warning!xcelite flush cutters!
This is a sticky topic.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: warning!xcelite flush cutters!
    sorry... wrong thread....
    sigpic
    (Insert witty quote here)
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5045
      • US
      this thread is stickeyed, so I don't think it can 'die' cause it never falls off any page
      anyways, I always cut leads with my wit, sharper then ever
      • tazwegion
        • Jun 2006
        • 444
        WIT? sharp humour?
        In a pinch... right angle nail clippers do a fine job!
        Viva LA Retro!
        • Johnny P
          • 9
          Why are you cutting them again? Don't youz guys use a solder sucker?
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Originally posted by tazwegion
            Well this pair of side cutters does the job for me, not remotely as nice looking as those pro'sKIT pieces, but the cut is closer than whatever the mass soldering machines (or skilled monkey's) use
            I suppose they could use some new rubber grips or heatshrink though
            Looks like mine!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • nickBcap
              • Jan 2012
              • 114
              • New Zealand
              #26
              Hi, I bought a solder sucker and loved it for removing so much solder from around the hole that the capacitors needed very little heating to remove but the most annoying thing is the fact the nozzel is always plastic which melts and the shop does not sell replaceable tips.
              Ok, so now I want to buy a pair of pro cutters, and, I dont think I will go with the fingernail cutter theory. Hopefully using a pro tool a few times is the start of a pleasant repair experience.
              Thank you for making such this helpful thread.
              • severach
                • Aug 2007
                • 1055
                Radial lead parts should be trimmed before soldering. It's faster, easier, and the work quality is much better. The lead trim length is close to the width of the blades on many wire cutters such as Harbor Freight 98410. Hold the cap even to the blade cocked back a bit to add some length. Practice results in even and perfect length cuts every time.
                sig files are for morons
                • MDOC
                  EngineeringTech
                  • Mar 2010
                  • 146
                  I never use cutters or knives to remove radial components. I use just a soldering iron and a solder wick or sucker. Apply heat to one leg, pull the cap back to pull the leg out. Then do the other leg. Then suck up the remaining solder out of the holes. No risk to board damage. This is how professionals do it. (You can also suck out the solder first before removing, but usually the leads still stick to the holes by the remaining solder, so it may take several tries.)
                  It's OK to use cutters to remove axial components. Don't use a nail cutter. Too bulky.
                  • y_not
                    Same 'ol Song
                    • Aug 2009
                    • 147
                    I was wondering if you could clarify for this "flush cutter newb".
                    It appears from the photos that they are angled for what, a 45degree cut?
                    Are they designed this way so that you do not have to hold your knuckles parallel to the board to get a parallel cut of the lead?
                    IE. This way you don't have to wrench your wrist or arm at an odd, awkward, unnatural angle. Instead, holding it more naturally, with your hand raised away from the board and your knuckles not jabbing into component leads. With the tool end now parallel to the board, instead of the handle being parallel. Letting it do the work of making a proper angle, leaving your hand comfortably away from the board.
                    Or is it the other way around?
                    Where by placing the handles of the tool parallel to the board, thus raising the cutting end up and off the board surface, so as to get a proper cut length from the component lead. Each and every time.
                    IE. The tool automatically makes the proper length each cut when used in this fashion.
                    I'm sure once could use it either way, but going against what the tool was designed for, kind of defeats the purpose.
                    Hopefully I have described this well enough to make sense.
                    How to properly apply thermal grease - Y_not's way.
                    • cheapie
                      null
                      • Jul 2010
                      • 849
                      Mainly the first way.
                      • kingsapper
                        • Oct 2013
                        • 14
                        In my opinion...
                        Cutters (Diagonal, flush, etc) should be sharp and well cared for. If you use them improperly they will damage things of course, but if you use dull banged up cutters or try and cut large or too-hard material (piano wire) with your cutters you will wreck things. So don't do that.
                        Likewise with fine-jaw pliers and tweezers. Very handy when you're using them correctly, but if they get banged up they're worse than useless.
                        Cutters should be sharp. Soldering irons should be hot. Boards/components should be clean. Always solder-cap cut leads.
                        And moreover, the underline for all of this: Care should be taken!
                        cheers,
                        KS
                        • farman
                          Banned
                          • Aug 2013
                          • 2
                          • ksa
                          #32
                          thankssssssssssssssss
                          • chozo4
                            Nothing Special
                            • 134
                            I've been guilty of using these for the purpose of lead cutting post-solder. They work well but can be tough on thicker leads due to not enough leverage from their small size. That's where proper cutters come into play.
                            Even crap caps can be useful... such as blank rounds for prop gunfights.
                            • rhomanski
                              nowhere man
                              • 5157
                              • U S of A
                              #34
                              I was issued a pair of diamond flush cutters at work in 1990. I've used them until last week when I ordered a pair of xcelite. The diamonds got to were they wouldn't cut tie cord anymore. Never had a problem, it's called skill and common sense. Well I did cut a couple wires in two here and there, always happens. I had to crawl up in a real hard spot in the nose of a MD-80 one time because someone cut one phase to the standy horizon. It was laying over on it's side. I got it spliced though. Stood it right up.
                              sigpicThe Sky Is Falling
                              • Aussie Max
                                • Apr 2020
                                • 8
                                Brilliant you know your stuff
                                Graeme
                                  Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                                  The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                                  Securing a good thermal interface between...
                                  10-07-2024, 04:35 AM
                                • jeremy96
                                  PS4 Power Button Traces
                                  by jeremy96
                                  Hi everyone,
                                  I recently bought a used PS4 and discovered that the power button is broken. Upon closer inspection, I found that the traces for the power button on the PCB are damaged and torn.
                                  Does anyone know where these traces lead or have any advice on how to repair them?
                                  Thanks in advance for your help!​...
                                  05-26-2024, 05:01 AM
                                • ktmmotocross
                                  can i see actual traces in BV or how to see it?
                                  by ktmmotocross
                                  guys can i see actual traces in BV or how to see it?
                                  09-10-2025, 01:41 AM
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • MegaZAC
                                  Onkyo TX-SR805 noise in one channel
                                  by MegaZAC
                                  Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                                  Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                                  There's some logic behind it. As soon as I select an input I get only left...
                                  04-23-2025, 10:09 PM
