[FAQ] Atten 858d problem S-E (or 5-E) or stuck in 498'C.
  • jmbinette
    • Nov 2017
    • 10
    Re: [FAQ] Atten 858d problem S-E (or 5-E) or stuck in 498'C.
    Originally posted by stj
    not much to it if it matches either of these:
    Actually it matches this schematic (resistor and cap ID are different but circuit is the same.
    • redwire
      • Dec 2010
      • 3912
      The triacs (BTA16-600B) are known to short circuit and the heater stays stuck on. Very dangerous and will burn down your house! Never leave these cheap chinese stations plugged in all the time, I pull the power cord after I am finished.
      The triac does need a heatsink, so make sure you have one or it will just overheat and short.
      The exact 858D schematic depends on your PCB version. Post pictures if you are not sure. This is 858D+ schematic which is similar.
      • jmbinette
        • Nov 2017
        • 10
        The standby function isn't working, but that doesn't , mean the Triac is shorted.
        It heats properly to whatever temperature I set and then maintains it.
          • 31267
          if the cpu pin is changing between 5v and 0v when you put the handle on the holder then the cpu is bad i imagine.
          otherwise you need to check the reed isnt cracked etc.
          • jmbinette
            • Nov 2017
            • 10
            I received a second unit from amazon with the same behavior... weird !
            And yes the cpu pin is changing between 0V and 5V.
            Anything would prevent the cpu from triggering the input?
              • 31267
              only a software function - try picking it up, putting it back, then waiting.
              they do have a delay.
              • redwire
                • Dec 2010
                • 3912
                Are you positive you have the right MCU pin?
                The reed switch sees the magnet only when in the cradle, so it closes and I/P goes from 5V to 0V.
                The chinese are trying to put hardware copy-protection in their soldering stations, as they steal firmware from others. To prevent cloning, the firmware guy will move an I/P pin so the clone pc boards no longer work. Small chance but this might be what you're seeing.
                • jmbinette
                  • Nov 2017
                  • 10
                  For the record, here is another PCB to add to the "clones database" ! lol
                  I re-tested everything and pin 18 on the IC is really switching from 5V to 0V(Wand on the holder)
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5084
                    • New Zealand
                    #29
                    I think what redwire is saying, is that Pin 18 may not be the pin the firmware is actually expecting the sleep signal on. As far as the software is concerned, Pin 18 may not even exist - the software might be waiting to see that sleep signal on say, Pin 17 instead.
                    Or, the software might not even have a sleep function at all!
                    -David VanHorn
                    • jmbinette
                      • Nov 2017
                      • 10
                      I tried every input pin with a jumper (both high and low) without any success of finding "the hidden input"
                      Seems like the device was not programmed with a standby mode but the manual says clearly that it has one ...
                      I bought the first unit, returned it and now this one has the same problem. I wondered if I could repair it easily but seems like I will also return this 2nd piece of Chinese cr*p !!
                      • redwire
                        • Dec 2010
                        • 3912
                        That's really weird. I wonder if it could be something enabled or disabled in settings that are stored in the EEPROM. Does it remember the temperature setting when you power it off? I'd poke around the menus if it has any.
                        Otherwise, the only fix would be an MCU adapter board that people have made for these.
                          • 31267
                          the replacement formware thing is interesting, but i have not tried it - my unit works fine as it is.
                          although i did think about changing it so i could use an oled display!
                          • jmbinette
                            • Nov 2017
                            • 10
                            Only setting I found is pressing the 2 buttons at the same time and I can set the default power-on temp. And it gets remembered by the EEPROM.
                            As for the replacement firmware ... I would consider it but would rather start with a fully functional unit before
                              • 31267
                              so what - you hold both buttons and it uses the set temp as default?
                              i'm pretty sure mine holds the last setting until you change it again.
                              • jmbinette
                                • Nov 2017
                                • 10
                                Yes correct, I hold 2 buttons and I have like 3 seconds to set a default temperature
                                  • Jul 2011
                                  • 6070
                                  I do not like this as a setup however wrote this software what were they thinking about when did this
                                  Unless this is done keep you from changing the temperature by accident
                                  Which might not be a bad idea this is ? mark
                                  • azone
                                    • Feb 2011
                                    • 3
                                    #37
                                    ...thanks to the OP for the tip... I just got an 858D that stopped working after 15 seconds when it heated up. It was also a cold solder joint. In my case it was the other style 858D with the two buttons on each side of the pot and the eight pin connector for plugging in the hand set. The lead free solder on the 8-pin connector was terrible. I resoldered and everything is fine.
