solder don't stick, new tip.
    • Jul 2011
    • 6070
    Re: solder don't stick, new tip.
    One note if you use a metal type of cleaning medium this is hard on a tip and you do every so often have to do this but it does wear your tip one other thing that wears out your tip is if you make it a habit of trying to clean soldering joints hole with the tip this cause the tip to be out of rounds and making hard to solder with
    • kity92
      • Jan 2022
      • 8
      • Poland
      I had the same situation with my old soldering gun. You have a corrosion tip and there is no way to fix it. Don't use any sandpaper I did it but just making it worse. There is two option. Change tip and buy some cheap tips (if you soldering one time in a month) or purchase a new soldering gun because high temp and bad soldering wire are killers of tips.
      -Dont use sanding paper
      -Dont use tinner for clean tip
      -Use clean water and sponge
      -Dont use your tip like aggressive
      -Stay all the time some soldering wire on tip
      • mosfetratus
        Sure Not
        • Feb 2019
        • 174
        • Resistron
        steel wool or thick cotton cloth to wipe that oxide crust
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
        • corrize
          Best way to solder LVDS connector for beginner (and qfn) ?
          by corrize
          Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
          I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
          I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
          See the test :
          https://youtu.be/bNAzC-EvqHs?t=1767
          With hot air from bellow the board, that's...
          03-09-2023, 02:57 AM
        • ezenia
          PS4 controller left stick potentiometer replacement issue
          by ezenia
          Not sure if this is the correct section, but I have a PS4 controller that I am trying to fix. It developed stick drift on the left stick and the usual simpler methods did not fix the problem.
          So I went on eBay and ordered some replacement potentiometers. https://www.ebay.co.uk/itm/174967976757 is where I got them from.
          I took the green potentiometers off the replacement sticks and soldered them onto the PCB. Assembled the controller and ran some tests. The drifting was somewhat fixed (not fully in center, but way better than before). However,...
          09-30-2023, 02:19 PM
        • petemanuk
          BGA solder balls not connecting - help pls
          by petemanuk
          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
          11-16-2022, 05:21 AM
        • myth77
          UV solder mask - high temp resistent, recomendation?
          by myth77
          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
          Is there any solder mask...
          03-28-2022, 04:04 AM
