Sharp LC70LE747 Flickering - darkening gradually to the right side
  • Diah
    • Feb 2013
    • 6422
    Re: Sharp LC70LE747 Flickering - darkening gradually to the right side
    for me its not panel fault.. the set trying to kill him self ( suicide ) LOL
    + 8Years old and picture setting dynamic !!! if one LED its ziner diode leaked.. there will be pulling of currents not Volts. if you measure currents you will find it.. even with this age of TV LVDS could be dried out. changing at Resistances of one of its PINs. clean them and it sockets could make change.. reduce BL could make change.. turn off 3D profile could make change too.. just be nice to it and care of its age pls.
    • SmartSarah
      • Jul 2016
      • 20
      • Belgium
      A few assumptions
      Which module can move the image vertically?
      The panel? I do not think so. Streaks, lines, dark, etc but not moving an image seems to me.
      T-Con? Definitely, which is exactly what that module does. However, my replacement module does the same.
      Main module? Yes it could be, if it delivers such an image T-Con cannot solve that. But how to test that without a replacement main module?
      I come back to the power supply. Could it be that the quality of the delivered power supply compromises the functioning of other modules? Quite possible, I think.
      Visually, I see nothing wrong on any elco on the PSU. To avoid having to unsolder each capacitor to measure it, I would first consider the following experiment.
      Through an external power supply I offer the PNL 12V and UR 13.2V, before starting the device.
      If he then works normal, maybe I can hang a scope on those lines, but in any case I have to look in the direction of capacitors on the PSU.
      Do you think the experiment with external power is worth to try?
      • Diah
        • Feb 2013
        • 6422
        this experiment will not work. because the Main boards full function at Dc to DC need another parameter to switching on like BU5V /AC_DET / ERROR,
        Alternative to this you can run the set will less load... BL down... sound down... wifi plugged out etc.
        the questions,now you are talking on the image jumping as we saw at your second video.. which are different from first Video you upload. is this new behavior ?
        other question did you log in Inspection mode to see if there are error as suggest at post#18?
        • dskall
          • Oct 2016
          • 2905
          • usa
          You can scope your power supply and main board voltages for fluctuation.
          • SmartSarah
            • Jul 2016
            • 20
            • Belgium
            The set appears to operate normally the last few days.
            Reason? More in use lately, warmer room temperature, mechanical manipulations, ...
            The vertical image jumping is there sometimes on top of the darkening. It's the extra factor of bad start-up indication.
            I've checked the first page of the inspection. See included picture.
            Lamp Error = 0
            There are some monitor err causes.
            1) 21 B00011422:40
            2) 21 B00011399:05
            3) 21 B00011251:35
            4) 1A B00011239:26
            I hope this give a clue where to search.
            Next I'll monitor the voltages during start-up with a scope.
            • Diah
              • Feb 2013
              • 6422
              so the inspection mode pointed to 21 PCB Panel power failure
              • SmartSarah
                • Jul 2016
                • 20
                • Belgium
                #27
                Okay. that's the PNL 12V on the PSU board.
                How did you figure out this detail?
                • Diah
                  • Feb 2013
                  • 6422
                  early i uploaded for you the service manual at my post #6 .. display code detail listed on Page 63
                  • SmartSarah
                    • Jul 2016
                    • 20
                    • Belgium
                    #29
                    Oh, I read only the page you indicated me earlier. I didn't realise what an information treasure you posted to me. I am sorry for this aberration.
                    • Diah
                      • Feb 2013
                      • 6422
                      as you mentioned before
                      so you need right now only to reset the error at page 2 of inspection mode. and if the fault back in future days.. you can see the error code again and work on it rails at PSU
                      • SmartSarah
                        • Jul 2016
                        • 20
                        • Belgium
                        #31
                        Update - the problem returned
                        Inspection
                        - MONITOR ERR CAUSE: all 4 positions "00 0000000000000"
                        - BL voltages 190V, current 22mA (measured with DC current clamp)
                        Observations
                        - I've noticed extreme latency on right side during inspection (see Ghost latency 1 video)
                        - I made another video while toggling through LCD TEST PATTERN 2 (the other are not supported). see LCD TEST PATTERN 2
                        - After power off, the last image is noticeable and fading out on the right side during about 10 seconds (no video made)
                        Could it be like a bad ground in the panel?
                        • Diah
                          • Feb 2013
                          • 6422
                          fading image on screen. i had one time faced it at Hisense and i do post it over here.. i just solved it with panel driver firmware which i took from friends in china.
