Please Remove Password In Panasonic CF Bios Dump
Re: Please Remove Password In Bios Dump
One More File
thanks youAttached Filesif you find these attachements useful please consider making a small donation to the site
sorry long time not login... maybe you or someone still need this file...
goodluck and please confirmAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi,rioreno.
Sorry for the sudden message.
I'd like to remove the bios password of a CF-AX2.
Can I remove it?
thank you.Attached Filesif you find these attachements useful please consider making a small donation to the site
1. Your file is not full bios (bios region only, no meregion etc), use the SPIprogrammer to backup your bios ..
2. Even though the password is in biosregion and i can remove it, but I'm not sure you can flashing that file without spiprogrammer.
3. The correct way is to read and write back the file using spiprogrammer...
4. If you are still curious you can try it without a SPIprogrammer but I am sure you will experience a failure ...Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi,rioreno!1. Your file is not full bios (bios region only, no meregion etc), use the SPIprogrammer to backup your bios ..
Thank you for answering.
I'd like to Password remove it by myself.
Would you tell me how to do?Comment
here is the answer Syamu.g.you can use uefitool or HxD.1. Your file is not full bios (bios region only, no meregion etc), use the SPIprogrammer to backup your bios ..
4. If you are still curious you can try it without a SPIprogrammer but I am sure you will experience a failure ...Comment
One More ! pleaseAttached Filesif you find these attachements useful please consider making a small donation to the site
this,,,
Panasonic CF-NX3EFRCSAttached Filesif you find these attachements useful please consider making a small donation to the site
One More, thanks youAttached Filesif you find these attachements useful please consider making a small donation to the site
Hi Rioreno,
Sorry to trouble but will I'm trying to read the my "winbond 25Q128FVSQ 1535" bios chip on my CF-SX4, I've clip the reader EZP2019 on to the chip but it detacted the chip as 93_EEPROM instead of SPI_FLASH.
is that correct and if not how can i let it read or detact the chip correctly?Comment
by outsiderHello
I removed the BIOS password thanks to the help of one of the friends of this forum.
https://www.badcaps.net/forum/troubl...61#post3637661
The batch from which the password was removed works correctly but... after some time, the BIOS password is set again, I reprogrammed the batch with the removed password, it's ok, there is no password, I set my password, ok, I can enter the BIOS with my password but...-
Channel: BIOS Requests ONLY!
by snpetitHi,
i need some help :-/
i deleted in Bios the Admisnistrator password with old password, but after it didn't allow me to modify the User password. Now i can't boot, enter the bios or do anything. It asking at boot for password, old password don't work...
Could you please remove all password related stuff from this bios. A hate Asus....
Thanks in advance!...-
by dell_biosHi everyone,
I'm working on removing an administrative BIOS lock (Supervisor/Admin Password) on a laptop.
The board has three SPI flash chips:
- W25Q64FV (main BIOS)
- W25Q32FV (EC/TPM)
- W25X10CL (configuration)
I was able to read the dump from the W25Q64FV chip, CRC32 = 0x3DE23E27.
The dump contains protection that needs to be removed.
If anyone has a clean or unlocked BIOS dump for W25Q64FV, I’d really appreciate it!
I’m also happy to share my dump for comparison if needed.
Laptop model: [please specify, e.g....-
by AhariHi all,
I...-
Channel: BIOS & Schematic Requests!
by traxformaniaHello,
I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
I'm trying to reset my bios without success.
I tried :
-I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries... - Loading...
- No more items.
