Sharp LC-60SQ15U TV DPS-167CP - No power
  • Hcarter
    • May 2017
    • 5
    • US
    Re: Sharp LC-60SQ15U TV DPS-167CP - No power
    Sorry for the delay, I just saw your message. The diode is an SB2100, Digikey Part Number 1655-1516-1-ND. I have 9 extra and would be happy to mail you a few for free.
    • Hcarter
      • May 2017
      • 5
      • US
      The diode is an SB2100, Digikey P/N 1655-1516-1-ND.
      • amoore1952
        • 3
        Originally posted by budm
        Check fusible resistor R7900 (2.2 Ohms) to see if it is open.
        IC7903 is the STBY SMPS IC which drives the power transformer T7901, D7950 is the rectifier diode on the Cold side.
        You should run the power supply board by itself to see if you do have STBY Voltage or not.
        HI, new to site. I am basic electronics skill. I heard a pop in the back of my sharp lc-60le650u tv last night. indicator light flashes 2 long 2 short which I think means 13V line on power supply bd and I have no picture. took off back of tv looking for bad cap or something obvious but everything "looks" ok. any ideas where to look or what to check.
        • amoore1952
          • 3
          sorry it has dps-167cp a power supply board in it.
          • amoore1952
            • 3
            I don't have access to sharp dps-167cp-a schematic but C7818 has blown on my board and I can't tell what the values are on it. Can you help me with a part number?
              Can I see good clear picture of this cap and its location?
                OK, I found pictures at shopjimmy.
                C7818 is a snubber cap for the PFC Diode D7805, its typical value is about 220 pf 1KV, but I always replace it with 2KV rating instead, it is commonly failed caps in Samsung power supply also.
                • johnz
                  • Jan 2012
                  • 66
                  Do you know the part number to the resistor R7900 or if some one knows the part #..?? Thanks.
                  • R_J
                    • Jun 2012
                    • 9594
                    R7900 seems to be 2R2Ω .5w If it is open I suspect that IC7903 is defective.
                    I see caps similar to where C7818 is located as 470pf 2kv
                    • johnz
                      • Jan 2012
                      • 66
                      I have the IC7903 but i don't know how to order the R7900 on digikey..its red, red, gold gold, silver. Thanks.
                      • johnz
                        • Jan 2012
                        • 66
                        Ok I got it working.. Thanks everyone for showing me where to start.
                        • veekay
                          • Aug 2021
                          • 2
                          • US
                          #32
                          Sorry to necro an old post, but felt it might be better to keep relevant info in the same spot.
                          Ran into the same issue with my TV over the weekend. Zero power, lights, nothing on standby, etc.
                          D7950 tested as bad, so I have ordered a replacement for that.
                          Decided to check the other things recommended here, but am stumped on how to tell if IC7903 is bad. Still pretty new to this.
                          Like egoh I get high voltage (165.3v) on pins 8 and 7, but my pin 5 gets 9.6v. Pins 1 and 2 are .2mv and pin 4 is 10.2mv.
                          On R7900 I am getting 2.7-3ohm when powered off, and higher when on. The resistor also has continuity.
                          • veekay
                            • Aug 2021
                            • 2
                            • US
                            #33
                            Well little update, replaced D7950 and R7900 and the TV is back to life. After replacing R7900 pin 5 jumped up to around 15-16V.
                            • lechugaAmir
                              • Aug 2016
                              • 19
                              • Mexico
                              #34
                              Hola amigo me pasa mismo 5.8v muy bajo varias cambie ic que va solución?
                              • romasik
                                • May 2022
                                • 56
                                • Ukraine
                                #35
                                Hello, please help me i have same problem on my Sharp Aquos 60LC635E No 5V power, tv dead . Blown R7900 and short D7950 . I changed it, than blown R7900 again . D7950 ok. I change IC7903 and cap on 5 leg 50V 47u and R7900 never blown again but 5V not( I do not know what to do . On big two cap 315V, on 5 leg IC7903 9V this very low for start A6069H . Datasheet say min 13V.
                                Please Help me. board power supply dps-162KP B RUNTKA932WJQZ
                                • romasik
                                  • May 2022
                                  • 56
                                  • Ukraine
                                  #36
                                  Please help me frend
                                  • dskall
                                    • Oct 2016
                                    • 2905
                                    • usa
                                    #37
                                    Check caps. and resistors on pin 5.
                                    • nomoresonys
                                      • 12284
                                      • U.S.
                                      #38
                                      maybe check c7901, c7907, c7818, d7805.
                                      • nomoresonys
                                        • 12284
                                        • U.S.
                                        #39
                                        wonder if you received faulty IC7903 or if it has gotten damaged.
                                        • romasik
                                          • May 2022
                                          • 56
                                          • Ukraine
                                          #40
                                          I check, they seem to be ok
                                          what do you mean? A6069H defective? was my marriage sold?
