HANNS G HZ281 White Screen
  • rrflorida
    • Aug 2018
    • 12
    Re: HANNS G HZ281 White Screen
    Oh, that's a nice spreadsheet - thanks for the pointer. It indicates the tcon board is bad, but to check the panel first before replacing the tcon board. I'll search around the forum for how to do that.
    • rrflorida
      • Aug 2018
      • 12
      Well, I'm not sure how to test the panel itself - I jiggled all the ribbon cables to the driver boards with no effect. Looks like there is no availability for this tcon board, so I'll need to attempt to diagnose and repair the one I have. The u102 transistor (circled in red) measures 7.3k Ohms middle to right leg, and 100 Ohms middle to left leg.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Good find.
        But left leg is the input, so 100 Ohms is not necessarily a problem.
        That said, see what voltage is coming to the left leg of U102 (with respect to ground) and what voltage it is outputting on its right leg (again, with respect to ground).
        Also, could you please tell us what part number is written on U102?
          That is Voltage regulator IC, not transistor. See what Voltage you have on Vin and Vout pin.
          I suspect the GAMMA Voltages are generated by U300, 301, get the P/N on both of them.
          BTW, designator for Transistor is 'Q??', IC is U??
          • rrflorida
            • Aug 2018
            • 12
            momaka and budm - thanks for the responses, really appreciate the help! I will gather the requested info Monday. Sorry for the delayed reply, was out of town.
            randy
            • rrflorida
              • Aug 2018
              • 12
              U102 is a 960T45. Left leg is 4.96V, right leg is 3.24V
              U300 and U301 are both BUF 07704, which Mouser says is a LCD Gamma Buffer.
                960T45 is 3.3V regulator, it is OK. https://cdn.badcaps-static.com/pdfs/...2741533542.pdf
                GAMMA chips may be bad, need to look up spec sheet.
                • rrflorida
                  • Aug 2018
                  • 12
                  Data sheet for BUF 07704 attached
                    So now you have the spec sheet of the IC showing what each pin is for, start checking the Voltages and report the reading for each pin, that will be a starting point.
                    • rrflorida
                      • Aug 2018
                      • 12
                      Below and attached (the formatting is messed up here in the post) are the voltage readings from the BUF07704 chips. The OUT side seems to correlate pretty well with the IN side.
                      Pin U301 U302 Name
                      1 13.13 0 VDD
                      2 12.46 6.55 OUT1
                      3 10 5.31 OUT2
                      4 9.29 4.34 OUT3
                      5 8.9 3.78 OUT4
                      6 8.11 3.07 OUT5
                      7 6.76 0.64 OUT6
                      8 0.12 0 NC
                      9 5.47 7.21 OUTCOM
                      10 0 0 GND
                      11 0 0 GND
                      12 5.45 0.63 INCOM
                      13 0.76 0.65 NC
                      14 6.75 0.64 IN6
                      15 8.11 3.07 IN5
                      16 8.89 3.78 IN4
                      17 9.29 4.34 IN3
                      18 9.99 5.31 IN2
                      19 12.45 6.56 IN1
                      20 13.13 13.14 VDD
                        https://www.badcaps.net/forum/attach...3&d=1536778904
                        Look at INCOM and OUTCOM of U302: U301 INCOM is 5.45V, OUTCOM is 5.47CV, but U302 INCOM is 0.63V and the OUTCOM is 7.21V
                        Look at pin 1 of U301 and 302: 0V on U302?
                        • rrflorida
                          • Aug 2018
                          • 12
                          Oh, I messed up pin 1 on U302 (VDD) - it's actually 13.13V, so ok there.
                          I see what you are saying on INCOM/OUTCOM on U302. I just double checked:
                          12 INCOM: .64 steady
                          9 OUTCOM: climbs from 1-3 volts up to 6-7 volts everytime I probe it (climbs for about 30 seconds)
                          Are you suspecting U302?
                          [NOTE: I somehow started using the wrong U numbers, but will stick with the current U301/U302 for consistency]
                            Yes, I expect U302 to behave the same as U301, it is buffer after all.
                            • rrflorida
                              • Aug 2018
                              • 12
                              Ok, I will attempt to replace the chip and report back. Thanks.
                              • rrflorida
                                • Aug 2018
                                • 12
                                fyi - having trouble finding the part - Mouser just cancelled the order and said it is discontinued. More later..
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  • Bulgaria
                                  #36
                                  Maybe check with eBay. Sure there's a chance the part you get may not be genuine or high quality, but it could work fine. I've bought PWM controllers for motherboards before, and they worked okay. It's really only the high-power devices (MOSFETs, BJTs, and those STK stereo modules) that you want to either stay away from or use with lots of caution.
                                  That, and the slow wait for the part to arrive from the far factories and shops of East Asia.
                                  • Capt. Cap
                                    • Oct 2017
                                    • 40
                                    • US of A
                                    #37
                                    Doesn't look like any reliable retailers have it available in small order quantities https://octopart.com/search?q=buf07704&start=0
                                    but you can get a single BUF07704 chip here
                                    Probably not the real thing, but like momaka says, it may work well enough.
                                    Let us know how it goes, I could be in the market for one myself soon
                                    • rrflorida
                                      • Aug 2018
                                      • 12
                                      I ended up using eBay seller dicikey-max. We'll know more in 12-50 days.... Thanks for the suggestions
                                      https://www.ebay.ie/itm/332274532555...m=332274532555
                                      • harp
                                        White screen repairs
                                        by harp
                                        To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                                        Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                                        On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                                        05-13-2024, 03:43 AM
                                      • Ryan.man
                                        by Ryan.man
                                        02-04-2025, 12:23 PM
                                      • EazyBone
                                        Sharp LC-65Q620U White Screen
                                        by EazyBone
                                        Another TV topic!!
                                        I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                                        The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                                        Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                                        08-21-2024, 12:56 PM
                                      • hcinne
                                        Dell G15 ryzen edition black screen 2 amber 1 white
                                        by hcinne
                                        I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                                        07-23-2024, 07:56 AM
                                      • Chrissygizmo
                                        Panasonic TX-48CX350B backlights but white screen , blank screen
                                        by Chrissygizmo
                                        Hi all, I’ve got a problem I hope someone can help me fixi.
                                        I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
                                        01-11-2025, 03:18 PM
