Philips 234e problem
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Re: Philips 234e problem
    I'll check for numbers on the panel.
    So you think there will be the VGH + 15V to + 20V, which is generated by L2 that I removed, and also a +12V as well?
    If the +12V has a short abd it iis derived from the VGH then that could explain the symptoms I'll look to see if I can find anything. I don't recall seeing a 4th inductor anywhere
    Follow me on YouTube
    Learn Electronics Repair
    • R_J
      • Jun 2012
      • 9607
      There in only one +5 volt supply on the cable between the main an tcon correct? so the other voltages must be generated on the tcon board
      It seems a bit odd that if there is something drawing so much current on the tcon board it does'nt blow the fuse an the tcon.
      Did you ever try supplying +5 volts from a bench supply just to the panel and see if you had the other voltages?
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        Yes as far as I have determined there is only one +5V on the LVDS, but I will check again now I stopped the chirping with the LVDS connected.
        So Yes the other voltages must be developed on the TCON. I can see three inductors, L3 generates 1.8V, L1 generates 5V (which seems a bit odd as we already have a 5V supply).
        L2 I don't know what it should generate because the power supply chirps when it is fitted (but I have seen anything from 3.5V to 7V on it. But I will assume it is a high voltage like 15V to 20V
        I can only assume the fuse on the TCON does not blow because the supply cuts out (chirps) first
        No I didn't try supplying 5V to the panel PCB from my bench supply, I will try that next, with L2 fitted
        I'll also try to get my multimeter in series with L2 and measure the current, I should be able to do that by soldering some 'legs' to it, or soldering a low value sense resistor in series and measuring across that.
        Cheers
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          Panel number pics attached.
          OK so I checked if I could see any other voltages supplied on the LVDS cable but couldn't, though 3.3V was present so I wasn't sure about that.
          So I disconnected LVDS and used my bench PSU to power the panel edge PCB with 5V
          Without L2 fitted I get a steady load of about 220mA and all the voltages I could see on the panel PCB with LVDS were still present (1.8V on L3, 5V on L1) and 3.3V and 12V though I'm not certain where those originate but they are from somewhere on board.
          When I fitted L2 I get the chirping noise but it is now a constant chirp-chirp-chirp.... not in bursts of 4-5 chirps like before (so it the sound was coming from the panel edge PCB not the main PCB - my hearing is not very good to be honest) and I have 7V on L2
          The current meter on my bench PSU was jumping up and down rapidly with each chirp so I can't say what the current draw was
          There is no short from L2 to ground, and in fact it sits at 7V, so this is more like a zener or some other device breaking down on that voltage rail
          I did wonder what would be the symptoms if I had a shorted turn in L2. As it is the same value component as L3 I swapped them round. I still get 1.8V on L3, and the chirping starts when I replaced L2 with the other inductor.
          I then decided to use my dual bench supply to power the main board with 19V (so the back lights come on) and power the panel PCB with 5V with the LVDS disconnected to see what if anything i could see on the screen
          This video is the results of that test. https://youtu.be/N6-i57vSvK4
          I don't much like the look of it, truth be known. That purple vertical line slowly fades away to black after a minute or so once the 5V is switched off.
          So the problem does seem to be that something is overloading the supply rail from L2 once it tries to go above 7V, but it's not a 'common or garden' short.
          That's as far as I can get with this, I'm out of ideas apart from maybe removing L2 again and trying to drive that rail above 7V.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            I suppose I could try replacing SM4043 - they are cheap to buy
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              #26
              I ordered some SM4043 - let's see what happens when they arrive.....
              • glory68
                • Nov 2019
                • 1
                • Russia
                #27
                Hello! What is the result after replacing SM4043? On my T-con exactly the same fault
                • leszczuk
                  • Sep 2011
                  • 15
                  #28
                  Did you repair this monitor or LCD panel is dead ? Maybe glory68 have some tip for this monitor?
                  • cxlycxlo
                    • Jul 2023
                    • 1
                    • Romania
                    #29
                    Hello any updates on the monitor? I got one myself today and its got basically the same problem but it doesnt show anything when i connect the big cable to the monitor PCB
                    • janos6662000
                      Philips 47PFS7509/12 LCD TV problem
                      by janos6662000
                      Hi
                      I have here a Philips 47PFS7509/12 LCD TV which came to me with a weird problem : without signal i could access menu, make a factory reset, access menus, etc.
                      When i applied cable signal to check image, i had normal picture, but TV was restarting.
                      I downloaded original firmware and applied the update, but the problem remained.
                      From a colleague i received a "factory package software" which is a lot bigger.
                      I made another firmware update, but still did not solve the problem.
                      Somewhere on the way the error got worse, because at the moment the...
                      08-12-2025, 12:54 PM
                    • keepread
                      Dell monitor PSU vs Dell laptop PSU
                      by keepread
                      Hi there!
                      Someone gave me their old monitor, it's Dell S2715ht.
                      The owner was using it when his PSU began to smell and then to smoke. It literally began to melt. He turned the monitor off, pulled the PSU, and ditched it because it was smelly even after it cooled. So I got the monitor but not the plug.
                      Now, I tried to bring the monitor back to life, by plugging one of my many Dell laptop PSUs. They are of the same 19.5V, and the wattage of the laptop PSU is higher than that which the monitor is rated for. Visually, the socket on the monitor seems compatible, and the plug plugs...
                      Today, 04:45 PM
                    • courtcircuit
                      Philips HTS8000 home cinema noise problem
                      by courtcircuit
                      Hello
                      I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                      Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                      Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                      I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                      Removed each of tyhe boards
                      02-08-2025, 08:22 AM
                    • Askic
                      Problem with monitor DS-D5022QE-B
                      by Askic
                      Hello to all,
                      I have a problem with monitor that is delivered together with CCTV system.
                      The monitor appears to be completely dead, there is no LED power diode and it doesn't react to pressed power button.
                      I have disconnect display and check many components on the power supply part of the board. There is no anything obvious and monitor is about 3 years old. There are no bulged caps. When measuring voltages on the output connector to VGA board I can measure stable 14.5 V on 12V pins and stable 5.07V on 5V pins. So I assumed that this part of the board is OK....
                      05-31-2023, 03:14 AM
                    • CptChronic
                      Samsung LU32J590UQUXEN Monitor display problem
                      by CptChronic
                      I have an intermittent display problem with my monitor, when I plug in the HDMI cable to my (or any) laptop, you see the connection screen shrink on the laptop as it usually would before displaying on the monitor but 95% of the time the monitor display stays black.
                      Before it cut out all together, tapping the monitor control button a fair few times would make the screen display, and everything work fine.
                      But now it never does it. Not sure what's going on, hoping someone can help. I'm capable of stripping the thing down and soldering in new parts if needed, or programming...
                      04-24-2023, 04:33 PM
