Asus n50v bios remove password
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    Re: Asus n50v bios remove password
    In that case, try this.
    • deepspace
      • Mar 2015
      • 11
      • Slovakia
      Thank you, but Im not sure about your file, my flash is 25q128 and bios dump have 16MB, your file is 8MB only..
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Oh, sorry, I uploaded the wrong file. Will fix that, hold on.
        Edit: This one is correct
        • deepspace
          • Mar 2015
          • 11
          • Slovakia
          Unfortunately not working, NTB starts, power light lit, but no picture and other sign of life
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            Try and report
            • deepspace
              • Mar 2015
              • 11
              • Slovakia
              #26
              Claudiomfa , sorry , not succes, in this case NTB do nothing, no reaction on power button, no light
              • deepspace
                • Mar 2015
                • 11
                • Slovakia
                #27
                Maybe problem is not in modified dump, I reflashed original bios, NTB started, but no bios screen, only power LED lit..,
                Its possible corrupt some area of flash with programmer ?
                • deepspace
                  • Mar 2015
                  • 11
                  • Slovakia
                  #28
                  OK, Maybe there is a problem with the wrong programmer? I have an old Elnec that doesn't support it 25Q128FV SPI Flash, only 25Q128BV.
                  I used the setting for 25q128bv when programming.
                  Everything was done, Verify OK, but NTB not starting with original locked dump.
                  • RethoricalCheese
                    • Mar 2013
                    • 1519
                    • Estonia
                    #29
                    It doesn't matter if it is FV or BV.
                    Are you sure that all bios chip legs are soldered correctly and not shorted?
                    I usually push on the chip with tweezers when I solder wson8 chips.
                    • deepspace
                      • Mar 2015
                      • 11
                      • Slovakia
                      #30
                      Legs soldered correctly, I Tested continuity from legs to pads,
                      There may be a problem in the setup secure and configuration bits ?
                      • TECHO TN
                        • Jan 2024
                        • 61
                        • algeria
                        #31
                        Try this bios . AAAA99BD
                        Hello
                        i want to tell you thank you vert much
                        the bios file work perfectely
                        i wrote it using ezp2019 and no password now
                        100%
