Daewoo microwave oven repair
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8696
    Re: Daewoo microwave oven repair
    I sure hope there aren't tv's using selenium rectifier stacks for crt rectification... More likely using selenium stacks only for "low" 200 volts and if that old, things like 1B3's for CRT final anodes.
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      Originally posted by goodpsusearch
      I don't know where this was stored, but the inside of the cooking chamber shouldn't rust like this. The oven doesn't look too old too to justify this level of oxidation.
      I know, but unfortunately I've seen this quite often on my local classifieds with various modern microwaves (and occasionally some old ones too, but a lot more rarely - seems the old stuff are indeed better built/welded/painted.)
      They used to sell special microwave paint for touch bad spots for inside the microwave shell
      But I have not seen any for a very long time
      Yeah, people just don't want to bother fixing anything anymore. A lot of things are getting too cheap to the point where it's cheaper / less effort to throw away the old/broken and buy new. And it seems more and more appliances make designs that are "not user-serviceable".
      In regards to the touch-up paint... mine certainly needed more than just a few "touch-ups"
      Originally posted by redwire
      Never seen rust in ovens, but habit is to leave the door open after cooking to air it out.
      I suspect that's part of the reason why, too. Seems people just don't bother to clean up their spills and don't air out their MW when cooking something for very long nowadays. Otherwise, I doubt the relatively high humidity where I live (at least in the summer and parts of fall and spring) could do this kind of damage. After all, our MW is over 20 years old and still no signs of rust spots anywhere in the chamber. There are a few small ones starting to show up on the door where it bumps into the chamber (so I'm guessing the opening and closing of the door after all these years started these spots, and they eventually grew a bit... but still far from being anything significant.)
      On that note, I grew up in Eastern Europe in the 90's, when getting a new appliance (especially a "Western" one like a microwave) was almost like a family celebration, lol. One of our more "wealthy" (at the time, anyways ) neighbors got a MW in the early 90's, and you bet they treated it with the utmost care.
      But now? No one really cares, I think. Just use, abuse, and throw away when it's broken, then buy new again.
      Originally posted by eccerr0r
      Considering that it costs $12 to mail something to my parents if it's 2 pounds and $18 if it got to $3, shipping heavy copper + laminated iron MOTs is part of the overall cost that shift towards transistors and flyback transformers...
      Yup.
      Well, it's a saving all the way around. Copper is getting more and more expensive - often to the point where it's cheaper to put several complex ICs and a complex overall design, just to save a little bit of copper in a transformer or wherever else. Of course, back when ICs and transistors (especially high-power ones) were expensive, it probably did make more sense to keep designs simple with less of these and more heavy passive parts. Just look at any wall adapter - despite having a few 10's of components and ICs, if not more, it's still cheaper than a regular iron-core transformer... and offers better regulation and lower standby consumption too (not to mention wide voltage input most of the time as well.)
      • goodpsusearch
        • Oct 2009
        • 2850
        • Greece
        Btw these Panasonic inverter microwave ovens have vary bad reputation for failing prematurely
        • valvashon
          Toshiba EM131A5C-BS microwave oven- noisy EE16 2.7 mH inductor
          by valvashon
          This poor microwave oven was purchased by my former employer in 2019 (it's a 7/2018 build) and lasted for about 3 months before making a terrible noise when in use. I determined that it was the main transformer and contacted Toshiba. They asked for a picture of the cord cut in half and the serial number, and then credited my boss' credit card. Rather than sending it to the e-waste, I bought a transformer on eBay and thought I'd try flipping it. Discovered that used microwave ovens aren't worth much but in for a penny, in for a pound as they say. It sat in my basement getting kicked and shoved...
          02-20-2024, 10:38 AM
        • drykid
          Matsui 175S microwave fuse replacement
          by drykid
          I recently picked up a used Matsui 175S microwave that was powering up (starts, turntable rotates) but not heating. From looking online the most likely culprit was the fuse, but unfortunately in this one the fuse had heated up and fused with the (badly designed) fuse holder and couldn't be removed. I guess this might indicate further issues beyond the fuse itself but at this stage I just want to replace the fuse and see how I go from there.
          Anyway since I couldn't get out the fuse itself the easiest fix was to replace the fuse holder assembly that runs between the...
          12-21-2020, 01:15 PM
        • tmhobadcap
          Can a microwave oven be used to reflow solder joint?
          by tmhobadcap
          I heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
          Is that possible? I do not want to try this unless I have a spare microwave oven.
          (I do not mean to suggest somebody to try this. It may be...
          10-30-2020, 08:38 PM
        • corrize
          A funny fuse story – Lumix LX100 II
          by corrize
          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
          10-19-2023, 09:58 AM
        • papillon
          Monitor Interlook switch on a microwave
          by papillon
          I *was* trying to determine the cause of a failure in a microwave oven.
          The unit is a Frigidaire Gallery model CGMV175QFA.
          For future reference, the exploded view for this specific model is available here.
          The last page of that document also has the electrical diagram which I am attaching to this message as well.
          The unit had a blown fuse when I opened it. I tested each component individually (magnetron, relays, tracsformers, etc) and all appeared to be working fine (no shorts) but the fuse kept blowing.
          Eventually, I looked at the electrical diagram...
          04-17-2023, 09:32 PM
