Apple MacBook Pro A1502 (820-3476-A)
  • lepi0101
    • Nov 2021
    • 1
    • Bosna and Herzegovina
    Re: Apple MacBook Pro A1502 (820-3476-A)
    Originally posted by SMDFlea
    Try this one.
    Hello
    I need new clear bin file for
    Macbook pro mid 2014
    a1502 emc 2875
    I've bought used macbook and when it came it was message
    "Disabled, try for 60 minutes"
    So please help me.
    • magneh
      • Apr 2014
      • 602
      • Portugal
      Hello all!
      Got a 3476-A that turns on but shuts down 30 secs after.
      Bios is corrupted.
      Can someone Clean ME ?
      Heres the original.
      Thanks!
      • peste
        • Dec 2016
        • 13185
        • ROMANIA
        Originally posted by magneh
        Hello all!
        Bios is corrupted.
        Heres the original.
        Thanks!
        what EMC ???
        • magneh
          • Apr 2014
          • 602
          • Portugal
          Originally posted by peste
          what EMC ???
          Hey Peste!
          Its A1502 (EMC 2678)
            • 21444
            Hey Peste!
            Try this bios https://www.badcaps.net/forum/showpo...54&postcount=5 ,edit your serial number into it first though and modify the Fsys checksum
            https://www.youtube.com/watch?v=poA8HByYqTM
            • reformatt
              • Feb 2020
              • 1442
              Attached is the latest BIOS version for this board (V432.60.3.0.0) with Clean ME after a recent repair I did (this is from Big Sur 11.6.5). I've altered the serial number slightly so you'll need to modify this and the Fsys block checksum to use this as a donor. PRAM reset also required after installation.
              • TrumanHW
                TrumanHW
                • Jun 2021
                • 52
                I know the Fsys is located at 0x590000 ...
                and I have a tool that fixes it for me.
                But how do you do it manually !? I used VBinDIFF and TONS of the BIN differed
                to where I couldn't isolate what really mattered conveniently. Would appreciate the info if you can...
                PS,
                Love this forum; they really should consider adding a "like" button
                so when people do generous things for others like posting old EFIs ...
                people like me can say 'thanks'.
                • peste
                  • Dec 2016
                  • 13185
                  • ROMANIA
                  #28
                  PS,
                  https://www.badcaps.net/forum/showthread.php?t=88533
                  • piernov
                    • Jan 2016
                    • 4437
                    • France
                    #29
                    https://www.badcaps.net/forum/showpo...43&postcount=5
                    • TrumanHW
                      TrumanHW
                      • Jun 2021
                      • 52
                      Thanks guys, I'll go read that. (Much appreciated)
                      • TrumanHW
                        TrumanHW
                        • Jun 2021
                        • 52
                        AWESOME !!!! YOU GUYS ARE EFFING AWESOME !!!
                        I found a tool called
                        UEFITool ...
                        Which parses a BIN out as shown
                        (note, it will open an EFI .bin but not a T2 ROM's .bin)
                        Navicated to:
                        Intel image --> BIOS Region --> EfiSystemNvDataFvGuid --> Fsys Store
                        Located in the right hand pane...
                        Which'll tell you if the CRC32 is valid.
                        Terminal: CRC32 [dragged entire bin]
                        Results (as shown) completely wrong.
                        Extracted a BIN (as shown) of just the Fsys region.
                        Apply CRC32 to just the Fsys section (same terminal process)...
                        It was the same code (as shown in image) as that which was "valid".
                        (for others, the "h" at the end (or x0) just means the format is Hex)
                        • Shevy57
                          • Feb 2020
                          • 6
                          • uganda
                          #32
                          Originally posted by johnnybeast
                          Hey mate, this saved my life. I wish you could teach me
                          Try this file, I had to use this to get a Fledging SSD working on a Macbook Pro that was running 0138 EFI Bootrom.
                          This is EFI Bootrom revision 0151 for the 820-3476 A1502 MacBook Pro 2013/4. The ME Region is clear on it and there's no passwords set.
                          You must us a HEX Editor to change the serial number at block 63043B, it's currently set to 11111111111 so it will NEED to be changed.
                          Also, within the first few boots you will need to reset the PRAM, which is holding the P, R, ALT (Option) and CMD buttons before pressing the power button and keep holding the 4 buttons till you hear the second 'bong'. This will flush any stored passwords in the NVRAM/PRAM.
                          Hope this helps somebody out as much as it helped me.
                          • 2011dandela
                            • Apr 2015
                            • 36
                            • algeria
                            #33
                            Please help me to reset efi code a1502 820-4924-a
                            • peste
                              • Dec 2016
                              • 13185
                              • ROMANIA
                              #34
                              the bios is corrupted.. make another copy and post again..
                              • 2011dandela
                                • Apr 2015
                                • 36
                                • algeria
                                #35
                                I lost original dump possible try another dump
                                • peste
                                  • Dec 2016
                                  • 13185
                                  • ROMANIA
                                  #36
                                  post EMC and S/N..
                                  • 2011dandela
                                    • Apr 2015
                                    • 36
                                    • algeria
                                    #37
                                    post EMC and S/N..
                                    Model aa1502
                                    emc2835
                                    sn c02pv3b5fvh3
                                    2011dandela is online now Report Post
                                    • peste
                                      • Dec 2016
                                      • 13185
                                      • ROMANIA
                                      #38
                                      Model aa1502
                                      emc2835
                                      sn c02pv3b5fvh3
                                      try..
                                      • 2011dandela
                                        • Apr 2015
                                        • 36
                                        • algeria
                                        #39
                                        try..
                                        think you peste itS working
                                        iwant other dump for 1502
                                        emc 2678
                                        serial C02LR1NHFH00
                                        • 2011dandela
                                          • Apr 2015
                                          • 36
                                          • algeria
                                          #40
                                          try..
                                          dump for 1502
                                          emc 2678
                                          serial C02LR1NHFH00
