Lenovo Yoga 2 Pro Lenovo nm-a074 schematic and boardview
  • flankerzo
    • Sep 2018
    • 7
    • Nitra
    Re: Lenovo Yoga 2 Pro schematic and boardview
    i have been too optimistic with swapping lcd
    and i now know story behind yoga 2 pro death, previous owner ,,repaired,, adapter and notebook died on over voltage, it lived short on battery, then died
    • alibatam
      • Jul 2016
      • 19
      • indonesia
      THANKS
      • emr2000
        • Mar 2015
        • 17
        • turkey
        Originally posted by snsent
        try this..
        thank you
        • pp3v3hot
          • Aug 2019
          • 2
          hi all im dealing with a dead board on a Yoga 2 Pro i5 8gb Ram model that i accidentally tried to plug in the little "connector" that connects the motherboard to the daughterboard while i still had the AC power adapter plugged in (newbie mistake!) i was rushing, and tired.
          luckily this is a personally device and not a customers device.
          im hoping to repair it, not sure i have the same board posted in the archive or PDF on page 1 however.
          can someone help me identify if this is the correct board as posted in the literature above or if i'm SOL?
          Here's the set of images:
          https://imgur.com/a/HZ0Woju
          • Delwar
            • Jan 2019
            • 8
            • bangladesh
            thanks
            • MAZMAZ22
              • Jul 2016
              • 68
              • ALGERIE
              #26
              Voir cpu
              • gerardo
                Engineer
                • Feb 2016
                • 59
                • Argentina
                #27
                Try this..
                Thank you!
                • gerardo
                  Engineer
                  • Feb 2016
                  • 59
                  • Argentina
                  #28
                  thank you!
                  • lindsayp133
                    • Apr 2020
                    • 7
                    • Mauritius
                    #29
                    HiThere,
                    I'm new for the forum, I got the same problem with the Lenovo 2 pro.
                    Do you still have the solutions?
                    For my case same problem mile yours but the fan start and stop for every 2 mins.
                    Thank you so much for your feedback
                    Regards
                    Lind
                    • jackpot508
                      • Mar 2021
                      • 1
                      • indonesia
                      #30
                      Try this..
                      thanks in advance
                      from new member
                      • sekhar.india
                        • Jun 2021
                        • 11
                        • Singapore
                        #31
                        Need Lenovo Yoga 2 pro 13 NM-A074 boardview
                        Hello, I have Lenovo Yoga 2 pro 13 with i7 4500U processor and 8GB RAM. I do have the schematic KONA NM-A074.
                        The laptop is working fine with bluetooth keyboard and mouse, but not with attached ones. At the startup The backlit LED of keyboard is ON, but later is not working. I have tried all windows based setting and now looking for HW debug.
                        I am looking for boardview file for KONA NM-A074, as unable to find the resistor locations. Please share if any one have.
                        If any one resolved similar issue, suggest the way forward. Thanks.
                        • mon2
                          • Dec 2019
                          • 14634
                          Re: Need Lenovo Yoga 2 pro 13 NM-A074 boardview
                          Which resistors ?
                          • sekhar.india
                            • Jun 2021
                            • 11
                            • Singapore
                            #33
                            Trying to find R313, which is supplying 3V to the keyboard matrix at JP9 connector.
                            • sekhar.india
                              • Jun 2021
                              • 11
                              • Singapore
                              #34
                              Do you have the boardview? The board silk print only have very few components listed.
                              • mon2
                                • Dec 2019
                                • 14634
                                Only the top and bottom silk screen files.
                                • sekhar.india
                                  • Jun 2021
                                  • 11
                                  • Singapore
                                  #36
                                  By chance, do you have any resistors listed? If possible please share. Many thanks.
                                  • mon2
                                    • Dec 2019
                                    • 14634
                                    Re: Lenovo Yoga 2 Pro Lenovo nm-a074 schematic and boardview
                                    Unable to locate it on the silk screens but check near the JP9 connector.
                                    To the right side - since the R313 mates with pin # 2, it should be close by.
                                    Otherwise, post clear and zoomed up pics of the JP9 connector and nearby parts.
                                    • sekhar.india
                                      • Jun 2021
                                      • 11
                                      • Singapore
                                      #38
                                      I have checked all the near by parts. I have tried to check continuity with PIN2 and surrounded components. None of them is show-up. The test pads near J9 connector show the connection. The other way I have tried to check the resistance between PIN2 and +3V on connector JP26 PIN15. No success. Any idea, which +3V rail might have connected?
                                      • mon2
                                        • Dec 2019
                                        • 14634
                                        ..post clear and zoomed up pics of the JP9 connector and nearby parts.
                                        • sekhar.india
                                          • Jun 2021
                                          • 11
                                          • Singapore
                                          #40
                                          Here are the closer look at J9 and the other side of the PCB at J9.
