Crimping crimp-on RG58, RG174, etc. connectors without die?
  • delaware74b
    • Apr 2009
    • 628
    Re: Crimping crimp-on RG58, RG174, etc. connectors without die?
    I have a basic hex crimping tool I bought at ratshack before they went under. Here is a similar one on amazon. Many different ones for around $20.
    https://www.amazon.com/dp/B000FV32JK..._t2_B004IPMGM8
    Stupidity should be a crime, especially for drivers. I have NO patience for them.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8716
      Yeah, don't know why RG-6 and RG-59 are much cheaper than RG-8, RG-58, RG-174. Saw a couple for the 75 ohm cables cheap but the 50? No idea why...
      Then again, with people "cord cutting," 75-ohm cable crimpers may go the same way as 50-ohm...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8716
        LOL
        https://www.thingiverse.com/thing:4278483
        I really wonder how long these will last... PLA is very hard and brittle, but even aluminum is harder than PLA, and real dies are steel of course... (I also wonder, lead versus PLA, which is harder?)
        Then again what I really should do is make a die model, put it in casting sand, and cast them using molten steel. Or even aluminum...
        • clearchris
          • Dec 2013
          • 687
          Originally posted by eccerr0r
          LOL
          I have seen people using 3d printed parts as dies in hydraulic presses. Done right it can have high compressive strength.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8716
            I have a ratcheting crimper and a vise ...
            and an STL...
            • CapLeaker
              Crimping CAT7 connectors high failure rates
              by CapLeaker
              I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
              Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
              11-09-2024, 04:11 PM
            • Eniaro
              Are USB C connectors standard
              by Eniaro
              I have a number of laptops with damaged USB-C connectors.
              I wonder if I can buy a few replacement connectors from Mouser to keep, as it seems like the wafer in the middle breaks easily and oftentimes causes shorts.
              I do know there are multiple connectors out there, but I'm curious to know which are most commonly used and how can I identify and purchase the correct ones.
              I purchased USB mini-B connectors in the past, only to find out that the connector was flipped (Lenovo smh).
              07-24-2023, 03:07 PM
            • corrize
              Desoldering - soldering BGA chip close plastic mini fpc connectors ?
              by corrize
              Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
              There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
              I have :
              - hot air, and a
              ll stuff around
              - true kapton tape
              - 140 and 180 degree soldering paste
              - bismuth
              - little hot plate 250 degree max
              - the new BGA chip with probably
              05-20-2025, 01:26 AM
            • corrize
              How to clean fpc connectors oxydated ?
              by corrize
              Hello, do you know if it is possible to clean oxydated fpc connectors until it back brilliant please ?
              I know the best is to replace, but sometime micro fpc are very little oxydated and very hard (or unable) to find as new. So, there is may be a chemical product for that ?
              I use vinegar for rust on metal screw or little metal pieces and I finish with WD-40 for protect, else the rust can come back. That works pretty good.
              I not yet tryed on connector. Do you have a good method please ?
              10-20-2024, 07:29 AM
            • fuzzy4
              Identify Cable connectors
              by fuzzy4
              Can someone identify the connectors on this cable and what it's used for?
              I recognise the BNC and what looks like power.
              The middle connector, is a BNC adaptor.
              Thanks...
              09-08-2024, 02:37 AM
