no Vcore.
              I have looked around in related forum posts for a schematic so Much appreciated if anyone can share a Broadview schematic.
              Thanks.
              07-15-2025, 11:15 AM
            • ianpoultonknights
              Zenbook Flip 15 UX562AI schematic
              by ianpoultonknights
              Had one of these come in for repair with a blown battery and a WiFi issue, battery has been replaced with genuine battery (twice) and won't take a charge works fine on AC, WiFi issue gone away. Looking for a schematic so I can trace the charger circuit UM562F is only one I can find, this is the 562AI model.Had a unit come in for repair — 562AI model — with a blown battery and WiFi issue. WiFi fault has cleared, but battery won’t charge despite replacing it twice with genuine parts. Device operates fine on AC power. Suspect charger circuit fault. Only schematic I’ve found so far is for...
              06-26-2025, 02:41 PM
