Power supply build quality pictorial DISCUSSION
This is a sticky topic.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Power supply build quality pictorial DISCUSSION
    Originally posted by Newbie2
    That's some good 350W power supply, but the pictures were a bit big.
    Sorry bout that... I resized them a wee bit... Used the wrong size...
    Yea, it's an impressive PSU... Also impressive that the PCE-TUR caps are fine... It's been in use for over 3 years, was bought 02-12-12...
    • Newbie2
      • Sep 2005
      • 885
      We have seen I think two failures of PCE-TUR caps, it's weird that their failure rate is very low (or low) but PCE-TUR is on the bad caps list.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
      • Rainbow
        • Aug 2005
        • 1375
        Looks like they're "good" bad caps
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          wow... I'd never seen a "Vogue" power supply before... there's nothing in there! Also, I didn't realise they were still making AT supplies in 2000... or that anyone would still use one! I don't think I ever had an AT supply fail on me...
          Ludicrous gibs!
          • Rainbow
            • Aug 2005
            • 1375
            I've repaired some AT PSUs - shorted transistors and diodes. Never seen bulged caps in them.
            • Mustang
              • Dec 2003
              • 203
              #26
              An overview of the build quality pictorial. There's PSU's that range from very old to a few of the latest models. It would seem to make sense if these pics were separated so if someone were to browse this forum trying to make an educated decision on buying a new PSU, they'd have the info readily available. Or perhaps a list of recommendations based on this pictorial?
              • Oklahoma Wolf
                • Dec 2005
                • 353
                #27
                Sounds like a plan - we could also post an approximate date along with each PSU to give an idea when it was made. Not sure about the Enermax I just posted, but it's gotta be older than 10 years. The FSP530-60GNA is roughly two years old, the CWT 250W is around 8 years old, and the FSP600-80GLC is a brand new model.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  #28
                  i was thinking we should show the range of few good manufacturers. we already have a good covering of what seasonic is doing on Per's thread so we should have one on fortron and fortron built units (considering that global availability is good). it would be best to show only units that would still be available. it would be great if someone could figure out the fortron model numbering if there is any logic to it.
                  • Oklahoma Wolf
                    • Dec 2005
                    • 353
                    #29
                    There's a few things to remember about Fortron part numbers, but not really anything to tell how new they are from them. The part numbers starting with AX and ATX are usually lower quality units from them (more likely to contain Fuhjyyu anyway), while the FSP models are usually higher quality. Taking my FSP530-60GNA as an example, I believe the G is supposed to indicate 80mm fans while the N signifies the noise killer thermal fan controller. No idea what the A is there for, or what the 60 means. There is a FSP530-60GN with much higher 12v capacity - maybe that's what the A is for.
                    It seems like they change it slightly for new lines. The Blue Storms end in THA or THN depending whether or not they have a 80mm fan or 120mm fan respectively. Except the AX500-A, which is a line unto itself. The Green Powers are GLN (120mm) or GLC (80mm), and the Zen fanless line ends in 60GNF for both models. Then there's the Russia only OPS line. It's all a bit confusing.
                    • dood
                      Deputy dood
                      • Mar 2004
                      • 2462
                      I was thinking about taking the pics from the pictorial thread and making them into a website, organized by brand, with just the top-down views on it, for a quick reference. That's kind of what I had envisioned for that thread, but then I got all picture-happy
                      Ludicrous gibs!
                      • Newbie2
                        • Sep 2005
                        • 885
                        Originally posted by japlytic
                        Vogue (rebadged Deer) 230W AT unit, manufactured July 2000. Viva primary caps; the rest Rulycon (my first real sighting of this brand!) and one CapXon.
                        I don't know why a company would make AT power supplies in the year 2000, when ATX was the standard.
                        That is the crappiest AT power supply I have ever seen. I thought the Astec SA145-3430 145W AT power supply (I don't have it anymore) was the crappiest AT power supply.
