HP6735s "invalid serial number", bios needed
  • scudd12
    • Aug 2016
    • 1
    Re: HP6735s "invalid serial number", bios needed
    Originally posted by dj_ricoh
    try this
    type in folder NbDmiFit
    and good luck
    Have a hp probook 6560b and I tryed the nbdmifit and it didn't work, I execute everything in the file while in dos. Suggestion ?
    • rioreno
      • Feb 2009
      • 540
      • Indonesia
      cek this read carefully and try, better using usb dosboot...
      hxxp://files.elektroda.net/514680,hp+dmi+toolkit.html
      • gidinho
        • Oct 2016
        • 3
        Guys,
        I got this message. Any suggestions?
        I believe I am close to be able to finaly tattoo again the serial number and the product model.
        • gidinho
          • Oct 2016
          • 3
          People. Please, enlighten me. =(
          • razu
            • Jan 2015
            • 218
            • Bangladesh
            Why you guys change bios serial number ...........can any one please tell me details.................
            • cyberhack
              • Feb 2013
              • 466
              • Uk
              #26
              Here is the nbdmifit -2.10 should fix most
              Product Information Not Valid
              If posted b4 please remove
              • Bollo
                • Aug 2017
                • 1
                Very thanks for the nbdmifit-tool!
                best regards
                • fyaagoub
                  • Dec 2016
                  • 269
                  • maroc
                  #28
                  thanks
                  • pappsw
                    • Nov 2017
                    • 1
                    How do I unlock MDM mode? FYI my UUID is already FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
                    • gitsfarmaz
                      Professnal tech
                      • Apr 2017
                      • 30
                      • Kenya
                      #30
                      Originally posted by ala_borbe
                      underneath that sticker is a motherboard code which is i guess 6050A2235601-MB-A03
                      all dumps i found are 2 mb.... schematics also says 2mb SST_25VF016B...
                      why not take eeprom from other non working board and put it in... its worth a try.... any 2mb spi eeprom should work
                      did you see traces of soldering when opened? maybe someone did some work before you... :/
                      hallo there i recently replaced a clients motherboard for folio 9470m, it says non committed state but bios chip is 128kb/1mb st chip but cant find right bin file for this ...see attached mobo no. and screenshot am using ch341a lack mini programmer
                      • HPuser54
                        • Mar 2018
                        • 1
                        Thank You All. I just entered the correct information on the S/N etc in the bios thanks to the DMI utilty. Worked perfect
                        • burkjavier
                          • Mar 2018
                          • 1
                          This worked for me after a LOT or searching online. Wanted to document for others. Pre-req: get all your machine info beforehand (S/N, Product # and CT #).
                          HP Elitebook 8460p, fine for many years but after a power outage it went into "Manufacturing Mode". Got past that but was having the "System Board (00A)" not found errors after that and then Windows wasn't activated anymore. This worked for me:
                          1- nbdmifit -2.10 above, built out a bootable flash drive with this, using Rufus / Freedos.
                          2- Renamed \wndmifit\FSMC.bin to SMB.bin and copied to root of flash drive.
                          3- Shut down. Hold windows key, Up-Arrow key, and the Down-Arrow key then the power button. This put my machine back into Manufacturing Mode (required for next steps)
                          4- Disable UEFI in BIOS (if used), boot directly to USB flash drive with Freedos, run the Run NBDMIFIT.BAT and followed the prompts - this didn't work earlier until I used STEP 3. When done rebooted and no more Manufacturing Mode anymore. Restore UEFI in BIOS if needed.
                          5- If seeing a "Restore Mode On" message during boot, I was able to fix that by re-running the HP BIOS update program on my device and then rebooting.
                          • chin0099
                            • Sep 2018
                            • 1
                            • Oman
                            #33
                            Originally posted by ktmmotocross
                            Solved.
                            i bad check bios id. it was 2MB, but it was corrupted. Cannot program it to end. So i took the same from HP 625 and program it. now i can see boot devices and can boot to DMI and change the sn.
                            I attach DMI with usb format tool.
                            what are the command lines for this tool
                            • xsilver
                              • Jul 2019
                              • 2
                              Thank you guys so much, just repaired my old HP Probook 6360b. I had to use the new NbDmiFit-2.09, it is a little bit different than the previous version. Was able to re-program the S/N, CT, Product # now the computer no longer gives me the "invalid System Board (00A) - Product Configuration". Learned something new and was able to repair my laptop, again thank you guys.
                              • steveadenuga
                                • Nov 2019
                                • 2
                                • Nigeria
                                #35
                                try this
                                and good luck
                                Thank You for this solution works!!!
                                • jgallardoh
                                  • Apr 2021
                                  • 1
                                  • Mexico
                                  #36
                                  You save my life, your DMI tools Work Great on my CQ41 Compaq Laptop. Thank You
                                  • creamyc12
                                    • Jul 2021
                                    • 1
                                    • Philippines
                                    #37
                                    Hi will this work on an acer predator laptop?
                                      • 21968
                                      No
                                      • rnd0pie
                                        • Oct 2022
                                        • 1
                                        • peru
                                        #39
                                        try this
                                        and good luck
                                        thankss!!!
                                        • Alexpetra54
                                          • Aug 2023
                                          • 1
                                          • Nigeria
                                          #40
                                          Originally posted by thesleepwalker
                                          thanks for the tool bro
                                          hey bro did it work with your hp 9470m? Please help me with the process
                                          • Wahaz
                                            by Wahaz
                                            10-30-2023, 08:42 PM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • techlab
                                            HP Elite Dragonfly Bios Crashed - HELP NEEDED
                                            by techlab
                                            Hi Guys,
                                            Looking for some help with an HP Elite Dragonfly.
                                            The customer explained it was updating the BIOS, the flashing completed, but afterwards the laptop wouldn’t power back on.
                                            • The laptop has no power but does take the correct voltage.
                                            • It shows 5 flashes white/amber, which indicates a BIOS issue.
                                            • I backed up the original BIOS to extract the feature byte etc.
                                            • I then flashed the BIOS with a clean version from HP’s website, but the laptop still gives 5 white/amber flashes.
                                            Just wanted to pick your brains on this — has anyone come across this before or...
                                            08-29-2025, 05:29 AM
                                          • TacticalFahrrad
                                            [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                            by TacticalFahrrad
                                            Hi everyone,
                                            I'm trying to recover a Fujitsu Lifebook E5513 (most likely 2023 model) that was bricked during a BIOS update. The update was interrupted (probably due to power loss), and now the laptop is stuck in a boot loop showing "PBB rollback" / "SBB rollback" messages.
                                            BIOS access (F2) and Boot Menu (F12) are no longer possible – the system instantly reboots after the rollback messages.
                                            I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                            06-30-2025, 04:09 AM
                                          • jbonavita
                                            by jbonavita
                                            Some issues
                                            Things I tried
                                            04-29-2025, 09:38 PM
