HP BIOS unlock tool
Re: HP BIOS unlock tool
Used the tool for probook 650 g3 .no boot!SORRY WAS BADF CHARGER.Last edited by bachir2004; 11-24-2019, 08:16 AM.Comment
can i use some BIOS Backup Tools to get the dump from a EliteBook 840 G1?
i tried with Universal BIOS Backup Toolkit 2.0
can u check this for me please?Last edited by xerano; 12-05-2019, 01:02 PM.Comment
The other way would be decrypting the password but good luck with that (and share knowledge if you succeed)
But there is no point in doing it like that. You can't program eeprom without using a SPI programmer anyway. So just get a programmer and read it with that.
The question is, can someone Check my dump that i created with the Tool. will this dump Work to Flash them?Comment
What you have to do is:
*Disconnect battery
*Connect charger
*Turn on laptop (Go to F1 screen or whatever you like, doesn't matter)
*Turn off laptop using the power button and DO NOT disconnect charger
*Attach soic8 clip to eeprom
*Read bios.
*Mod bios.
*Write bios.
Turning laptop on and off is very helpful on HP-s.Comment
Then you need to deal with why it turns up faulty. If you can't read properly, you can't write properly.
*Disconnect battery
*Connect charger
*Read bios.
*Mod bios.
*Write bios.
Turning laptop on and off is very helpful on HP-s.i will Report soon thank you in advance
okay i have desoldered my chip and dumped it with AsProgrammer 1.41 and CH341A Programmer
then i used the HPUnlocker Tool and flashed this Image to the Chip (i ereased the Chip before)
now i have only black screen and Blinking CapsLock Key (5 times blinking)
can someone check my dumps to verify please?
Thank youComment
Thank you
After programming, Power on laptop and let it power cycle a couple of times. This is CleanME BIOS also so you need to wait for it to finish everything...Attached FilesLast edited by razor_amd; 12-07-2019, 10:13 AM.Comment
have u only use the HPUnlocker Tool? i have 2 another Elitebooks can i use this tool to done this?
or have u special mod used?Comment
by salim5566Hi guys i like to buy tool that automatic unlock bios or find password also can flash and repair bios ic, looking for good tool have good software that have 1 click and unlock bios any recommend good tool? looking for sony ps5 and and laptop bios
Thanks-
Channel: BIOS Requests ONLY!
by zeniusHello, I have an old Dell G3 3579 (ST: 2WQ7LP2-8FC8) with a newer 8FC8 BIOS password. I have successfully attached to the flash chip (W25Q128JVSQ) on the motherboard with a CH341A programmer and made several modifications using Intel FIT (e.g., allow software SPI write) without bricking. I was also able to boot to a modified GRUB shell where I attempted to edit many BIOS security related options like BIOS Guard/Lock, Flash Signature Override, ME FW Image Re-Flash, etc.
Unfortunately, some of these modifications like to Intel BIOS Guard failed because it is fused into the PCH. Also,...-
by CityminHi all,
My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
The charging red LED lights up, but the charging screen doesn't show any indication.
When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
(I've tried removing the battery and resetting the device, but the issue persists.)
NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
S/N : 5RNK9FFT70...-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by Forest79Hello,
I got a Lenovo ThinkStation P520 (Type 30BF) from a friend, asking me for a repair. Windows 11 offered a firmware upgrade as an optional update, and it failed.
The emergency flash procedure from the hardware manual has also failed. So, I asked an acquaintance with better skills to flash the BIOS directly.
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
Channel: BIOS & Schematic Requests!
- Loading...
- No more items.
