Remove rear panel Sony Bravia KD-65X7500F
  • viewerau
    • May 2020
    • 305
    Re: Remove rear panel Sony Bravia KD-65X7500F
    I don't know...the logical way to me, is that it must go upwards, along the central channel, however, I'm unsure how to undo the very to full length of the top part that would let it slide upwards.
    I'm guessing that along the top panel, where the red dots were placed on my photo, must be the screw heads referred to, but releasing them seems my problem. As I squeeze those areas, there is some give, but it feels like the whole area would crack with more exertion??
    Signature:Seemingly hopeless tv fixer
    • budwich
      • Jul 2015
      • 3097
      can you provide better pictures of the top back edge area along with the "divide" between the top half of the back and the bottom / card area?
      hmmm... how about this link... if you can figure out the diagrams or maybe when they mean "exploded view", they actually mean "blow the thing up and watch".... :-)
      of course, they don't provide much cover removal.... but you see the order of things.
      • viewerau
        • May 2020
        • 305
        Well done budwich
        These are the areas I needed to see
        It appears there must be some clips or something under the top panel area, here
        I just have to try figure that part out, it seems???
        • budwich
          • Jul 2015
          • 3097
          have you removed items 1 and 2 shown. My take is the bottom half of the back panel pulls out at the bottom of the panel to clear connections of inputs and then slides down from the middle section to remove.... just a guess. Again, some clear pictures of the middle section as the forum "eyes" are not that good / almost blind. :-)
          • viewerau
            • May 2020
            • 305
            Thanks...I will try get a photo up tomorrow, as I am away from the house at the moment...txs for help.
            • viewerau
              • May 2020
              • 305
              Here is some photo's I have stored
              • budwich
                • Jul 2015
                • 3097
                You aren't trying to remove the back with the legs still attached?
                • viewerau
                  • May 2020
                  • 305
                  No, that's a photo before I removed the legs and all screws.
                  Items 1and 2 are simply the power chord connection and cover, and these were shown as already removed in my first
                  post, in the original link to the back of this panel/tv.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Does that silver strip come off to reveal access to more screws ? Is that where it's catching ?
                    • nicholas1110
                      • Aug 2012
                      • 127
                      • usa
                      #30
                      On most of the new Sony’s with the backs like that, in the bottom corners there is one clip that is very strong. Usually once you release those clips in the corners the bottom with be Loose the you angle it upwards and pull it towards the bottom to slide it out of the channel on the top.
                      • budwich
                        • Jul 2015
                        • 3097
                        i agree, that "finish strip" probably pries off to reveal more screw points along the border between the top and bottom halves. I see you are like me and leave the protective plastic on your stuff... :-)
                        look close at the area to see if the finish strip is "integral" to the rest of the plastic or indeed has some sort of "disjoint" with the other plastic panel.
                        • viewerau
                          • May 2020
                          • 305
                          The plastic strip top and bottom is just protection film. There are no screw holes under either piece.
                          I "believe" the trick is something to do with the pressure points in the disassembly diagram.
                          If I can somehow get them to release, it appears that the whole top and bottom section with the protective plastic strip should come off.
                          • dick_barton
                            • Aug 2015
                            • 6643
                            • Wales
                            #33
                            On a set I worked on recently I had to use a plastic piece similar to a guitar pic and and an old credit card to slide between the joint and slide up/down to release internal plastic catch.
                            • viewerau
                              • May 2020
                              • 305
                              Is there a chance that the vesa mounting area needs unscrewing before the back will come off. Even though I have never wall mounted it, the threaded 4 mounting holes are still there. .Do you have to remove the unused female threaded screw holes first? If so, what tool does this, or is these spots permanently attached to the chassis and not need removing at all to take off the cover. As you can see, I am just getting nowhere.... thanks in
                              • nomoresonys
                                • 12218
                                • U.S.
                                #35
                                This thread has got to be the funniest thing I have ever seen on this forum, maybe we should start a pool, how many posts will it take to get the back cover off, I'm going with 99.