                          so i suggest you at my post#7 to put back yours original T-CON. did you ?
                          at same service manual was advised to inter adjustment mode in case changing module of main or panel.. but i don't think you need this if you put back the original t-CON and did reset from inspection mode page 2.
                          EDIT: if you did have same fading remain with original T-CON. i would change all caps at Panel_12V rail on PCB
                          • SmartSarah
                            • Jul 2016
                            • 20
                            • Belgium
                            #33
                            The original T-CON has always been in place. I just swapped it shortly but since it made no difference I installed the original back.
                            Ok, at least I'll start measuring the 12V caps. I'm not sure if I've replacements available on the shelf. Would it hurt if I additional place caps in parallel?
                            • Diah
                              • Feb 2013
                              • 6422
                              mathematics wise yes.. but as currents who knows and we don't have any record under hand.. so i would just measure ESR out side the circuit. if it was out of the order.. u can do this experiment until u got exact value
                              • SmartSarah
                                • Jul 2016
                                • 20
                                • Belgium
                                #35
                                I've measured 6 x caps 470uF, all good. C7133, C7130, C7123, C7120, C7950A, C7950B.
                                Replaced C7123 by a new 1000uF. No difference.
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #36
                                  So, I don't think main board is responsible for erasing image. That is done at t-con/panel.
                                  • Diah
                                    • Feb 2013
                                    • 6422
                                    if you test all were good why you replaced C7123..
                                    it sound for me the error 21 TV registered could be related to Test you did to ribbon disconcerting one side cable or LVDS before since no more error listed.
                                    • SmartSarah
                                      • Jul 2016
                                      • 20
                                      • Belgium
                                      #38
                                      Small update on this.
                                      It's all in the boot of the TV.
                                      I follow this procedure nowadays.
                                      Bad image -> pull the mains socket -> reboot (= cold restart with large red SHARP logo).
                                      Again bad image -> repeat pulling the mains socket for a few seconds.
                                      Good (= steady SHARP logo), so not jumping, not fading to the right -> leave it on. And than it stays fine, for weeks!!!! until next reboot.
                                      Brightness or backlight has no influence. Last "session" it worked fine on dynamic setting for 3 weeks.
                                      The only reason for this behaviour I can think of is that one or more (passive) components is degrading and troubles some syncing during start-up.
                                      But besides blindly de-soldering and measuring capacitors I have no clue where to start diagnosing.
                                      • nomoresonys
                                        • 12220
                                        • U.S.
                                        #39
                                        wonder if it could be a memory problem?
                                        • nomoresonys
                                          • 12220
                                          • U.S.
                                          #40
                                          also wonder if it might be a bad/intermittent connection in backlight circuit.
                                          • Civitello
                                            RCA RTU5540-D has flickering pixels on entire right side of display.
                                            by Civitello
                                            TL;DR: Is one side of the display showing flickering full brightness r g or b subpixels in a sparse arrangement likely to be a defective secondary board?
                                            Model: RCA RTU5540-D
                                            Problem: The right half of the display has pixels flickering, it seems like random subpixels (red, green, or blue) are being turned on at full brightness briefly.
                                            I have tried reseating and switching the two ribbon cables coming from the secondary board to no avail, but I did confirm that each one corresponds to 1 half of the display. I considered trying to drive the right half of the...
                                            05-14-2023, 05:28 PM
                                          • WillHoh
                                            Slight flickering and horizontal stripes on the right side - VX24AH Asus
                                            by WillHoh
                                            Hi, I have an Asus VX24AH monitor that suddenly went black and didn't display a logo when I switched it on. After extensive research (also thanks to this forum) I was able to get it to show a picture by disconnecting the STV (VSTB1). Unfortunately, the right side now shows horizontal stripes and it looks like every 2nd pixel row is missing.
                                            Can anyone help me with this? Can it still be saved? I would also appreciate links and references to literature or other information.
                                            Before disconnecting, the test point of VSTA1 and VSTB1 only measured 30 ohms. I therefore disconnected...
                                            08-26-2024, 06:45 AM
                                          • flibidy
                                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                                            by flibidy
                                            I have here a Magnum IA.100 which belongs to my parents.
                                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                                            What Ive done........
                                            01-01-2025, 01:26 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • ttmi100x
                                            HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                            by ttmi100x
                                            Greetings everyone,
                                            I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                            The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                            Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                            Upon closer inspection...
                                            07-31-2024, 06:36 PM
