Help with dead Commodore 1802
  • R_J
    • Jun 2012
    • 9579
    Re: Help with dead Commodore 1802
    The sound (bong noise) is the degausing coil, mesure the DC voltage across the filter caps, C814 (12v) and C813 (121V) the heatsinks may not be grounded. If there are no voltages, then its time to start checking on the primary side.
    What voltage do you measure ACROSS C803? If you have voltage across C803, leave your negative meter lead on C803 negative and with the red probe check the voltage on T801 pin 4 and pin 2
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      Couldnt find C814 anywhere until i noticed it was a cap labeled as R814. Anyway no voltage across C813 & C814 and no voltage between C803 and pins 4 & 2 of T801
      • R_J
        • Jun 2012
        • 9579
        So you have 0 voltage the main filter capacitor, that does'nt leave much, Check the large 3.3Ω 10 watt resistor R801, it must be open or has cold solder connections
        • roadrash
          • Oct 2015
          • 490
          • U.K.
          R801 is open circuit and registers nothing on any scale.
          • roadrash
            • Oct 2015
            • 490
            • U.K.
            I only had a 4.7ohm wire wound resistor here and ordered some I thought were 10A 3 Ohms that were actualy 3.3ohms. Ive got another 10A 3ohm one comming and be here in a few days or so.
            • R_J
              • Jun 2012
              • 9579
              3.3Ω 10 watt not, 10 amp, the 4.7Ω would work to test if it is around 10watt
                • 31151
                R801 is probably metal oxide, not wirewound.
                a wirewound will get glowy hot instead of going open-circuit.
                smash the old one to check the insides.
                so now you need to see what made it burn!
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  #28
                  Its a large white oblong ceramic type.
                  Could it be just age and maybe being left turned on for hours because I accidently did that when I left it on overnight one night by accident. It was after that I found it dead.
                  • roadrash
                    • Oct 2015
                    • 490
                    • U.K.
                    #29
                    This is it. Is it. What type is it?
                      • 31151
                      you cant tell without breaking it, but you rarely get wirewounds used on ac because the coil radiates interference.
                      btw, the replacement needs airflow under it, what we used to do is solder the new one on top of the dead one so it still stands high off the board.
                      that or use ceramic spacers.
                      • R_J
                        • Jun 2012
                        • 9579
                        It will be a wirewound, this from digikey should work A137101-ND Mfg # SQZW103R3J which seems to be like the original. TYPE SQZ horizontal, pluggable.
                        They go open after time, the wire gets a weak spot and thats it, If there was any other problem it would have blown the fuse and not the resistor.
                        If you just want to try the monitor, replace it with a piece of wire, if there is a short anywhere the fuse will blow. or if you want to get fancy replace it with a incandescent lamp to test
                        • roadrash
                          • Oct 2015
                          • 490
                          • U.K.
                          #32
                          wow thats expensive..
                          Subtotal: £2.07
                          Shipping: £12.00
                          VAT: £2.81
                          Total: £16.88
                          ive got a few ceramic wire wound ones coming from Ebay and yesterday after lots of searching I also found and purchased a MOX one as well. Is the MOX a better one to use?
                            • 31151
                            where the fuck are you shopping?????
                            RS is free delivery,
                            germany and poland only cost about £6
                              • 31151
                              https://uk.rs-online.com/web/p/throu...stors/6661718/
                              £7.90 inc free postage.
                              https://www.tme.eu/gb/details/crl10w...s/sr-passives/
                              55p + about £6 postage
                              https://www.reichelt.com/gb/en/wirew...?&trstct=pol_0
                              87p + postage
                              • R_J
                                • Jun 2012
                                • 9579
                                The resistor is just to provide a bit of surge protection when you first turn it on. It is in the ac line, it can be made from anything, its not important.
                                I just used digikey to find a mfg. part number of the same type and mounting that you are replacing.
                                https://uk.farnell.com/international...10w/dp/1457934 £0.933
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  #36
                                  That was DigiKey.
                                  Ive got some wirewound coming from a trader on Ebay for few quid.
                                  I will do as you said and solder in on top of the original.
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    #37
                                    I fitted a 3.3 ohm wire wound resistor and as soon as I powered it up it blew it again.
                                    • R_J
                                      • Jun 2012
                                      • 9579
                                      It blew the 3.3Ω 10 watt resistor! but not the fuse? Ok check the 4 power supply diodes, then check the resistance across the main capacitor. You must have a dead short somewhere in the primary circuit
                                      Post a picture of that new resistor that blew open
                                        • 31151
                                        told you!
                                        • roadrash
                                          • Oct 2015
                                          • 490
                                          • U.K.
                                          #40
                                          Hhahhaha yep You said it! Do you still think it a MOX because I did order a couple of these wire wound ones and a MOX one that I am still waiting to arrive. I will now do like RJ said and rty and find that short. I never expected that. there was just I small flash from the new restistor and I knew straight away and yep! its was blown. Just as well I got another.
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
