APC BackUPS LS-500 Schematics?
  • cook
    Quiet observer
    • May 2010
    • 100
    Re: APC BackUPS LS-500 Schematics?
    I know that this schematic I posted above isn't the exact match, but it should be good enough to give an idea what is going on.
    For me, I'd ESR the sh*t out of them caps and replace them. I've had a run in with my small SMT a few years back, it turned itself off all the time.
    https://www.badcaps.net/forum/showthread.php?t=66277
    I'd change the two brown caps, the 2 black caps next to it and C51 and retest.
    Got it, I will be replacing larger brown and black caps. I may do some more trouble shooting on the board first just to see if I can find other bad caps too.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8351
      if you see a regulator, change the caps surrounding it too.
      • cook
        Quiet observer
        • May 2010
        • 100
        I may need some help in identifying if the board has a regulator. Would that be one of the IC chips that I listed in an earlier post? Or is it something else on the board? I have pictures of the board in an earlier post.
          • Jul 2011
          • 6070
          I would definitely recommend doing the ones right next to these chip but ones you get working correctly I would highly recommend that you recap the hole board
          As far as the regulator ic chip you would have to look up each part to what kind a chip it is
          • cook
            Quiet observer
            • May 2010
            • 100
            I found a regulator. It is a LM2575T. I will be tracing down the caps that are next to it.
            It may be next week sometime before I have any results, but I will post what I find.
            • cook
              Quiet observer
              • May 2010
              • 100
              I finally replaced all ten of the various aluminum radial electrolytic capacitors on the board. The only ones that seemed out of spec. were the smallest ones - 22uF 16V ones, which were blue and made by JiangHai. There are 6 of these on the board. Some of them had very high ESR values. I have been running it for a few days now with the new caps and it is no longer beeping. So I am thinking that they were the cause of the intermittent beeping I experienced. Thank you to everyone who helped me with this fix.
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8351
                good to hear that you had success!
                  • Jul 2011
                  • 6070
                  I am glad you got it back up and running
                  On this voltage regulator what was on the next line was it a 5 or was it 12 this tell you what what voltage is
                  Now if it not have anything then it adjustable type
                  • cook
                    Quiet observer
                    • May 2010
                    • 100
                    Sorry Sam_sam_sam,
                    I don't know what was printed on the next line on the regulator. It is all back together now, and I can't see that part. And it is not easy to get it apart.
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • mrautom8
                      Samsung TV UN75H6350AFXZC main board schematics?
                      by mrautom8
                      Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                      Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                      While relay is on, all voltage rails are present and steady (scoped) on main board.
                      I love a good logic puzzle but getting lost without any schematics.
                      No shorts on ANY capacitor main board.
                      Thermal camera shows 3.3V inductor getting warm instantly but...
                      10-19-2025, 06:32 PM
                    • Rezendes
                      Looking for 13" Macbook Pro A1278 mid 2012 820-2565-A Schematics and Board View
                      by Rezendes
                      Hello, I am looking for any and all files related to the mainboard for 820-2565-A (13" Macbook Pro A1278 mid 2012) schematics/board view.
                      I looked through forum search results and google and was unable to find a board view file, I found a pdf of all the schematics but I don't know where the parts physically are on the board as this is my first macbook board level repair attempt.
                      The macbook charger has a green light, the battery has been replaced and OS reports Normal status but Not charging. After cleaning a corroded capacitor it crumbled off the board. There...
                      05-10-2024, 02:18 PM
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • howardc64
                      by howardc64
                      Problem
                      08-04-2024, 10:36 PM
