LCR T7 tester problem
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    Re: LCR T7 tester problem
    Don't have one but I'll see if I can find one in town
    • Crystaleyes
      • Sep 2021
      • 493
      • Brazil
      Hi all.
      Feel I should update the situation...
      Stj's original suggestion regarding upgrading the crystal whilst installing two resistors and reflashing the Atmel was surely advice which I should have followed, however...
      Considering that the flashing kit was almost the same price as the 'latest' TC2 ESR tester, I took the lazy route and just before Xmas received the TC2.
      There are already three dead variations of the MK328 component tester in my 'to fix' bin, so I was über careful measuring caps with this one.
      After less than three weeks, whilst testing germanium diodes and transistors in an old radio, the TC2 just switched off. I didn't think much of it, as it had been doing that since it had arrived.
      But that is the state it is still in to this day!
      I have had a quick peek and found two dead zeners, and shall open up a new thread about this tester in the near future, with more detailed photos and explanation.
      To be honest, it is a pretty crap tester, but that's another story too.
      Thought it was a bit rude to not have given an ending to this thread..
      Cheers
      • harp
        • Jun 2022
        • 648
        • Planet Earth
        saves a lot of messing around with patch wires...
        Just interesting... stj
        I have also a simmilar LCR-T5 the red one with two button, and... acidently testing a charged cap... offcorse
        The tester at this point shows wiered things, mostly like mosfets or so... it boots up normaly... so, I thinking, maybe is burned some input thingy inside uC but maybe lucky enough to extract firmware from it? I realy like it original chinese firmware.
        Question is, can I read and write atmega328 with ch341a programmer throu spi header, and what prearrangement have to be done before that?
        I do not any experiance about that, so please explain step by step
        Can be done in circuit somehow?
          • 31281
          that looks like the old "fish" tester i think - very early design style.
          firstly, if it's not dead check if it has the input protection diode-pack.
          if it does then remove it and try again.
          • harp
            • Jun 2022
            • 648
            • Planet Earth
            I dont see any protection diode pack...
              • 31281
              under the board?
              • harp
                • Jun 2022
                • 648
                • Planet Earth
                #27
                No, on back side there is no any component.
                This 6-leg smd package nor multiple diodes is not on the pcb.
                I look even under zif socket.
                  • 31281
                  then check the 6 resistors on the sensing likes, if they are good your atmel is damaged.
                  on the bright side - it has a programming header.
                  • harp
                    • Jun 2022
                    • 648
                    • Planet Earth
                    #29
                    Check R1 till R6 in circuit, all is still ok... 680R and 470K
                    Check for shorts and nothing find.
                    Input pins 1, 2 and 3 from zif socket are also directly connected to atmega328 pin #23, #24 and #25.
                    So, can I try to read this chip with CH341A, is connection direct or crossover some pin... what power... what is next step?
                      • 31281
                      i have never used a ch341 to read the spi bus, so i dont know.
                      99% chance they set the lock bits though, or the firmware would be online somewhere.
                      unless it's here:
                      https://disk.yandex.com/d/yW8xa5NJgUo5z
                      • harp
                        • Jun 2022
                        • 648
                        • Planet Earth
                        #31
                        Ok, if we pretended to I have USBasp programmer with all needed wires what is next to do to try to read atmega328?
                        I accept a 1% chance for success if you can guide me
                        I just read MX25L3205D with it, so it does SPI as well.
                          • 31281
                          download AVRdude and it's pdf
                          then if it supports your programmer use it to read the flash, eeprom and fuses in 3 seperate passes
                          https://github.com/avrdudes/avrdude
                          https://avrdudes.github.io/avrdude/7.1/avrdude.html
                          or try the factory software for the ch341?
                            • 31281
                            actually i think NeoProgrammer can do it with ch341
                            https://www.badcaps.net/forum/showpo...postcount=2373
                            • harp
                              • Jun 2022
                              • 648
                              • Planet Earth
                              #34
                              Thank you very much, I need some time to setting up wires and program...
                              I downloads a bounch of random software who claim to can comunicate with avr from ch341... we will see...
                              • harp
                                • Jun 2022
                                • 648
                                • Planet Earth
                                #35
                                ok, here is update
                                For reference I working with winxp sp2... 32bit.
                                I aim to download program for programing avr via ch341:
                                neoprogramer 2.1.0.19 - work ok, but fuse tab is no description and it is confusing for beginers. Still it is good interface and work great. Neo 2.2 I download from past link but I cant extract. I guess there is no big diference.
