Macbook Pro A1278 820-3115-B bio bin
  • peste
    • Dec 2016
    • 13659
    • ROMANIA
    Re: Macbook Pro A1278 820-3115-B bio bin
    Originally posted by martha februarini
    Hy Peste, can you help me repair this bios ?
    thanks
    try..
    • Bonzas
      • 474
      • Indonesia
      Still No Display and fan spinning faster than before
      • peste
        • Dec 2016
        • 13659
        • ROMANIA
        post serial number S/N
        • gpatadia
          • Sep 2015
          • 15
          • India
          can you help me?
          please remove password from this file
          • peste
            • Dec 2016
            • 13659
            • ROMANIA
            Originally posted by gpatadia
            can you help me?
            try..
            • gpatadia
              • Sep 2015
              • 15
              • India
              #26
              thanks its working
              • Qbanastyle
                • Jun 2020
                • 6
                • Polska
                #27
                Hello! Help needed with bios password removal. Thanks in advance!
                • peste
                  • Dec 2016
                  • 13659
                  • ROMANIA
                  #28
                  try..
                  • Qbanastyle
                    • Jun 2020
                    • 6
                    • Polska
                    #29
                    Sorry, but not working. Fan spinns, black screen... Any idea?
                      • 21984
                      Is the bios the original backup or one you found on the forum.Post the serial number on the case
                      • Qbanastyle
                        • Jun 2020
                        • 6
                        • Polska
                        #31
                        Should be original but someone has already played with the bios. SN from case
                        C1MM61PHDV30
                        • peste
                          • Dec 2016
                          • 13659
                          • ROMANIA
                          #32
                          C1MM61PHDV30
                          S/N is ok .... try this ..
                          if it doesn't work, post the full name and model of the laptop, EMC, and motherboard model.
                          • Qbanastyle
                            • Jun 2020
                            • 6
                            • Polska
                            #33
                            Thank You SMDFlea and peste for Your support! It turned out that two from three bios chips I have where damaged. The third one took the bios without any errors and is up and running!
                            • String2016
                              • Nov 2015
                              • 2238
                              • philippines
                              #34
                              Macbook a1278
                              Can someone fix this bios please, the problem is cannot installed os when,I press the options on keyboard at startup cannot detect installer it goes directly to apple
                              • String2016
                                • Nov 2015
                                • 2238
                                • philippines
                                #35
                                Re: Macbook a1278
                                Anyone can help fix the bios please
                                  • 21984
                                  Re: Macbook a1278
                                  Find a 820-3115-B bios with clean ME firmware (post #32 seems ok) ,then edit it with your serial number (the one on the bottom case) and modify the fsys checksum.Watch piernovs video how to do it
                                  https://www.badcaps.net/forum/showpo...43&postcount=5
                                  4. DMI editing by brand
                                  4.3. Apple
                                  For 2017 and older machines, serial number is stored in Fsys store of BIOS and can be edited with hexadecimal editor. Fsys checksum needs to be fixed afterwards
                                  Search for "ssn", edit the serial number, save, open dump in UEFITool, go to the Fsys store and write down the suggested checksum in the panel on the right. Checksum is 4 bytes at the end of the Fsys store, between one zone of 0x00 either Gaid or another zone of 0xFF, it must be written in reverse order (so last 2 characters from UEFITool must be written first).
                                  See: https://www.youtube.com/watch?v=poA8HByYqTM
                                  • peste
                                    • Dec 2016
                                    • 13659
                                    • ROMANIA
                                    #37
                                    Re: Macbook a1278
                                    try..
                                    • String2016
                                      • Nov 2015
                                      • 2238
                                      • philippines
                                      #38
                                      Re: Macbook a1278
                                      Originally posted by peste
                                      try..
                                      already tried but still same issue pressing alt options on startup not showing installer, already tried command + r for recovery not showing up
                                      • andresi
                                        • Nov 2020
                                        • 154
                                        • INDONESIA
                                        #39
                                        can you unlock my bios? macbook pro 2012
                                        • Vesko356
                                          VIP Moderator
                                          • Aug 2018
                                          • 4386
                                          • Bulgaria 🇧🇬
                                          #40
                                          Become a Badcaps supporter
                                          Thanks to all supporters.​