                                    This is the style I'm talking about
                                    https://www.amazon.com/dp/B07XYMJ7BQ...2522518&sr=8-6
                                    • MadMaxGR
                                      • Dec 2020
                                      • 3
                                      • Cyprus
                                      #38
                                      Originally posted by senndogg
                                      Its only a week i have been working with my new Atten 858D+ heating station and i have experienced a problem. The station showed S-E in the digital display, the blower fan was ok but it was NOT heating. Searching the web showed that the heating element was gone, this was an error code, but it was not true. Measuring it showed 70 Ohms. Also the mosfet which drives it was not shorted. The station was also stuck in 498'C sometimes, again no heat.
                                      Browsing again and saw some unresolved topics, there is one at a well-known polish forum. Mine is in warranty too but i was not thinking about shipping it ti China.
                                      After close inspection at the small circuit in the gun, i could distinguish a cold joint at the soldering of the thermocouple sensor. Bingo!
                                      Now the heating is working great again!
                                      Thanks for reading.
                                      First pic is the Atten 858D+. At the moment it is OK, SLP means "sleeping".
                                      Second pic is the culprit.
                                      @senndogg I am sorry for bring back to live your post, but I would need yur help on that.
                                      I have bought a heating element replacement for my toasted old one and I have issue identifying the wiring. The wires on the replacement are totally different and even same colored. I can't tell also which one got to Positive and which on Negative. Can you help? I attach the pictures.
                                      You see the replacement has 2 x black , 1 x red, 1 x Green, 1 x Blue wires.
                                      The one black is thick, so I guess this is the main voltage, which is the grey one in my original wiring. I hope you can help me where to solder each.
                                        • 31267
                                        on the element, you can use a multimeter to find the 2 wires by continuity test to the coil.
                                        the other 2 wires will be the sensor.
                                        then check that by setting your meter to read mV and heat the sensor with a hair dryer or something and you should see the voltage rise.
                                        that will also tell you which wire is + and which is -
                                        • MadMaxGR
                                          • Dec 2020
                                          • 3
                                          • Cyprus
                                          #40
                                          The wires are wrapped inside the element, is difficult to do continuity test, but I can figure out which one goes where if I can find the Positive and negative.
                                          • Prott
                                            Surface Pro 7 - SSD heating up in an unusual pattern, stuck at boot
                                            by Prott
                                            Hello fellow Badcappers,
                                            I have a Surface Pro 7 that's turning on (CPU heating up, USB powered, LCD powered) stuck on a boot logo. BIOS should be correct (ME cleaned, worked in a different S7Pro), no shorts. Only thing that seems a bit weird is the pattern in which the SSD chip is heating up. Is that normal behaviour? Rest of the SSD is 10 degrees colder.
                                            I have replacement SSDs, but it's quite a hassle to reball and install them, so I would like to avoid doing this step if possible.
                                            Thank you!
                                            03-01-2024, 08:23 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • stormanimal83
                                            Gigabyte B450 Aorus Pro stuck at VGA LED, burning hot LED Controller MCU 1 under PCI slot...
                                            by stormanimal83
                                            Hey....
                                            Board as written in description was stuck at VGA LED. common Problem wit these type of bords.... tried all the "standard stuff" like resettin... reseatin.... found out the LED Controller MCU1 = IT8295FN-56A geting burning hot under the last PCI Slot.. now i desoldered it cause there were only 18 ohms at the caps arround.... another aorus x470 in working condition with similar part and nearly same layout had arround 280 ohms...
                                            my question is: why doesnt the board start know without this chip.... worked myself through the boardview but i can´t understand...
                                            01-18-2024, 02:15 PM
                                          • ekozeko333
                                            [Help] Lenovo Yoga Slim 7-14ARE05 (DA0LS3MBAF0) – 25Q80DVN1G Flash Is All FF, USB-C PD Stuck at 5V
                                            by ekozeko333
                                            I’m trying to recover a Lenovo Yoga Slim 7-14ARE05 with board DA0LS3MBAF0 Rev:F. I’ve run into an unusual issue where USB-C PD is stuck at 4.7–5V and the system won’t boot (keyboard lights flash briefly, then nothing).
                                            🔥 The Problem Started After Suspected ESD/PD Fault
                                            I experienced a power issue or ESD event through a USB-C charger
                                            After that, the NX20P5090 power switch was visibly burned and was replaced
                                            Now the PD controller always negotiates 5V @ 2A, even with known-good chargers
                                            🧠 What I’ve Done So Far
                                            Flashed...
                                            06-21-2025, 02:48 AM
                                          • EasyGoing1
                                            The best way to drive a heating element?
                                            by EasyGoing1
                                            I've got this circuit that I've been playing with on a breadboard. I'm not happy with it mainly because the MOSFET gets too hot and generally controlling the temp of the heating element with the Arduino has proven to be a little more cumbersome than I would like.
                                            What I would like to know, is what is the best way to set up a circuit like this? The heating element is just a PCB and its going to be mounted under a 3D-printed enclosure that a lizard will use to warm his belly.
                                            This is the general setup that I have now.
                                            This is what the...
                                            01-25-2023, 11:29 AM