                        My gaming PC:
                        • Rainbow
                          • Aug 2005
                          • 1375
                          #32
                          L&C LC-B450 E 450W Power Supply
                          OMG, that's crap. I'd call it 200W max.
                          • larrymoencurly
                            • Oct 2004
                            • 960
                            IThat is the crappiest AT power supply I have ever seen. I thought the Astec SA145-3430 145W AT power supply (I don't have it anymore) was the crappiest AT power supply.
                            Isn't Astec supposed to make the good stuff? I once had an ancient XT Astec that was built like a tank compared to everything else, including a LiteOn.
                            • Chris1992
                              • Apr 2005
                              • 561
                              #34
                              Yeah, Astec's PSUs I thought are good. I have a Mac Performa 6320CD with Astec PSU. Only thing is, I don't have a Mac monitor nor mouse nor kbd to test it.
                              The great capacitor showdown!
                              • Chris1992
                                • Apr 2005
                                • 561
                                #35
                                How can I tell if a PSU has passive or active PFC? Willawake's Fortron Blue Storm 350w has passive but I don't see anything in there really different to my 350w Hipro PFC-less PSU.
                                • dood
                                  Deputy dood
                                  • Mar 2004
                                  • 2462
                                  I think, in the picture that Willawake has in his post, it's the thing in the upper-right corner of the PSU, by the main caps... I think. If you compare his PSU to the Sparkle (Fortron) PSU that I posted earlier (the new one), you'll see that mine has a big open hole where that thing is supposed to go on overseas models.
                                  Ludicrous gibs!
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3586
                                    • USA, Unsure of Planet
                                    #37
                                    Bingo, dood. And that inductor probably makes that corner of the P/S rather heavy, since the core is probably steel laminations.
                                    PeteS in CA
                                    • dood
                                      Deputy dood
                                      • Mar 2004
                                      • 2462
                                      Something interesting that I've been noticing... on the cheaper, crappier supplies, you find the "warranty void if removed" stickers covering screws and seams and such... but on the more expensive or just higher-quality units, you usually don't. Iiiiinteresting...
                                      Ludicrous gibs!
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        In the L&C LC-B450E 450W supply, the 330uF 200V primary capacitors are inadequate for a supply of this size. They should be at least 680uF.
                                        820uF 200V primary capacitors in the Delta DPS300-BB 300W supply seem plentiful; an old Compaq Deskpro 386s 140W supply uses two 680uF 250V units in the primary.
                                        • PeteS in CA
                                          • Aug 2005
                                          • 3586
                                          #40
                                          Passive PFC uses a large, heavy 50/60 Hz inductor. As mentioned above, the core will be stacked steel laminations, either E-core or U-core.
                                          Active PFC will usually use a 400V or 450V I/P lytic. There will be an inductor, usually with a toroid core. I'm tempted to say there will be 3 devices on the primary-side heatsink, but this can vary, depending on whether the main inverter is a single-switch forward converter or a two-switch forward; also, the standby switch (or regulator) may be on that heatsink. So that can be misleading.
                                          PeteS in CA
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                            by sam_sam_sam
                                            03-31-2024, 02:12 PM
                                          • shamsudeen
                                            Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                            by shamsudeen
                                            Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                            I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                            i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                            07-19-2025, 07:14 AM
                                          • JimBanville
                                            Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                            by JimBanville
                                            The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                            Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                            I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                            I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                            09-13-2023, 07:21 AM
                                          • madan1
                                            555 based power supply getting too hot
                                            by madan1
                                            Good day.
                                            I have an AC/DC -> DC PWM (rectifier + 555 buck converter) power supply with MDF11n60, which is getting very hot.
                                            The input is AC from a transformer and the output powers a 24v dc fan. The power supply is used to regulate the speed of the fan.
                                            After several runs on the bench power supply I noticed that the mosfet is reaching 80+C*. The mosfet reads fine on component tester, the thermal paste is changed, the fan is cleaned and with freshly oiled bearings.
                                            When powered directly from the bench psu, the fan takes ~0.7A on 12V. The current consumption is similar...
                                            06-23-2025, 04:38 PM