                                • viewerau
                                  • May 2020
                                  • 305
                                  It may be funny if you are just watching 😀, but from a personal point of view, it is absolutely frustrating.
                                  It is not just here that I have posted, but in many different forums world wide....not one has been able to answer my question precisely, only with suggestions, like have been done here to date.
                                  At least people are trying to help, and just maybe, someone whom has done it before, or possibly another with access to the service manual will be my answer.
                                  Believe me, as well as frustration 🥵, this seemingly simplistic task has me stumped 🔨🔨🔨.
                                  • petehall347
                                    • Jan 2015
                                    • 4430
                                    • United Kingdom
                                    #37
                                    here is the video again ..watch from 3.20 . https://www.youtube.com/watch?v=rVftkD0GFoU
                                    • viewerau
                                      • May 2020
                                      • 305
                                      Thanks again petehall347.....I searched via Google this afternoon, but failed to find the name of the tool shown at 3:20, hence asking its name in the other post....does anyone know?
                                      I did try with a wide flat bladed screwdriver, but unsuccessfully.
                                      • nomoresonys
                                        • 12218
                                        • U.S.
                                        #39
                                        So you mean you got the "finish strip" off?? looking at nick's tool, maybe you could use a butter knife or similar if it isn't too thick to fit, the tool looks to be a pretty basic piece of sturdy metal, yes I did see your posts on other forums, makes it even funnnier. 39.
                                        • diif
                                          • Feb 2014
                                          • 6978
                                          • England
                                          #40
                                          It's called a spudger, they a few generally used for prying.
                                          https://www.ebay.com.au/itm/1PCS-Met...302?nav=SEARCH
                                          • guidodroid
                                            Bad Panel in Sony Bravia X850G
                                            by guidodroid
                                            Hello all,
                                            I'm trying to understand what is the issue with my 26 months old Sony Bravia KD-65XG8505 (XBR65X850G).
                                            It is just few months out of warranty, so Sony doesn't want to do anything, and the local replacement shop also tells me that it's not worth repairing (alhtough this model costed almost 1000 euros just 2 years ago...).
                                            Few nights ago the TV started showing some horizontal lines and distorted colors/geometries in the bottom part of the screen (see attached photos).
                                            The issue is not as bad as others that I've seen around, but is indeed noticeable...
                                            03-19-2022, 12:08 PM
                                          • m4a2t0t
                                            Sony Bravia 75X850C panel
                                            by m4a2t0t
                                            After changing out the backlights I have a single green vertical line on the left side of the screen. Is there any way to fix it? I tried putting pressure on all the tabs and on the top of the panel but neither helped.
                                            Does Sony epoxy all their panels or just the expensive ones?
                                            12-07-2023, 05:43 PM
                                          • swrb898
                                            Sony KD-70X690E Bravia; Bad TCON? Bad panel?
                                            by swrb898
                                            What's wrong with my TV: the TCON, the panel, or something else? I'm stuck.
                                            Problem:
                                            Last week, my Sony KD-70X690E 70" stopped displaying a picture. The TV powers on, and the back lights power on. However, the TV doesn't seem to boot up. I say this because the SONY splash-screen logo does not display, nor does any picture display, nor can I invoke a menu by pressing "Menu" on the remote. Other than back-light bleed, the screen is black.
                                            My troubleshooting got me this far:
                                            With the left-hand TCON to bottom-board ribbon cable...
                                            12-28-2021, 08:12 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • PopsCaps
                                            Sony Bravia KDL-40V2500 that will not power on
                                            by PopsCaps
                                            I have a Sony Bravia KDL-40V2500 that will not power on. The indicator flashes red 3 times.
                                            I do not hear any sound and I cannot see any backlight.
                                            I have tried disconnecting every cable on each board one at a time to see if anything changes.
                                            The only change is when I disconnect AC-DET cable on the Power Supply board or on the other end if I unplug the CN7009 connection on the B-Board and try to power on the TV the indicator will stay on solid green until I power off.
                                            My friend ordered another used power supply board but it is also doing the red indicator flash 3 times...
                                            03-25-2025, 11:23 AM
