1300W PSU - Help with replacement mosfet
  • sdinelli
    Sdinelli
    • Aug 2014
    • 152
    Re: 1300W PSU - Help with replacement mosfet
    the 10k resisters are good. i took them out of circuit along with one of the fets in yellow ( the one on the end because it was easy to get out)
    it turned on and off as it should.
    so it looks like i can get away with replacing the one main fet ( ill probably replace both), diode and the through hole resistors.
    hopefully i remember where all the stuff i took out goes haha
    jk
    ill order parts and report back when its installed.
    i still have to make the light bulb current limiter thingymambob
    • sdinelli
      Sdinelli
      • Aug 2014
      • 152
      Actually can someone help me identify the specs of these resistors?
      I really suck at this for some reason
      they seem like metal film 2watt
      2x 5.8ohm.05%
      1x 65.9ohm.05%
      What do you all think?
      • tbgaming
        • Mar 2021
        • 13
        • canada
        You technically already did. The specs are as such indicated by it's color bands.
        • sdinelli
          Sdinelli
          • Aug 2014
          • 152
          Well what if im color blind?? :P
          I guess im just looking for reassurance before i order. im just guessing on the 2 watts too does that sound about right?
          • R_J
            • Jun 2012
            • 9625
            The resistors are likely ok based on your first post?
            • sdinelli
              Sdinelli
              • Aug 2014
              • 152
              But they measure very low about .03-.04ohms
              • R_J
                • Jun 2012
                • 9625
                They are very low values, resistors very rarely go down in value. When I first looked up the values they came to 0.05Ω
                Using the 4 band color code, they read 0.05Ω 5%
                • sdinelli
                  Sdinelli
                  • Aug 2014
                  • 152
                  well why do they have 5 bands then? its confusing which is why i asked in the first place.
                  Whats the point in having such a low resistor there? does it act as a fuse?
                  If you did measure them as 4 band they would still measure lower then spec
                  which leads to ask do i replace them with 4 band spec or 5 band spec resistors?
                    • Jul 2011
                    • 6070
                    Here is the answer to your question
                    https://www.digikey.com/en/resources...tor-color-code
                    Use the calculator for 5 and 6 band selection and you see what each band is for
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      #30
                      Sometimes there are 4-band resistors with a 5th band that stands for "reliability", IIRC. This is different than regular 5-band resistors, where the first 3 bands are the value of the resistor, the 4th is the multiplier, and the 5th being the tolerance. In this case here, I think we are dealing with the former.
                      Current sensing + fuse.
                      Despite its low resistance, a significant voltage rise can appear across that resistor when a very high current is passed through it momentarily, thus allowing ICs in the PSU to gauge how much current is passing through a given circuit.
                      These resistors are also typically metal-oxide flame-proof and fusible - that is, if overloaded severely, they will open like a fuse and will not burn down (something that regular carbon composition resistors may actually have trouble with.)
                      I suggest not to replace them, like R_J said. Indeed when resistors go bad, they don't go lower in resistance but always higher. The fact that they did not go open-circuit means they survived whatever fault there was in the PSU, again, since they are fusible type. I'm also a bit confused on their color band rating as well. The two with Black, Green, Silver, Gold, Green bands don't seem to fit any standard ratings, as black can't be a first color band (unless it's brown that has turned very dark - in which case, these should be 0.15 Ohm resistor, I think) and if rad the other way, Gold doesn't make sense as a 2nd color band either. The 3rd resistor also doesn't make sense to have a value starting with Blue (6) and Green (5) color bands, and the other way around has same issue as above with Gold as the 2nd band.
                      *EDIT*
                      According to the Digikey resistor calculator that Sam posted above, the resistors with color bands Black, Green, Silver, Gold, Green show up as 5.8 Ohms, 0.5%... and that's assuming the 3rd (middle) band is NOT actually Silver but rather Gray (calculator has no selection for Silver.)
                      And the other one (Blue, Green, Gray, Gold, Green) comes up as 65.8 Ohms.
                      Now that appears to be a match with your measurements in post #22, so I think they are OK indeed.
                      • sdinelli
                        Sdinelli
                        • Aug 2014
                        • 152
                        Thank you for your time and detailed explanation.
                        Ill order the stuff and see what happens.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          #32
                          Sounds like a plan.
                          Oh and when you get to the part with testing with the series incandescent bulb, you may have to try a few things there. Namely, since this PSU has APFC, the APFC circuit may not function properly with the series bulb.
