lenovo t440p bios password
  • 530v8
    • May 2019
    • 42
    Re: lenovo t440p bios password
    Can you share us the fdb file and tell with which tool you just replace lenovotranslationservice
    • Maxpower3
      Bad Veteran
      • Feb 2018
      • 1356
      • France
      everything is already on the forum. the where you have already posted. Read the first pages, you will understand.
      https://www.badcaps.net/forum/showth...=65996&page=12
      2 files are needed for the first gen. boot and translate. ppis is automatically replaced by the software
      Don't try to put this dump in your machine. It's reserved and only for the dump of digitalpc !!!!
      • 530v8
        • May 2019
        • 42
        Yes I know that's not for mine
        I read all the posts but a lil bit chaos inside
        I will try again
        • digitalpc
          • Jun 2016
          • 305
          • .DLL
          Originally posted by Maxpower3
          Try this
          Remove all battery and CMOS battery
          press F1 to enter setup: password 1234
          wait 20sec or more
          Press anykey to hardware Id
          Press 2x space
          turn off
          and backup bios original .
          Enjoy
          if 2x 5 beep, it's normal, I didn't do the checksum but should light up anyway.
          Works on my T440
          Test and report please
          with this bios when i press f1 laptop goes off
          • 530v8
            • May 2019
            • 42
            Did you push the button on the Mainboard
            There is a small dip switch if 💻 body dissambeled it won't start.
            When not need to patch bios again just wait a lil bit
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1356
              • France
              #26
              start again with this one
              • digitalpc
                • Jun 2016
                • 305
                • .DLL
                #27
                dip switch? look my pic with red, is that
                • digitalpc
                  • Jun 2016
                  • 305
                  • .DLL
                  #28
                  thanks my friend, I will try tomorrow in morning and replay
                  • 530v8
                    • May 2019
                    • 42
                    yes this one also cmos battery and intern battery plug them out
                    this solved my problem
                    then start laptop and press f1 after that it says press space then press space again
                    it will say TPM certificate changed
                    _ -- this symbol will appear after that flash your original bios back and enjoy
                      • 31285
                      so is this latest file for all 440's or still for a specific machine?
                      • 530v8
                        • May 2019
                        • 42
                        no this is specific for user digital pc
                        every Lenovo notebook has an own bios file
                        so you can send your bios dump and the forum here can help you
                        • digitalpc
                          • Jun 2016
                          • 305
                          • .DLL
                          #32
                          Is working thanks i have another laptop with same problem, can u help me to remove password
                          lenovo t440p can u make same pached with this one
                          • digitalpc
                            • Jun 2016
                            • 305
                            • .DLL
                            #33
                            Haha i just try with same file u send for first laptop and is working
                            thank you so much.
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1356
                              • France
                              #34
                              The PC IDs remained the same as the original “UUID” Mac address etc. I suspected that it worked but not yet tested
                              • Mmunoz
                                • Jan 2020
                                • 2
                                Dear forum - I'm in the process of working on a series of 10+ Lenovo Thinkpad T540p's which are bios locked. I'm intending on selling them at a discount to area nonprofits. I've just purchased an SPI programmer which should be coming in a few days, but I wanted to ask the forum's knowledge base about what will be required here. I don't want to pay $60 per laptop obviously, but am concerned about corrupting the TPM by using solutions I found here. I also am not sure about the procedure, and what combination of tools (hardware and software) are needed. Any advice on where I can find this information?
                                -Mike
                                • Bonzas
                                  • 474
                                  • Indonesia
                                  #36
                                  Re: Lenovo T440P bios locked
                                  Originally posted by Mulong2019
                                  Here i share 8mb and 4mb file report if it is working
                                  This File Not Working on my board sir, no display
                                  • Conste
                                    • Oct 2018
                                    • 235
                                    The trick with shortening two pins of an IC when powering on doesn‘t work?
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1519
                                      • Estonia
                                      #38
                                      It works up to T430, not on T440.
                                      • shafqat ali
                                        • Jun 2019
                                        • 1
                                        • uae
                                        #39
                                        Re: Thinkpad t440p - Restoring locked bios
                                        hi sr have lenovo t470 bios password how to remve send me pached file?
                                        • bachir2004
                                          • Feb 2015
                                          • 439
                                          • maroc
                                          #40
                                          https://www.badcaps.net/forum/showth...=65996&page=41
                                          • RMDUiFT
                                            Should I buy a Lenovo Thinkpad E495 with bios password?
                                            by RMDUiFT
                                            Good day. I apologize if I posted this in the wrong topic. I saw somebody selling a Thinkpad E495 with a Ryzen 3500U CPU near me. In the pictures the laptop is running windows 10. I contacted the seller and asked a few questions about upgradability and if it has a bios password on it. He confirmed it has a bios password. I searched through the forum, I found a guide regarding removing the bios password using the autopatcher, I also found a thread with the e495 where people requested help with unlocking the bios password.
                                            I have a few questions:
                                            • If I would buy this laptop and have
                                            08-25-2024, 09:00 AM
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • lucaszmn
                                            Summary of BIOS Whitelist Removal Problem Lenovo Thinkpad T560
                                            by lucaszmn
                                            Problem:
                                            I am attempting to remove the WWAN card whitelist from my Lenovo ThinkPad T560.
                                            Initial Findings:
                                            • My current BIOS version is N1KET58W (1.45).
                                            • I have a CH341A programmer and have successfully created two full backups of my BIOS.
                                            • I have the ability to use command-line tools on a Linux machine.
                                            Troubleshooting Steps & Conclusions:
                                            • I attempted to use several automated and manual patching methods on my N1KET58W (1.45) BIOS, including using hex strings. These attempts all failed.
                                            • I concluded that the
                                            08-12-2025, 03:01 PM
                                          • baaligoga
                                            Help needed in unlocking BIOS Supervisor password - Lenovo X1 Yoga 5th Gen
                                            by baaligoga
                                            Good day, everyone!
                                            I'm encountering an issue with my Lenovo X1 Yoga 5th Gen laptop related to the BIOS supervisor password. I'm seeking assistance and guidance from the knowledgeable members of this community in resolving this problem.
                                            I am no expert and cannot perform soldering or unsoldering of the chip from the board. Therefore, I attempted to use an EZP 2023 programmer with a clip to extract the BIOS bin file without removing the BIOS chip from the motherboard. The BIOS chip has the following letters imprinted on it: "Winbond 25Q80DVNIG 2026". I used the...
                                            05-20-2023, 09:48 AM
                                          • darknwo
                                            Bios password Lenovo Legion 16IRX8H
                                            by darknwo
                                            Hi, can someone help me please with the removal of the bios password of this dump.
                                            Someone desoldered the bios chip, tried several "methods" but with no luck, and he gave me the dump to try to search some help.
                                            For now he deleted more things and bios password is gone but laptop doesn't show serial, model etc.
                                            Also, I updated bios to latest version, when he will write the dump again without password, it should be better to put back the old version that was orignally or doesn't matter? Because from what I've read this laptop has 3 bios chips, don't know if has...
                                            10-05-2024, 10:40 AM
