the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
  • cheese007
    • May 2009
    • 85
    Re: the gutless, bloated, and fried power supply hall of shame
    I know I already posted it, but I think it's bad enough to warrant posting again. Power board for a Philips CD-i 910.
    • c_hegge
      • Sep 2009
      • 5219
      That's nasty. The only time I've seen anything that even comes close to that was the PSU from a computer that lived near the coast. One day it went BANG. I opened it and noticed that the PCB was wet (salt water?). Unfortunatly, when this PSU died it took the motherboard out. It was a shame as it was a good PSU (FSP).
      • cheese007
        • May 2009
        • 85
        The machine it came out of seems to have been around moisture for quite some time, an almost cough-syrup like substance, as there's a whole bunch of dust stuck to one part of the unit. I REALLY need to repair it, as these machines are quite rare, and a new one costs upwards for $200 if you want something that won't break (I paid $40).
        • 370forlife
          Large Marge
          • Aug 2008
          • 3112
          Originally posted by cheese007
          To be fair, that one is actually rated for 150w (the label pictured is from another PSU on that site), but still...
          I believe leadman/sunpro/Powsun makes psu's that can run their ratings, and when OEM's look to buy them, they simply ask "what wattage is it", to which they reply "what wattage do you need?"
          • c_hegge
            • Sep 2009
            • 5219
            This is an old 400W Generic PSU. It would make some strange hissing and zapping noises when plugged in, me and my best friend sprayed lots and lots of WD-40 in it and dropped a match in. Here's the carnaige.
            PS. I removed the fan first so I can use it as a case fan.
              • 30979
              you should have rescued the cables first - i find lots of short cable very usefull.
              • everell
                • Jan 2009
                • 1514
                Now you can post an ad on Ebay................one slightly burned computer power supply, $75. As is, no return!
                Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
                • c_hegge
                  • Sep 2009
                  • 5219
                  I have lots of wires from other faulty PSUs.
                  • c_hegge
                    • Sep 2009
                    • 5219
                    Here's another one, an Excel 450W (I doubt if it would actually be 450W, probably 250W MAX). It wouldn't even turn a computer on. Note the burn marks in the pics. I'll probably do the same thing to this as I did to that other cheap one (set it on fire). I LOVED hearing those caps pop.
                      • 30979
                      why not put a big load like a 100w lamp or 3 on it and power it up outdoors to go boom?
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        #31
                        You need to be more eco friendly :P
                        • c_hegge
                          • Sep 2009
                          • 5219
                          It's already fried. I also like using WD-40 or something flammable like that as it keeps it burning for longer (long enough for all the caps to pop). Also, if I do want it to explode like that, I just put the voltage selector in 110 volts (We have 240V here in Australia). If it doesn't have one, short the two pads fhere it was meant to go on the PCB.
                            master hoarder
                            • May 2008
                            • 12170
                            • Bulgaria
                            #33
                            Doesn't look that bad really. Might be useful for powering up something like this:
                            http://www.instructables.com/id/DIY-...8volts-DC-at-/
                            Just remove the 5vsb circuit on the primary side, then find an adapter anywhere between 7v and 40v to power the PWM controller (since 5vsb is dead) and the PSU should be working again.
                            • c_hegge
                              • Sep 2009
                              • 5219
                              Can't be bothered re-capping it as well as finding a substitute for the dead rail. It's full of fuhjyyu (and the 5vsb one is leaking). I don't usually bother repairing PSUs unless they are really good in all other ways (like the Channel-well made Antecs).
                                master hoarder
                                • May 2008
                                • 12170
                                • Bulgaria
                                #35
                                I know what you mean, I wouldn't put money in repairing a PSU like that either (let alone putting it in a computer). But if I find the right parts for free, perhaps I would. The good thing about broken stuff like that is that you can try and fix them with whatever you find, and even if it doesn't work or if it blows up, you don't loose much (except for some time). And if you do manage to fix it, you see what works and what doesn't (kind of like one of 370's threads where he swapped transformers from one PSU into another and it worked).
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  Took this one home from work today, along with 2 Fuhjyyu'd Antecs. It's a Sun Pro, supposedly 550W, although I doubt it would be anywhere near that. The caps are either branded "CS", "GL", or "JEE". Two caps are bloated (although it may not be obvious in the pics) one is a 2200uF 10v JEE and the other is a 1000uF 10v CS. Note the discolouration around the middle of the PCB.
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    "jee"!
                                    4 diodes! so you are right, i'd say 200-250w max
                                    look at the heat damage.
                                    edit- OMG! look at that fake y cap on the secondary board attached to the ac plug! one of the leads is shorting the AC!
                                    gut it!
                                    sigpic
                                    (Insert witty quote here)
                                    • c_hegge
                                      • Sep 2009
                                      • 5219
                                      Actually, it probably can really manage 550 Watts.....For half a second!
                                      • 370forlife
                                        Large Marge
                                        • Aug 2008
                                        • 3112
                                        Also note the second primary switcher that is split in half
                                        • Wizard
                                          • Mar 2008
                                          • 2296
                                          #40
                                          That size of recifier bridge diodes on input side. That won't let PSU go all the way. These is rated 1A max.
                                          Cheers, Wizard
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • Lapsmith
                                            Fried capacitor on Dell-5520. Guilty as charged.
                                            by Lapsmith
                                            While installing new SSD's in my new to me Dell 5520 laptop, I dropped a screw which sparked and fried a capacitor. Yes, I know I should have disconnecte the battery first Doh!😡. The laptop runs fine, but I want to replace the capacitor asap. I ordered and received the replacement (10uF, 25V 0603). Since I also managed to burn up one of the pads it was soldered to, my main question is whether it is okay to solder this capacitor on top of another capacitor (same size, same function in circuit). Specifically, PC4428 is bad and no way to easily solder to the board. I would like to solder it piggy...
                                            07-06-2025, 11:08 PM
                                          • Per Hansson
                                            Power supply ripple hall of shame
                                            by Per Hansson
                                            While our PSU hall of shame thread is fun I thought It'd be fun to have a ripple hall of shame thread too
                                            I'll go first out, it's an industrial PSU that offers +15v -15v -5v +5v rails.
                                            However it has been mounted on a frame with DC/DC converters for producing +12v and -12v as well.
                                            The caps for this have gone a bit high ESR
                                            The measured ripple is around 1700mV, or 1.7v!
                                            After recapping the ripple is gone, also note that the scale on the scope is 50mV/div instead of 500mV per div in this shot
                                            -And that's how you know you have a qualifying...
                                            05-24-2018, 01:03 PM