                                avrdude with gui is a basic and it is... basic
                                I can start this gui, but indeed it is not user friendly, only graphicaly presented cmd line... unknown purpose for doing that... presume that I already know all about microcontrolers to save me some space on screen - no description and meaning at all whatsoever. So... next!
                                avrdudess 2.14 - from pictures look user friendly with some description, but I can not start it because of missing some crucial component who isnt preinstalled on my os and it isnt in the same package within too...
                                avr-ch341 is a look good small program (3 files) that work out of the box and have description with any option. I will use this program at the moment till not find a basic failure or so. It is yet simply and neat, and it is still free
                                So... I build a small adapter, basicly original male-female jumper wires glued on some wooden cube... it is handy because I can use it via zif socket. I test it with through arduino icsp connector and can read a flash, eprom and fuses. But when I conected it with LCR-T5 it pulls all FF FF FF FF on screen... and say that device is disabled for future programing and verification...
                                So... is there is a way to overcome this, to anyway read firmware from chip, or at least erase it for reusing it?
                                In meantime I was try to download firmware from yandex link but I cant due to old browser. Please can you do (or somebody else) to download a firmware pack for me, my tester and upload it here?
                                It is fish8840 design version 2.1, with two button,
                                atmega328p, 8MHz, monochrome (green) dot matrix display 12864LCD
                                And... before I mess up with future chip desoldering and ripping up a bunch of pads, is any precautions, sugestions, procedure that I must know or deal with before programing it?
                                  • 31281
                                  install peazip
                                  https://peazip.com/
                                  install the final version of opera
                                  • harp
                                    • Jun 2022
                                    • 648
                                    • Planet Earth
                                    #37
                                    Wow! thank you very much, i must study this now... but before one question: the fuses is program before or after flash memory?
                                      • 31281
                                      fuses last - because if you accidentally protect the chip you cant verify it.
                                      and you dont want to screw up the clock setting while programming either.
                                      first the flash,
                                      then thr eeprom,
                                      fuses last.
                                      • lotas
                                        • Jan 2016
                                        • 4837
                                        • Russia
                                        #39
                                        Here is avrdudess portable program, with CH341A support.
                                        • harp
                                          • Jun 2022
                                          • 648
                                          • Planet Earth
                                          #40
                                          So yeah, some progress is done
                                          1. desoldering the chip... ok
                                          2. buying new... ok
                                          3. soldering new chip... ok
                                          4. connecting with ch341a... ok
                                          5. load and program original hex... ok
                                          6. verify flash... error at address 0x2? but it looks identical, maybe some bug? I can read the flash.
                                          7. load and program original eep... ok
                                          8. verify eeprom... ok
                                          9. confused with fuses, waiting for help...
                                          it has some picture for fuses in folder Fish-8840/Firmware/Original(ver2.1) but it is all different to me... russian notes... I dont know what to choose.
                                          on original "destroyed" ic, I got fuses reading of
                                          extended 0x05
                                          high 0xD9
                                          low 0xF7
                                          I put attached photo of new chip fuses, and AVRCH341A interface.
                                          I didnt touch anything yet
                                          help... what to enter?
                                          P.S. can you point me where to look for 0x2 address?
                                          • theone111
                                            by theone111
                                            3. Problem: TV shuts down
                                            07-22-2024, 10:36 AM
                                          • seifaldenn
                                            LCR T7 tester problem short
                                            by seifaldenn
                                            LCR T7 tester problem short( dz2---v05 )
                                            you changed v05 working now Not a fixed measurement
                                            Any measurement out 2.95v
                                            Kim can solve the problem out 2.95v ...
                                            03-29-2023, 06:57 AM
                                          • Zeonalbasta
                                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                            by Zeonalbasta
                                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                            09-13-2024, 01:17 PM
                                          • Gibon378
                                            Problem with stopping audio and video for no reason
                                            by Gibon378
                                            PC Specs:
                                            • CPU: Ryzen 5 1600
                                            • GPU: GTX 1080 Palit JetStream
                                            • MOBO: ASRock ab350 PRO4
                                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                            • PSU: XFX 650W (don't remember what model)
                                            • OS SSD: ADATA SP920
                                            • OS: Windows 10 21H2
                                            Problem description:
                                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                            11-19-2022, 09:41 AM
                                          • perzyk23
                                            Lenovo T580 - LCD Panel problem - error 0288
                                            by perzyk23
                                            Good morning,
                                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                            10-25-2024, 12:42 AM