                          Thus, my suggestion is to first start with a 60-100 Watt bulb and see if the 5VSB comes up and also if the bulb stays off (after turning on for a moment on two when the PSU is first plugged in.) If 5VSB comes up, you can try to tun on the PSU by connecting PS-ON on the 24-pin ATX connector to ground. If the incandescent bulb blinks on and off for more than 2-3 seconds, you may have to use a bigger bulb (or two or three more bulbs in parallel with the first bulb.) This will increase the power the PSU can draw through the bulb(s) and thus may now allow the APFC to function properly and make the PSU run. However, if the bulb(s) stay fully lit after trying to turn on the PSU, there may still be a fault in the PSU. Do report back if you run into either of these two cases.
                          The series bulb tester is a very useful tool, but can also sometimes get tricky to use on PSUs with APFC and may make you think the PSU still has a fault when it hasn't. But in any case, it is still a good idea to use it, as without it you do run the risk of blowing your new MOSFETs again.
                          • sdinelli
                            Sdinelli
                            • Aug 2014
                            • 152
                            Well parts came in. PSU is all back together!
                            i really wish i had a solder sucker! getting solder out of the holes with just solder wick can be a pain.
                            Anyways
                            I just need to find a bulb socket.
                            basically i took an old power cord. cut the end and attached it to a typical electrical socket and wall box.
                            I removed a foot or so of shielding from the cord exposing the wires.
                            cut the black one, and plan is to attach them to the bulb socket and bam.
                            Sound about right??
                              • 31286
                              and bam.
                              the lamp is to prevent that!
                              • sdinelli
                                Sdinelli
                                • Aug 2014
                                • 152
                                Welp here it is, i guess im going to see if i get 5VSB
                                I if you all dont hear back then im probably in heaven or hell
                                • sdinelli
                                  Sdinelli
                                  • Aug 2014
                                  • 152
                                  i have 5VSB!
                                    • 31286
                                    that lamp looks surprisingly white, is it a real glass filament lamp??
                                    • sdinelli
                                      Sdinelli
                                      • Aug 2014
                                      • 152
                                      welp. i guess its a failure.
                                      i get the 5vSB but psu doesnt turn on.
                                      testing a spare 350W psu with the limiter i get all my voltages.
                                      Do you think the 1300W is too much for the limiter or something?
                                      im using a 72W bulb and bulb turns on and fades quickly when switching psu on.
                                      Any thoughts?
                                      • sdinelli
                                        Sdinelli
                                        • Aug 2014
                                        • 152
                                        yes i believe it is a standard incandescent bulb. its just frosted glass i suppose
                                        • sdinelli
                                          Sdinelli
                                          • Aug 2014
                                          • 152
                                          OK i did some testing with the supply switch on but pins not shorted.
                                          my results are
                                          150V across main filter caps.
                                          150V on both source and gate on the two fets i replaced but nothing on the drain. I imaging the drain will only be present when PSU = on?
                                          the two other fets i had highlighted in yellow in that picture:
                                          Fet on right=
                                          S & G = 150V
                                          D= .45V or .55V depending on which side of main cap you use as ref
                                          Fet on left:
                                          S & G= .39V
                                          D= 150V
                                          Im not sure if these sound ok or not?
                                          I'm not sure which part of the circuit switches it on i guess i can trace the psu -on pin and see where it goes....
                                          • DoOm86
                                            Dual mosfet replacement help
                                            by DoOm86
                                            Hello.
                                            I have a notebook with a shorted mosfet, it's a E6930 GA8125.
                                            It seems to be a 30V dual asymmetric N-channel AlphaMos.
                                            Luckily the notebook is working, so I just need to find a good replacement for this mosfet.
                                            And here is where I need help!
                                            It's the first time I have to replace this kind of mosfet, I checked on mouse and I found this: (mouser No) = 512-FDPC5030SG.
                                            I need your help to be sure is a good replacement or there is another with better compatibility, since I can't find the same exact (just from China).
                                            Thanks!...
                                            10-31-2023, 12:03 PM
                                          • jm942
                                            Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                            by jm942
                                            My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                            I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                            I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                            I did voltage injection on the cpu with 0.7V and i have a current...
                                            07-11-2024, 05:11 AM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
                                          • String2016
                                            SMD MOSFET REPLACEMENT
                                            by String2016
                                            Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                                            01-23-2025, 06:35 PM
                                          • String2016
                                            by String2016
                                            i NEED Help any replacement for this mosfet M3092M?can i replaced with EMB20N03
                                            12-15-2024, 05:31 AM
