Asus Q502L does not boot up properly
  • tibimakai
    • Jan 2012
    • 3680
    Re: Asus Q502L does not boot up properly
    I have unsoldered it.
    TL866 it is updated, 671 version and the firmware as well. W25Q64FV
    • tibimakai
      • Jan 2012
      • 3680
      Here it is my serial number: F4N0BC05247717B
      • tibimakai
        • Jan 2012
        • 3680
        cacla, those files don't look bin files. I would have to rename it, as .bin file?
          • 21986
          You don`t have to change it to .bin ,the programmer will read the file as is. Your bios chip is a W25Q64FV(SIQ) , if you get any errors reading or verifying ,program it again with QE = 1 S9 QUAD ENABLE ticked under the config tab .
          • cacla
            • Apr 2015
            • 444
            They are fine trust me
            • tibimakai
              • Jan 2012
              • 3680
              Cacla, which one should I use? On the Asus site, the 206 is the latest Bios.
              • tibimakai
                • Jan 2012
                • 3680
                What is interesting, when I check the ID( 0xEF 40 17) of the IC online, it shows as a W25Q64CV.
                Should I chose the basic W25Q64FV, and not the SOIC8 or such options, right?
                • tibimakai
                  • Jan 2012
                  • 3680
                  I have tried the 209 version and did not work, just the power and HDD LEDs keep blinking.
                  If I place the IC into the programmer and I "Verify" it, it shows this message after it's done: Verify Result(differencequantity): 5238952. This is a message in red. This is bad or OK?
                  I will try, the 206 version now.
                  I'm not measuring anything at this time, but some of the coils are getting pretty warm(3.3V & 5V).
                  • tibimakai
                    • Jan 2012
                    • 3680
                    I have tried 206 as well and I get the same thing, it seems like it is trying to turn on, but it is in a reboot loop.
                    I have measured the 3.3V and 5V and when it reaches these voltages, drops to 2.3V respectively, to 3.4V. After a couple of seconds, it turns off(0V) and the cycle restarts. No voltage is present, at the 1.8V CPU.
                    The ICE chip could be faulty?
                    I'm wondering, how come everything has changed, after I have removed the BIOS chip?
                      • 21986
                      Program the bios with the part number on top of the chip. If your getting any sort of error its A. Not seated properly in the adapter B. The programmer is faulty C. The bios chip is faulty. D. You`re not programming with the correct settings .
                      The W25Q64CV supports dual and quad SPI The W25Q64FV supports dual ,quad and QPI
                      Try it with QE = 1 S9 QUAD ENABLE ticked under the config tab . If that doesn`t work try it with quad enable unticked ,and check id unticked and choose W25Q64FV
                      • tibimakai
                        • Jan 2012
                        • 3680
                        I'm not getting errors. Every time shows a succesful result.
                        After I try the chip in the laptop, when I place it back in the programmer and I hit Verify, than I get that red message. But I don't know if it is an error, or not.
                          • 21986
                          If youve got the options ticked to erase before,and verify after thats ok. When you put it back in the programmer why hit verify again ? . You only need to program and verify once.
                          • tibimakai
                            • Jan 2012
                            • 3680
                            I was just curious.
                            So, if the flash is OK, than what is happening with my laptop?
                            What I have noticed previously touching it and now, that with the AC adapter is in a reboot loop and with the battery, wants to start only once.
                              • 21986
                              The bios provided by @cacla are ok. Did you replace the cap with the ferrite bead . 3.3v and 5v voltages are up ,you need to know which IC generates 1.8v . It would really help if you could get the boardview.
                              • tibimakai
                                • Jan 2012
                                • 3680
                                The question which BIOS should I have on the chip? He asked for the serial number, which I have provided on the first page.
                                It would be a good start, to have the right BIOS.
                                The 3.3V and 5V are up, but they are keep shutting down, so most likely something is causing that. They are warm at touch as well.
                                I would need that password, for the boardview.
                                  • 21986
                                  Which IC is generating 3.3V and 5V. I`ve already PM`ed you about the boardview,so you know there`s other alternatives.With the boardview you`ll find the right value ferrite bead replacement, and we`ll know what IC is controlling what.
                                  • tibimakai
                                    • Jan 2012
                                    • 3680
                                    I have checked the voltages, at the coils.
                                    I have purchased the boardview file, but how can I upload it here?
                                    • tibimakai
                                      • Jan 2012
                                      • 3680
                                      OK, here it is the rar file.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        I'm at work, so I don't have setup, the boardview software yet.
                                        • tibimakai
                                          • Jan 2012
                                          • 3680
                                          The ferrite bead is L4510, by the LVD connector(first on from the right).
                                          P.S. I have managed to open PCBRepair Tool software.
                                          • throwaway327
                                            Asus ROG Ally X -RC72LA - changed hidden bios settings with 'Smokeless-UMAF', won't get past boot logo
                                            by throwaway327
                                            ASUS ROG Ally X - (Handheld Gaming PC)
                                            Model No: RC72LA
                                            Serial No: SBNVKD001014459
                                            Hi all, I've spent the past week digging through the forums and guides to try correct my foolish mistake of changing hidden settings while tinkering around, and to be honest my heads overloaded so I'm hoping you'll be able to help.
                                            I used a tool called 'Smokeless-UMAF' to access usually hidden settings in the bios. I tweaked one or two 'safe' things but made the mistake of tweaking a lot of settings under 'USB/Thunderbolt Configurations' when I didn't know what they did. For...
                                            06-18-2025, 05:52 PM
                                          • jrodefeld
                                            Asus laptop won't boot (no power) - possible bad caps?
                                            by jrodefeld
                                            I would like to see if anyone could help me salvage a very expensive laptop that is no longer working.
                                            The model:
                                            Asus Zenbook Pro Duo UX582L
                                            I have used this laptop lightly since I purchased it new in 2022. I have always taken precautions to take care of it the best I could, and have never done anything that would risk causing damage to it or shorten it's life.
                                            However, around six months ago, the laptop stopped working on battery power. It continued to work fine when plugged in, but as soon as power was disconnected,...
                                            09-02-2024, 04:55 PM
                                          • acata
                                            Asus X450LC REV 2.2 can't boot to anything
                                            by acata
                                            I get this Asus X450LC REV 2.2 can't boot from SATA, ODD or USB flash drive.
                                            Power on normally. Boot to bios ok.
                                            But I can't normal boot from HDD (windows 7) just freeze on the animation. I can't boot from pre-installed SSD windows 10, bsod: driver pnp watchdog. I can't boot USB flash drive Hiren boot CD or linux mint.
                                            10-10-2023, 05:15 AM
                                          • lukkihapsi
                                            Asus Vivobook X515JA Weird Boot Issue
                                            by lukkihapsi
                                            Asus Vivobook X515JA Laptop
                                            Issue :
                                            Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                            Tried :
                                            Cleaned inside for dust, applied fresh thermal paste. No Change!
                                            Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                            Removed Internal SSD. No Change!
                                            Updated BIOS to latest version. No Change!
                                            Removed battery and pressing power button for 1 minute. No Change!
                                            Weird Part :
                                            Upon turning laptop ON, screen lights up - stays black,
                                            I...
                                            07-07-2025, 12:07 PM
                                          • futadmytro
                                            Asus g713qm-es94 stuck on boot bios problem
                                            by futadmytro
                                            sn^M4NRKD02753616E
                                            MB- g533-6050a3250201-MB-A03
                                            Stuck on boot after ROG logo, did not enter to bios
                                            In flash bios , laprop boot but have video issue
                                            orig bios...
                                            06-25-2025, 08:07 AM
